HMG IDE 2.8.6a
Re: HMG IDE 2.8.6a
Ok, I've attached trivial sample for testing.
If you compile this, you will get an error.
If you change line 13 in test_grid.fmg to:
VALUE {1,1}
everything will be OK.
Marek
test_grid.zip
(1.56 KiB) Downloaded 303 times
Re: HMG IDE 2.8.6a
mol wrote:Ok, I've attached trivial sample for testing.
VALUE {1,1}
Marek
Hi Marek
VALUE is 1 in .fmg and IDE and no problem got while building and running.
Does your HMG ( not IDE ) may be any of older version ?
Re: HMG IDE 2.8.6a
my IDE is 2.8.6A
The newest, I think...
Re: HMG IDE 2.8.6a
I found, that I have hmg 2.8.5 on computer on which I made this test.
(I'm working on threee different computers, and sometimes it's difficult to keep all programs in the same versions...)
Maybe that's the problem...
Re: HMG IDE 2.8.6a
Yes - I've installed hmg 28.6 and grid works fine.
But I'm still thinking that spinner for defining value of grid must be changes to textbox...
Best regards, Marek
Re: HMG IDE 2.8.6a
mol wrote: But I'm still thinking that spinner for defining value of grid must be changes to textbox...
Don't worry about it; it was already confirmed by Roberto.
Re: HMG IDE 2.8.6a
mol wrote: (I'm working on threee different computers, and sometimes it's difficult to keep all programs in the same versions...)
This is bothers of richness :)
Re: HMG IDE 2.8.6a
Wow!!! :)
I'll fix IDE ASAP!
