Ftp @ in username problem
Re: Ftp @ in username problem
Hi :
Firefox creates a transaction with the FTP server, it responds with a LOGIN
when trying to enter the username and password responds with a 503 error logging
error 503.jpg (31.42 KiB) Viewed 5373 times
No error Harbour as Firefox or any other browser is the same.
did tell me how to create the new account; but where registration requests to that server know your requirements and Connection
hynan
Post by hynan »
Hi
And sorry, the GOODACCOUNTNAME and NOTGOODACCOUNTNAME was only ment to make a statement
ftp://Eldemo@johnsjn22.twentytwo.axc.nl ... two.axc.nl
working in Chrome 34.0.1847.137 m
not working in IE 11
( can someone please confirm ? )
so also some browsers have problem with the @ i think
attach screenshot ftp
as you can see very simple,
only thing is,
@johnsjn22.twentytwo.axc.nl is forced as part of the username
Thanks and greetings...
hynan
Post by hynan »
Hi all,
I still think the
/* Comprobamos si el usuario contiene una @ para forzar el userid */
IF At( "@", cUser ) > 0
oFTP:oUrl:cServer := cServer
oFTP:oUrl:cUserID := cUser
oFTP:oUrl:cPassword := cPassword
is a bug in the above code .OR. in the tipclient source ?
The code is in several samples in the contrib dir and seen some times in this forum,
is there anyway a solution for the future ?
(i wish i could do myself, but i am just beginner) :D
Otherwise i must forget it...
Thanks and Greetings...
Demo Code FTPclient.prg
#include 'hmg.ch'
#define DISABLE 0
#define ENABLE 1
#define CRLF INetCRLF()
#require "hbtip"
REQUEST __HBEXTERN__HBSSL__
REQUEST HB_GT_WIN_DEFAULT
Public cUSER := ""
Public cSERVER := ""
Public cPASSWORD := ""
Public aFiles
Public cUrl
Public cStr
Public lRetVal := .T.
Public oUrl
Public oFTP
Public cFile := ""
Public lTrace := .T.
SET MULTIPLE OFF
SET NAVIGATION EXTENDED
SETMODE( 25, 80 )
* Send an file or list of files to ftp server
cServer := "ftp://johnsjn22.twentytwo.axc.nl"
cUser := "Eldemo@johnsjn22.twentytwo.axc.nl"
cPassword := "12345"
* An URL:
* http://gian:passwd@www.niccolai.ws/mypa ... =0&avar1=1" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
* cProto UID PWD cServer cPath cQuery
* cDirectory cFile
* cFname cExt
cUrl := cServer
oUrl := TUrl():New( cUrl )
oFTP := TIPClientFTP():New( oUrl, .T. )
oFTP:nConnTimeout := 20000
oFTP:bUsePasv := .F.
IF oFTP:Open( cUrl )
aFiles := Directory( "SelectAFile\*.*" )
IF Len( aFiles ) > 0
FOR EACH cFile IN afiles
? "Filename: " + cFile[ F_NAME ]
IF ! oFtp:UploadFile( cFile[ F_NAME ] )
lRetVal := .F.
EXIT
lRetVal := .T.
oFTP:Close()
MsgBox( "Could not connect to FTP server " , oURL:cServer )
IF oFTP:SocketCon == NIL
cStr += hb_eol() + "Connection not initialized"
ELSEIF hb_inetErrorCode( oFTP:SocketCon ) == 0
cStr += hb_eol() + "Server response:" + " " + oFTP:cReply
cStr += hb_eol() + "Error in connection:" + " " + hb_inetErrorDesc( oFTP:SocketCon )
? cStr
lRetVal := .F.
/* Leemos ficheros a enviar */
RETURN lRetVal
No es un Bug dentro de la libreria HBTIP.
sucede que es un error de sitio que asume como nombre de usuario
normalmente esa URL se decompone de esta manera.
posiblemente Google Web Browse busca : para decomponer
Translate Google
Not a Bug HBTIP within the library.
happens to be a site that takes error as username
URL that usually decomposes in this way.
* An URL:
* cDirectory cFile
* cFname cExt
Browse possibly Google Web searching ":" to decompose
See : C:\harbour\contrib\hbtip\url.prg
and FTPClient HBTIP library
METHOD New( oUrl, xTrace, oCredentials ) CLASS TIPClientFTP
   ::super:new( oUrl, iif( HB_ISLOGICAL( xTrace ) .AND. xTrace, "ftp", xTrace ), oCredentials )
   ::nDefaultPort := 21
   ::nConnTimeout := 3000
   ::bUsePasv     := .T.
   ::nAccessMode  := TIP_RW  // a read-write protocol
   ::nDefaultSndBuffSize := 65536
   ::nDefaultRcvBuffSize := 65536
   // precompilation of regex for better prestations
   ::RegBytes := hb_regexComp( "\(([0-9]+)[ )a-zA-Z]" )
   ::RegPasv :=  hb_regexComp( "([0-9]*) *, *([0-9]*) *, *([0-9]*) *, *([0-9]*) *, *([0-9]*) *, *([0-9]*)" )
   RETURN Self
METHOD Open( cUrl ) CLASS TIPClientFTP
   IF HB_ISSTRING( cUrl )
      ::oUrl := TUrl():New( cUrl )
   IF Len( ::oUrl:cUserid ) == 0 .OR. Len( ::oUrl:cPassword ) == 0
      RETURN .F.
   IF ! ::super:Open()
      RETURN .F.
   IF ::GetReply()
      ::inetSendAll( ::SocketCon, "USER " + ::oUrl:cUserid + ::cCRLF )
      IF ::GetReply()
         ::inetSendAll( ::SocketCon, "PASS " + ::oUrl:cPassword + ::cCRLF )
         // set binary by default
         IF ::GetReply() .AND. ::TypeI()
            RETURN .T.
   RETURN .F.
is logical and correct treatment of the URL within the library.
a modification to that library to make it compatible with URL like this.
hynan
Post by hynan »
Hi all,
First, thank you ver much for your work and time ;)
Get error when building,
using the default build.bat from HMG
Or is it need to build new library ?
( i have no idea how to do :oops: )
Harbour 3.2.0dev (r1312060701)
Copyright (c) 1999-2013, http://harbour-project.org/" onclick="window.open(this.href);return false;
main.prg(76) Error E0030 Syntax error "syntax error at 'NEW'"
main.prg(93) Error E0030 Syntax error "syntax error at 'OPEN'"
2 errors
No code generated.
hbmk2[main]: Error: Running Harbour compiler (embedded). 1
(v:\hmg\harbour\bin\harbour.exe) -n2 main.prg ftp.prg -DHBMK_HAS_HMG=1 -q -oC:\Users\HP\AppData\Local\Temp\hbmk_6q0j5m.dir\ -iv:\hmg\harbour\include -i. -iv:\hmg\include
Complete code:
#include 'hmg.ch'
#define DISABLE 0
#define ENABLE 1
#require "hbtip"
Public cUSER := ""
Public aFiles
Public cUrl
Public cStr
Public oUrl
Public oFTP
Public cFile := ""
SET MULTIPLE OFF
SETMODE( 25, 80 )
cUrl := cServer
lRetVal := .F.
EXIT
lRetVal := .T.
oFTP:Close()
? cStr
lRetVal := .F.
RETURN lRetVal
::bUsePasv := .T.
RETURN Self
RETURN .F.
IF ! ::super:Open()
RETURN .F.
IF ::GetReply()
IF ::GetReply()
RETURN .T.
RETURN .F.
hynan
Post by hynan »
Hi all,
Can somebody please confirm the syntax error
ik also did install 3.3.0 to be sure,
version.txt gives 3.3.0
build.log gives 3.2.0
Harbour 3.2.0dev (r1405061532)
Copyright (c) 1999-2014, http://harbour-project.org/" onclick="window.open(this.href);return false;
2 errors
No code generated.
(v:\hmg\harbour\bin\harbour.exe) -n2 main.prg -DHBMK_HAS_HMG=1 -q -oC:\Users\HP\AppData\Local\Temp\hbmk_udu5t0.dir\ -iv:\hmg\harbour\include -i. -iv:\hmg\include
Hello Hynan:
these new methods need to have the upper class,
CREATE CLASS TIPClient
   METHOD Open( cUrl )
ENDCLASS
ENDCLASS
ENDCLASS
CREATE CLASS TIPClientFTP FROM TIPClient
   METHOD Open( cUrl )
   METHOD New2( oUrl, xTrace, oCredentials )    // You method
   METHOD Open2( cUrl )                                 // You method
ENDCLASS
METHOD Open2( cUrl ) CLASS TIPClientFTP
RETURN .F.
METHOD New2( oUrl, xTrace, oCredentials ) CLASS TIPClientFTP
RETURN .F.
compile Lib
