Is this a bug ?
Re: Is this a bug ?
esgici wrote: So I can say only : "Yes sir, you have already told me !"
Re: Is this a bug ?
You could make your original sample to work also making this change to _SetValue() function in h_controlmisc.prg HMG library code (you should replace the 'case T == "GRID"' section with the following):
	case T == "GRID"
		IF _HMG_SYSDATA [32] [ix] == .F.
			ListView_SetCursel ( c, value )
			ListView_EnsureVisible( C , VALUE )
			IF VALTYPE ( VALUE ) == 'A'
				IF VALUE [1] == 0 .OR. VALUE [2] == 0
					_HMG_SYSDATA [ 39 ] [ix] := 0
					_HMG_SYSDATA [ 15 ] [ix] := 0
					REDRAWWINDOW(C)
					_DoControlEventProcedure ( _HMG_SYSDATA [ 12 ] [ix] , ix )
					IF	_HMG_SYSDATA [ 39 ] [ix] <> value [1]	;
						.OR.					;
						_HMG_SYSDATA [ 15 ] [ix] <> value [2]
						ListView_SetCursel ( c, value [1] )
						ListView_EnsureVisible( C , VALUE [1] )
						_HMG_SYSDATA [ 39 ] [ix] := value [1]
						_HMG_SYSDATA [ 15 ] [ix] := value [2]
Basically, it allows the execution of the OnCgange procedure only if some of the cell coordinates are different from previous value.
Re: Is this a bug ?
Thanks for the explanations and suggestions.
This is my long term doubt. When we change the value of a control through "form.control.value := x" statement, whether on change event would be fired or not? Whether it is fired only when an user changes the value of the control manually?
Re: Is this a bug ?
Thanks for the explanation.
I faced the same problem in my initial project One-to-Many form :)
Re: Is this a bug ?
rathinagiri wrote:Thanks for the explanations and suggestions.
Well...
When started HMG, 'OnChange' event behavior was completely inherited from WIN32.
This meant, that when the content of a control changes, the operating system sends a message that is 'picked up' by MiniGUI library that executes the procedure specified as 'OnChange' event.
When a report pointed that programmatic changes do not fired OnChange event procedure for a specific control, I've fixed that, since IMHO this is the reasonable and 'logical' behavior (Look at 2.6.2 changelog).
Anyway, these fixes, are difficult decisions to make, because, since this behavior comes from the HMG beginnings, they could break lots of already written (working) applications.
In fact, 2.6.2 fix, caused HMG print preview to fail (it was corrected on 2.6.5).
Re: Is this a bug ?
Oh. In my programmes, I had always called for the onchange procedure again, whenever I change the value of the control programmatic.
So, I need not do so, in future. That's nice. Thank you Roberto.
Re: Is this a bug ?
rathinagiri wrote:So, I need not do so, in future. That's nice. Thank you Roberto.
Please, if you find a control that not work so, report the problem.
Re: Is this a bug ?
Hi Roberto
Roberto Lopez wrote:You could make your original sample to work also making this change to _SetValue() function in h_controlmisc.prg HMG library code
I applied, but sorry, can't run :(
HMG wrote:Error BASE/1003 Variable does not exist: VALUE
Called from _GETVALUE(253)
Called from GETPROPERTY(6775)
Called from (b)MAIN(107)
Called from _DOCONTROLEVENTPROCEDURE(4675)
Called from EVENTS(1407)
Called from SETSPINNERVALUE(0)
Called from _DEFINESPINNER(165)
Called from MAIN(109)
Best Regards
Re: Is this a bug ?
esgici wrote:Hi Roberto
Best Regards
I've took the code posted from my own h_controlmisc.prg (it is working for me). Perhaps you missed something...
Anyway, I've attached the entire file to this message.
h_controlmisc.rar
(28.98 KiB) Downloaded 818 times
Re: Is this a bug ?
Roberto Lopez wrote: ... Perhaps you missed something...
Yeah ! That's all ! :lol:
My defendant test prg now acquited :D
Un gran abrazo Roberto :)
Best Regards
