Incremental Search in BROWSE
Clip2Mania
Re: Incremental Search in BROWSE
Post by Clip2Mania »
Oh, sorry I forgot. The latest version (3.3.0 32bit, patch3, ANSI)
Gracias a todos por compartir! Mol, Sr. Esguici :D
Clip2Mania
Had the weekend to find a way around it. :)
Made the Search-string public (although I don't like making a lot of variables public).
For the ones interested (Javier?), this is the code:
function main()
local aHeaders:={"Nummer","Trk","Artiest","Titel"}
local aWidths:={65,35,248,249}
local acFields:={"MUSIC->NR","MUSIC->DTR","MUSIC->ARTIEST","MUSIC->TITEL"}
local cSMsg:="Type to Search - Click on title to Change Sort Order - F2 to clear search"
public cStr:="", cVal
REQUEST DBFNSX
SET BROWSESYNC ON
SET DATE FRENCH
dbUseArea(.T.,"DBFNSX","MUSIC",.F.)
OrdSetFocus(5)
dbGoTop()
DEFINE WINDOW MainForm;
	AT 90,90;
	WIDTH 645;
	HEIGHT 403;
  TITLE "MiniBrowser";
	ON RELEASE Closedb();
	MAIN
	ON KEY F2 ACTION ResetSearch()
	DEFINE STATUSBAR
		STATUSITEM cSMsg
		CLOCK
		DATE
		STATUSITEM " " WIDTH 15 //In Windows 7, year is hidden by corner
	END STATUSBAR
@ 5,5 BROWSE br_Main;
  OF MainForm;
  WIDTH 620;
	HEIGHT 332;
	HEADERS aHeaders;
	WIDTHS aWidths;
	WORKAREA MUSIC;
	FIELDS acFields;
	ON HEADCLICK { {||Resort(5)} , {||MsgInfo('No Sort Key')} , {||Resort(1)},{||Resort(2)}};
	JUSTIFY { BROWSE_JTFY_LEFT,BROWSE_JTFY_RIGHT,BROWSE_JTFY_LEFT,BROWSE_JTFY_LEFT}
CREATE EVENT PROCNAME QuickSearch() HWND MainForm.br_Main.HANDLE MSG WM_CHAR
MainForm.Center
MainForm.Activate
return NIL
function ResetSearch()
cStr:=""
MainForm.Statusbar.Item(1):=cStr
return NIL
function QuickSearch()
local ch, hWnd
ch := HMG_GetLastCharacter(@hWnd)
if asc(ch) = 8
  cStr:=if(len(cStr)>1,left(cStr,len(cStr)-1),"")
   cStr:=cStr+upper(ch)
if !DBSEEK(cStr,.T.)
  DBSKIP(-1)
HMG_CleanLastCharacter()
MainForm.br_Main.Value:=recno()
MainForm.br_Main.Setfocus
return 1
function Resort(nNum)
Ordsetfocus(nNum)
cStr:=""
Mainform.br_Main.Refresh
return Nil
function Closedb()
DBCloseAll()
Return NIL
Thanks to all who contributed!
Please attach some piece of database to allow testing it!
Gracias por compartir Clip2Mania
Clip2Mania
Here is the code & snippet of DB!
MiniBrowse.zip
(8.43 KiB) Downloaded 728 times
Clip2Mania wrote: Here is the code & snippet of DB!
Good job :arrow:
Thanks to share ;)
By the way, don't worry about PUBLICs, in HMG Lib almost everything is public !
Clip2Mania
In the code above, and also in general:
When you type a character, it is trapped by HMG_GetLastcharacter().
The following phenomenon occurs:
1) if you click in the browse, and then type a character, it is trapped.
2) if you scroll in the browse (with arrows or mouse scroll), and then type a character, the first character is not trapped by HMG_Getlastcharacter(), second one and following are.
How come? Is there a solution to this?
Thanks,
Erik
Agil Abdullah
Post by Agil Abdullah »
Hi Marek,
I tried to compiled your codes written down above, by inserting #include hmg.ch and minigui.ch before making Function Main().
But it generated errors as below:
Harbour 3.2.0dev (r1407111333)
Copyright (c) 1999-2014, http://harbour-project.org/" onclick="window.open(this.href);return false;
C:/Users/toshiba/AppData/Local/Temp/hbmk_dd8s3c.dir/inboxfind.o:inboxfind.c:(.data+0x58): undefined reference to `HB_FUN_OKNOSZYBKATABELATOWAROW_AKTUALIZUJPODGLAD'
C:/Users/toshiba/AppData/Local/Temp/hbmk_dd8s3c.dir/inboxfind.o:inboxfind.c:(.data+0x78): undefined reference to `HB_FUN_OKNOSZYBKATABELATOWAROW_ZWROCKODTOWARU'
C:/Users/toshiba/AppData/Local/Temp/hbmk_dd8s3c.dir/inboxfind.o:inboxfind.c:(.data+0x88): undefined reference to `HB_FUN_ZMIENKLUCZTOWARU'
gcc.exe C:/Users/toshiba/AppData/Local/Temp/hbmk_dd8s3c.dir/inboxfind.o C:/Users/toshiba/AppData/Local/Temp/hbmk_dd8s3c.dir/hbmk_h89g4y.o D:/hmg00/_temp.o -Wl,--nxcompat -Wl,--dynamicbase -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbmysql -lmysql -lhbtip -lhbsqlit3 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbfimage -lhbpgsql -lhbnetio -lxhb -lpng -llibhpdf -lhbvpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oinboxfind.exe -Ld:/HMG331/harbour/lib/win/mingw -Ld:/HMG331/lib
hbmk2: Error: Referenced, missing, but unknown function(s):
OKNOSZYBKATABELATOWAROW_AKTUALIZUJPODGLAD(),
OKNOSZYBKATABELATOWAROW_ZWROCKODTOWARU(), ZMIENKLUCZTOWARU()
Pls tell me how fix it. Thanks.
Programmer Never Surrender
these functions are defined in my project.
This function updates only additional informations on screen (product describe, image of product):
function OknoSzybkaTabelaTowarow_AktualizujPodglad
	OknoTabTowarow.T_DodatOpis.Value := towary->DodatOpis
	if lPodgladZdjecia
		cOkno := "OknoTabTowarow"
		if IsControlDefined(IM_ZdjecieTowaru, OknoTabTowarow)
			if file(cFolderZdjecTowarow+"T"+towary->towar+".jpg")
				SetProperty(cOkno,"IM_ZdjecieTowaru","Picture",cFolderZdjecTowarow+"T"+towary->towar+".jpg")
			elseif file(cFolderZdjecTowarow+"T"+towary->towar+"_1.jpg")
				SetProperty(cOkno,"IM_ZdjecieTowaru","Picture",cFolderZdjecTowarow+"T"+towary->towar+"_1.jpg")
				SetProperty(cOkno,"IM_ZdjecieTowaru","Picture",'RC_BRAKZDJECIA')
return
second:
function OknoSzybkaTabelaTowarow_ZwrocKodTowaru
	local StObsBledu
	local lKontynuacja := .t.
	ZwrotnyTowar := OknoTabTowarow.B_Towary.Value
	towary->(DBGoTo(ZwrotnyTowar))
	if !empty(cFunkcjaZapisuPozycji)
		lKontynuacja := &cFunkcjaZapisuPozycji
	if !lKontynuacja
		OknoTabTowarow.Release
		OknoTabTowarow.T_Wyszukaj.Value := ""
		//OknoTabTowarow.SetFocus
 return
you can see macro calling: &cFunkcjaZapisuPozycji
It realize special action after selecting item, you can set it by cFunkcjaZapisuPozycji := ""
And the last changes index:
function ZmienKluczTowaru
	param NrKlucza
	DbSetOrder(NrKlucza)
	SetProperty(ThisWindow.Name, "B_Towary","Value" ,towary->(recno()) )
	DoMethod(ThisWindow.name, "B_Towary","Refresh")
 	DoMethod(ThisWindow.name, "T_Wyszukaj","SetFocus")
 return .t.
I'm afraid you will find it hard to implement. But try!
