Dirección MAC
Re: Dirección MAC
Hola a todos
se agrego al grid la direccion IPv4 e IPv6 de la placa de red conectada a internet que suministra el proveedor o direccion interna dada por el servidor DHCP local.
el GRID muestra las placas de red físicas disponibles
se elimino codigo redundante
se necesita limpiar un poco el codigo fuente eliminando las variables no usadas.
Translate Google
Hello everyone
grid is added to the IPv4 and IPv6 address of the network card connected to Internet provider that provides or internal direction given by the local DHCP server.
GRID displays the physical network plates available
redundant code was removed
needs to be cleaned a bit the source code by removing unused variables.
2014-01-30 22_12_00-AdapterInfo().jpg (44.77 KiB) Viewed 4779 times
AdapterInfo.rar
(7.27 KiB) Downloaded 336 times
Re: Dirección MAC
Enjoy
AdapterInfo 3.rar
Clean source code
(13.19 KiB) Downloaded 375 times
Re: Dirección MAC
Hola a todos
Tomando el ejemplo posteado por Maximiliano pude lograr esta Función espero les sirva:
(Aclaro que solo lo he probado en mi PC)
Hello everyone
Taking the example posted by Maximilian I could achieve this function hope they serve:
(I must say that I have only tried on my PC)
FUNCTION SysInvent()   //  By AndyGlezL
	LOCAL obj, cpu, nInd, obj1, obj2
	WaitWindow( "Espere, Leyendo...", .T. )
	oLocator := win_oleCreateObject( "wbemScripting.SwbemLocator" )
	oWmi     := oLocator:ConnectServer()
	data1:=""
	oCollection:= oWMI:ExecQuery("Select * from Win32_ComputerSystem")
	For Each obj In oCollection
		Name  := 'Computer: '+CHR(9)+obj:Name
		PhysicalMemory := 'PhysicalMemory: '  + CHR(9) + STR( ( VAL( obj:TotalPhysicalMemory) / 1000000 ) / 1024 ) + " GB."
		cNumProcs      := "# of Processors: " + CHR(9) + STR( obj:NumberOfProcessors )
		data1 += Name+CRLF+cNumProcs+CRLF+PhysicalMemory
	Next
	data2:=""
	oCollection := oWMI:ExecQuery("Select * from Win32_OperatingSystem")
		Caption    := 'OS: '           + CHR(9) + obj:Caption + CRLF
		ServPack   := 'Service Pack: ' + CHR(9) + STR( obj:ServicePackMajorVersion ) + CRLF
		cVersion   := "Version:      " + CHR(9) + obj:Version + CRLF
		FreePhysMem:= 'FreePhysMemory: '+CHR(9) + STR( ( VAL( obj:FreePhysicalMemory ) / 1000 ) / 1024 ) + " GB." + CRLF
		cWinDir    := "Win Directory:" + CHR(9) + obj:WindowsDirectory
		data2 += Caption+ServPack+cVersion+FreePhysMem+cWinDir
	Next
	data3:=""
	oCollection := oWMI:ExecQuery( 'select * from Win32_ComputerSystemProduct' )
		Vendor := 'Manufacturer: '+CHR(9)+obj:Vendor
		Name   := 'MotherBoard: '+CHR(9)+obj:Name
		IdentifyingNumber := 'Id. Number: '+CHR(9)+obj:IdentifyingNumber
		data3 += Vendor+CRLF+Name+CRLF+IdentifyingNumber
	Next
	data4 := ""
	nInd  := 0
	oCollection := oWMI:ExecQuery("Select * from Win32_DiskDrive")
		nInd++
		Model         := 'Disc Model'+ALLTRIM(STR(nInd))+': '+CHR(9)+obj:Model+CRLF
		*SerialNumber := 'SerialNumber: '+obj:SerialNumber                   // ERROR !   ?????
		InterfaceType := '   Interface'+ALLTRIM(STR(nInd))+': '+CHR(9)+obj:InterfaceType+CRLF
		Size          := '   Disc.Size'+ALLTRIM(STR(nInd))+': '+CHR(9)+STR( ( VAL( obj:Size ) / 1000000 ) / 1024 )+" GB."+CRLF
		Partitions    := '   Partitions'+ALLTRIM(STR(nInd))+': '+CHR(9)+STR( obj:Partitions )+CRLF
		data4 += Model+InterfaceType+Size+Partitions
	Next
	data5 := ""
	oCollection := oWMI:ExecQuery( 'select * from Win32_Processor' )
	For Each cpu In oCollection
		*DeviceID      := 'DeviceID: '+CHR(9)+cpu:DeviceID+CRLF
		*Availability  := 'Availability: '+CHR(9)+STR( cpu:Availability )+CRLF
		AddressWidth  := 'AddressWidth: '+CHR(9)+STR( cpu:AddressWidth )+CRLF
		*CpuStatus     := 'CpuStatus: '+CHR(9)+STR( cpu:CpuStatus )+CRLF
		CurClockSpeed := 'ClockSpeed: '+CHR(9)+STR( cpu:CurrentClockSpeed )+CRLF
		*MaxClockSpeed := 'MaxClockSpeed: '+CHR(9)+STR( cpu:MaxClockSpeed )+CRLF
		L2CacheSize   := 'L2CacheSize: '+CHR(9)+STR( cpu:L2CacheSize )+CRLF
		L2CacheSpeed  := 'L2CacheSpeed: '+CHR(9)+STR( cpu:L2CacheSpeed )+CRLF
		Name          := 'Name: '+ALLTRIM(cpu:Name)
		*data5 += DeviceID+Availability+AddressWidth+CpuStatus+CurClockSpeed+MaxClockSpeed+L2CacheSize+L2CacheSpeed+Name
		data5 += AddressWidth+CurClockSpeed+L2CacheSize+L2CacheSpeed+Name
	Next
	data6 := ""
	nInd  := 0
	aNetConnectStat := { 'Disconnected', 'Connecting', 'Connected', 'Disconnecting', 'Hardware not present', 'Hardware disabled', 'Hardware malfunction', ;
						 'Media disconnected', 'Authenticating', 'Authentication succeeded', 'Authentication failed', 'Invalid address', 'Credentials required' }
	oCollection1 := oWMI:ExecQuery( "SELECT * FROM Win32_NetworkAdapter WHERE Manufacturer != 'Microsoft' AND NOT PNPDeviceID LIKE 'ROOT\\%'" )
	oCollection2 := oWMI:ExecQuery( 'SELECT * from Win32_NetworkAdapterConfiguration where IPEnabled=TRUE' )
	For Each obj1 In oCollection1
		nTemp := obj1:NetConnectionStatus
		For Each obj2 In oCollection2
			nInd++
			cDescrip := 'Description'+ALLTRIM(STR(nInd))+': '+CHR(9)+SUBSTR( obj2:description, 1, AT( "-", obj2:description ) -2 )+' / '+aNetConnectStat[ nTemp+1 ]+CRLF
			ServiceName := '   ServiceName'+ALLTRIM(STR(nInd))+': '+CHR(9)+obj2:ServiceName(0)+CRLF
			IPAddress   := '   IPAddress'+ALLTRIM(STR(nInd))+': '+CHR(9)+obj2:IPAddress(0)+CRLF
			*DefaultIPGateway := 'DefaultIPGateway: '+obj:DefaultIPGateway(0) 		// ERROR !   ????
			MACAddress  := '   MACAddress'+ALLTRIM(STR(nInd))+': '+CHR(9)+obj2:MACAddress(0)
			data6 += cDescrip+ServiceName+IPAddress+MACAddress+CRLF
		Next
	Next
	oCollection := 0
	oWMI := 0
	WaitWindow( )
	MsgInfo(data1+CRLF+ ; // REPLICATE( "-", 80 )+CRLF+ ;
			data2+CRLF+REPLICATE( "-", 80 )+CRLF+ ;
			data3+CRLF+REPLICATE( "-", 80 )+CRLF+ ;
			data4+CRLF+REPLICATE( "-", 80 )+CRLF+ ;
			data5+CRLF+REPLICATE( "-", 80 )+CRLF+ ;
			data6, 'System Inventory - By AndyGlezL' )
RETURN nil
Re: Dirección MAC
Muy bueno Andrés !!!!
Slds
Re: Dirección MAC
Excelente Andres!
edufloriv
Re: Dirección MAC
Post by edufloriv »
Que genial !! gracias por su tiempo amigos y por compartir.
Eduardo Flores Rivas
LIMA - PERU
