HFCL-ComboSearchBox- BugFix & New Features
Re: HFCL-ComboSearchBox- BugFix & New Features
Hi Rathinagiri,
tonton2 wrote:Hello everyone,
after several attempts, the above example still gives me errors, while the old version works well
Great thank you all for your work
The error thrown is:
Harbour 3.2.0dev (r1312060701)
Copyright (c) 1999-2013, http://harbour-project.org/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
C:\hmg.3.2\Mios\ComboSearchBoxNuevo\mainNuevo.prg(51) Error E0030 Syntax error "syntax error at '.T.'"
C:\hmg.3.2\Mios\ComboSearchBoxNuevo\mainNuevo.prg(52) Error E0030 Syntax error "syntax error at '50'"
C:\hmg.3.2\Mios\ComboSearchBoxNuevo\mainNuevo.prg(53) Error E0030 Syntax error "syntax error at '0'"
3 errors
I mention what I did, maybe it's where I'm wrong:
1 - Copy all the files you uploaded to the folder:
     C: \ HMG.3.2 \ HFCL \ DOC
     C: \ HMG.3.2 \ HFCL \ Include
     C: \ HMG.3.2 \ HFCL \ Samples
     C: \ HMG.3.2 \ HFCL \ Source
2 - And compile the example you uploaded in this Post.
3.- Please update and re-build the library.
There is something extra that needs to be done ? or not the files you uploaded is copied there?
Many thanks in advance!
tonton2
Post by tonton2 »
Bonsoir,
it is this process that I did
"1 - I Copied all the files in the C: \ HMG.3.2 \ HFCL
- C: \ HMG.3.2 \ HFCL \ DOC
- C: \ HMG.3.2 \ HFCL \ Include
- C: \ HMG.3.2 \ HFCL \ Samples
- C: \ HMG.3.2 \ HFCL \ Source
2.- I updated and re-build the library.
3 -then I compiled this example
thank you and good continuation to you all
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Yes, you have to rebuild the library using the build.bat after updating the patch.
tonton2
Post by tonton2 »
Rathinagiri wrote:Yes, you have to rebuild the library using the build.bat after updating the patch.
Bonjour,
I dont undestand,but why this new COMBOSEARCHBOX doesn't work?
thanks
Y.TABET
Please copy this file to hmg.3.2\lib folder.
libhfcl.zip
(76.81 KiB) Downloaded 327 times
tonton2
Post by tonton2 »
Good evening everyone
it does not work yet.
here are the errors it gives when compiling
C:\HMG.3.2\hfcl\Samples\ComboSearchBox\main.prg(51) Error E0030 Syntax error "syntax error at '.T.'"
C:\HMG.3.2\hfcl\Samples\ComboSearchBox\main.prg(52) Error E0030 Syntax error "syntax error at '50'"
C:\HMG.3.2\hfcl\Samples\ComboSearchBox\main.prg(53) Error E0030 Syntax error "syntax error at '0'"
3 errors
No code generated.
hbmk2: Error: Running Harbour compiler (embedded). 1
(C:\HMG.3.2\harbour\bin\harbour.exe) -n2 C:\HMG.3.2\hfcl\Samples\ComboSearchBox\main.prg -DHBMK_HAS_HMG=1 -q -oC:\Users\youcef\AppData\Local\Temp\hbmk_vksv8v.dir\ -iC:\HMG.3.2\harbour\include -i. -iC:\HMG.3.2\include
Please tell me , the version of HMG is 3.2 without patch ?
Y.TABET
tonton2 wrote:Good evening everyone
3 errors
No code generated.
+1 :(
Sorry friends.
Please also copy hfcl_combosearchbox.ch file from hfcl\include to hmg.3.2\include.
tonton2
Post by tonton2 »
Rathinagiri wrote:Sorry friends.
It works very well.
Thank you very much for your cooperation. :D
Y.TABET
Thanks Rathinagiri, works great, congratulations! :D :D :D
