Transform CodeBlocks in strings
Harbour, MingW related news.
Re: Transform CodeBlocks in strings
srvet_claudio wrote: Thanks for the info.
Thanks to interest and like, Claudio :oops:
Another quotation about code block de-serialization:
Code block deserialize
code block deserialize.JPG (24.4 KiB) Viewed 32596 times
IMO de/serialization isn't simply a de/crypt method and is a high level subject that far for ordinary / casual programmers like me ;)
Viva HMG :D
Rick Spence, I like much his articles. Thank you Esgici for your indications and material arrangement. I read all and I have no problem with CodeBlocks except how I get what the CodeBlock has contained and I wish in string type. I will try to explain a little bit more with samples.
We have this demo, which is an almost perfect example or at least simulates what we now have as IDE. Where the actions are being inputed by users, stored into a string variable and passed to the text file (FMG file created by the IDE):
Function Main()
LOCAL cBlock, bBlock
SET WINDOW MAIN OFF
cBlock:=InputBox("Confirm your ACTION (function):","Define your action","MsgInfo('Action test')")
SET WINDOW MAIN ON
bBlock:={||MemVarBlock(cBlock)}
MsgDebugTitle("Types of variables") ; MsgDebug(' cBlock type = ( '+ValType(cBlock)+' ) ',' bBlock type = ( '+ValType(bBlock)+' ) ')
MsgDebugTitle("Content of variables") ; MsgDebug( cBlock, bBlock )
EVAL(bBlock)
On the other hand, we have the inverse situation of creating FMG file by IDE. Where we already have a PRG made by the user and we want to transform what is being executed (in memory running) into standard FMG text file.
Function Main()
bBlock:={||MsgInfo('Action test')}
cBlock := hb_ValToExp( bBlock ) // I want this: "MsgInfo('Action test')", but seems in Harbour there is no way...
EVAL(bBlock)
What would be the difference between these examples ?
I need to get the function or the (nested) functions that are inside {|| ...} (what's in red color)
How to get cBlock with full information (not just "...") :?:
This is the big question. If I have FMG file, I could read directly from the file, because is a text file.
Regarding this:
I believe that in my case with Prg2Fmg project, the compiler would have it because Prg2Fmg will only works by re-building the application with the user app. So Harbour, will have all the functions defined as ACTIONs. Otherwise, user's app would not be compiled with some error in their codes.
So in this case CodeBlock deserialize will never contradict the mandatory for Prg2Fmg because always will running and compiling at same time.
Claudio, could you tell me if it is possible to read (perhaps in the C language) the contents of a temporary variable and replace "{||" And "}" by quotes ? Or let say to replace "{" by "[" and "}" by "]" ? Which it would transform block for string ?
It is not possible because Harbour when create the CB transforms in pcode and refers to the local symbol table, would be necessary reverse engineering.
I've Understood. I read about it, but I did not think it would turn the cb into P-Code at the same time.
I was dreaming with hb_struBlock and hb_execFromArray...
Thank you Claudio
One POV:
However, if HMG would it may store these CodeBlocks that are currently stored as type "B" (Block) and instead would store as type "C" (character) in _HMG_SYSDATA structure, It would provide that same information with the same result. Of course to treat it at the time of execution will need to transform from string to block type. ;)
Pablo César wrote: One POV:
This is not as simple as it sounds when cb strings contain local variables. This is the same problem that happens with macrosubstitution with local variables. The cb was create to overcome the limitations of the macrostitution.
Ahh yes, I read about LOCAL and STATIC variables is not visible at macrosubstitution... :|
Do you believe Claudio that I could overwrite HMG instructions by an own include file and make all actions be converted in string instead a block when compiled with Prg2Fmg ?
I saw in HMG like as:
#xcommand ACTION <action> => _HMG_SYSDATA \[ 419 \] := <{action}>
probably by removing "{}" ?
Pablo César wrote:Ahh yes, I read about LOCAL and STATIC variables is not visible at macrosubstitution... :|
No, this can cause many problems with local variables and it does not make sense to do so.
Let me explain to you...
The usage of Prg2Fmg, will be only with the propose to create a non existing fmg file of user app. And the only way to use it is to compile Prg2Fmg together just for fmg files creation. Prg2Fmg do not need to execute any action like as OnChange... OnClick... so on...
After user usage, they will re-compile and back again what their normal app behaviour.
Por tu silencio Claudio, creo que no me llegaste a entender o no te interesó más mi ultima propuesta. Acabo de probarlo y parece funcionar perfectamente para atender a mi objetivo. Pero antes de decir que no haberá problemas, iré chequear los ejemplos. La propuesta, no es para cambiar nada en HMG, sinó que voy a poder convertir las ACTIONs en strings sobreponiendo las directivas, solo para un propósito: generar archivo FMG.
Después lo muestro con la próxima version de Prg2Fmg.
Ok, no problem.
