HMG 3.3.1 (Stable)
Amarante
Re: HMG 3.3.1 (Stable)
Post by Amarante »
tonton2 wrote:Bonsoir à toute l'équipe
dans le HMG.3.3.0 tout fonctionne bien ,mais dans le HMG.3.3.1 il me donne cette série d'erreurs au moment de la compilation.
Google traduction
in HMG.3.3.0 everything works fine, but in the HMG.3.3.1 it gives me this series of errors at compile time.
Bonne Soirée
I also found the same error :? :shock: :o :( :roll:
Try compiling sqlite sample in:
SAMPLES\HFCL\SQL\SQLITE
Google traduction
Bonne Soirée
In hmg.hbc change the line 'libs=sqlite3' to '# libs=sqlite3'.
I will upload a new version.
Pablo César wrote:Thank you Rathi/Claudio for this new version.
Rathinagiri wrote:    - HMG IDE
      - Fixed when not found the text editor calls notepad.exe of windows (reporte by Roberto Lopez)
At my first running of this new IDE release, did not found my Notepad++ as my preferred codes editor, in place came up Windows's Notepad. I understand IDE should searchs at REGISTRY in order to know which is the app for PRG files. (source required)
My Notepad++ was installed and registered at my PC. Why did not recognized it ?
I think Claudio could solve this. We shall include that too in this version.
Amarante
Post by Amarante »
Google traduction
Bonne Soirée
Thanks Rathi, but is already well:
libs=hbtip
# libs=sqlite3
libs=hbsqlit3
libs=sddodbc
I removed the '#' and it worked ok!!! :D
Are there side effects? :?:
thank you Rathi.
Amarante
Post by Amarante »
Rathi, I removed the '#' in hmg.hbc and it worked ok!!! :D
tonton2
Post by tonton2 »
Google traduction
Bonne Soirée
libs=hbtip
# libs=sqlite3
libs=hbsqlit3
libs=sddodbc
I did the same thing
Thanks
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Thx guys for your great work!
It seems we have no vacation in this year :-D :-D
Post by EduardoLuis »
Hi Friends Rathi & Claudio:
As i saw, you are planing to make a new upgrade, it will be usefull for everyone you uses HMG_PDF, to include on next upgrade, a solution developed by Pablo Cesar, that correct a bug on print justify text with TTF fonts on a rectangle are.- I know that there are not much members that include Rathi's HMG_PDF routine on their developes, but when they take in count all it's power, they will be please exploring all it's capabilities.-
This solution was published:
http://hmgforum.com/viewtopic.php?p=35144#p35144" onclick="window.open(this.href);return false;
I tested and works fine, expanding this utility generating complex forms and reports.-
With regards as allways.-
Eduardo
HMG 3.3.1 (Stable)
There is still pending the corrected _HMG_HPDF_MULTILINE_PRINT function as Eduardo said as so far already required on 16th of June (third request)... :mrgreen:
We all shall be appreciated to be included this fix soon as posible...
It seems that my messages are being lost or are not read even with proper care. :?
