XaCT: a Costing Tool
Re: XaCT: a Costing Tool
Thank you Serge for your suggestions.
Actually, this book can be fully encrypted using AES encryption (sqlcipher).
However, it is possible to have a User Authentication Module.
I am happy that you have seen english.txt :) I have just tested about the multilingual capability of the software. It shall be fully implemented in the next version, enabling it to be extended to any language easily.
I will make a full example and share.
Agil Abdullah
Post by Agil Abdullah »
I am very sorry to [once more time] report Build Error. I followed your guide (as seen on screenshoot of my folder) but error remained the same. I run also "buildalllib.bat" to make sure, but no different.
Thanks for your kind help.
Programmer Never Surrender
Do you have installed only a single version of HMG?
Agil Abdullah
Recently, around 17-oct-2014, I installed HMG330. In my mind, I just want to put collections of HMG in my laptop. If this the case, should I reinstall HMG331? I am ready to do so.
Not necessary. You have to verify whether your build.bat/IDE is pointing to hmg.3.3.1 folder, since you have copied these libraries in that folder.
This is cool, congratulations Friend !!!
Agil Abdullah wrote:I am very sorry to [once more time] report Build Error. I followed your guide (as seen on screenshoot of my folder) but error remained the same. I run also "buildalllib.bat" to make sure, but no different.
Sorry I have the same error, now copy the files and apply "BuiltAllLib" and gives me error. the same Agil
I am facing no problem to compile
Step taken by me
1. Copy all the lib file *.a to hmg\lib [overwrite if old exist]
2. from command line enter c:\hmg\build xact xact.hbc
Done
Suggest to add Import data from excel
with option to overwrite data for existing date / append data
In that case, you can add the source code of hmgsqlite library. :)
hmgsqlite.zip
(2.18 KiB) Downloaded 361 times
