ErrorIMATECH wrote:Hi Esgici !
Adjusted ( but not tested ! )
Unicode and HMG_HPDF
Re: Unicode and HMG_HPDF
- err.JPG (11.31 KiB) Viewed 22393 times
I tested :IMATECH wrote: Adjusted ( but not tested ! )
Two REQUEST moved to before Main()
hb_gtsys() moved to after Main()
PROCEDURE() ( and its RETURN ) lines commented;
and the result ( same as Dave's ) :
Error BASE/1302 Argument error: HB_TRANSLATE
Called from HB_TRANSLATE(0)
Called from MAIN(24) -> SELECT HPDFDOC ( hb_Translate( cTarget...
Hi Esgici, bdp !
Adjusted
and
Tested ( Works ok )
Harbour uses last libHaru sources ( 2.3.0RC2 ) supporting 1~2 bytes UTF8 codes
Then HMG_hbHpdf can be updated to use these new resources
Code Template:
Adjusted
and
Tested ( Works ok )
#include "hfcl.ch"
PROCEDURE Main()
LOCAL i
LOCAL lSelPDF
LOCAL aSourceText
LOCAL cSourceFileName
LOCAL cTargetFileName
hb_langSelect( 'es' )
hb_cdpSelect( "UTF8EX" )
cSourceFileName := "espãnol.txt"
aSourceText := hb_aTokens( hb_Translate( HB_MEMOREAD( cSourceFileName ), 'UTF8EX', 'ESISO' ), CHR(10) )
cTargetFileName := STRTRAN( cSourceFileName, "txt", "pdf" )
SELECT HPDFDOC ( hb_Translate( cTargetFileName, 'UTF8EX', 'ESISO' ) ) TO lSelPDF
IF lSelPDF
_HMG_HPDF_SetEncoding( "WinAnsiEncoding" )
START HPDFDOC
START HPDFPAGE
FOR i := 1 TO Len( aSourceText )
@ ( i * 4 )+15, 20 HPDFPRINT aSourceText[ i ]
END HPDFPAGE
END HPDFDOC
IF FILE( cTargetFileName )
MsgInfo( "PDF Builded as " + cTargetFileName )
MsgStop( "PDF Building Unsuccessful", "Unexpected ERROR !" )
ENDIF lSelPDF
// hb_gtsys()
PROCEDURE hb_gtsys()
REQUEST HB_LANG_ES
REQUEST HB_CODEPAGE_ESISO
REQUEST HB_CODEPAGE_UTF8EX
libHaru 2.3.0RC2
Changed package naming, no other changes was done.
libHaru 2.3.0RC1
Added support for 3dMeasures of subtype PD3 and 3DC, projection annotations, ExData and javascript attached to a U3D model. (Robert Würfel)
Added support for 1- and 2-byte UTF8 codes. (Clayman)
Added full PDF/A1-b support. (Petr Pytelka)
Added support for CCITT compression for B/W images. (Petr Pytelka)
Add support for TwoPageLeft and TwoPageRight layouts. (Vincent Dupont)
Const-ified arrays used in the sources. (Ilkka Lehtoranta)
Fixed build with libpng 1.5.0
Fixed bug in HPDF_GetContents() - isize variable was not initialized. (Vincent Dupont)
Fixed possible endless loop in PNG handling code. (reported by Mathew Waters)
Fixed several issues based on the warnings generated by clang-analyzer. (Daniel Höpfl)
Fixed quite a number of warnings. (Davide Achilli)
Added 'd' postfix to debug build, fixed wrong filename. (Wim Dumon)
Fixed HPDF_Text_Rect() not to split words in some obscure cases.
http://libharu.org/
/* UTF8 */
HPDF_UseUTFEncodings( oPdf )
/* Embend Font */
HPDF_LoadTTFontFromFile( oPdf, "Any.ttf", .T. )
/* oPdf Font */
HPDF_GetFont( oPdf, cFontName, "UTF-8" )
M., Ronaldo
By: IMATECH
Imation Tecnologia
By: IMATECH
Imation Tecnologia
Hola Ronaldo,IMATECH wrote: Adjusted![]()
and
Tested ( Works ok )
yes; tested, works ok
Thank you very much
Two little question ( if no problem
- . español .OR. espãnol; which one is correct ? ( It cost me two hours
. how a function ( hb_gtsys ) runs without calling
Not only problem solved, but for everything increased my knowledge
As Daniel said : everybody learns something by every post !
Viva HMG
Hi Esgici !
. español .OR. espãnol ( just a wrong backspace: shit happens )
Sorry, I don't know nothing about spanish language rules
. hb_gtsys
It's a default behavior for any Harbour GT
. HPDF_UseUTFEncodings( oPdf )
After Sr.Rathinagiri just include this function to HMG_HPDF lib any language will be correct created inside pdf files ( japanese, greek, ... )
. everybody learns something by every post !
Some times by every re-edited posts too
Then my posts can be readed again and again...
. hb_gtsys
M., Ronaldo
By: IMATECH
Imation Tecnologia
By: IMATECH
Imation Tecnologia
Yes, you are right,IMATECH wrote: . HPDF_UseUTFEncodings( oPdf )
Your good news and suggestions about HaruPDF and UT8 is more important than my asked problem,
thanks a lot for this also
Hopefully forum management will take into account your guidance
Regarding re-editing posts, my humble opinion is:
forum software don't allow deleting answered posts;
this rule must apply to editing posts too, I think.
Because some people abusing it; uses posts as a scratchpad,
and will be very difficult to follow the subjects.
For example, corrects an his erroneous sentences after someone warn it
Anyway, thanks to everything and
Viva HMG
Hi quartz !
It's for you
image pdf using Arial.ttf font
It's for you
M., Ronaldo
By: IMATECH
Imation Tecnologia
By: IMATECH
Imation Tecnologia
Thank you Ronaldo,IMATECH wrote:Hi quartz !
It's for you
Add following 2 line to run above example
#define HPDF_COMP_ALL 0x0F
REQUEST HB_GT_WIN_DEFAULT
Thank you very much Ronaldo. It works perfectly!
Thanks all !
Thanks all !
- ABGD.png (4.14 KiB) Viewed 22274 times
Nikos.
os: Windows Server 2019 - 64
Nikos.
Hi !
Esgici, DanielMaximiliano, BPD and Nikos
Thanks for interest and feedback
Best regards
Best regards
M., Ronaldo
By: IMATECH
Imation Tecnologia
By: IMATECH
Imation Tecnologia
