MySql Primer
Re: MySql Primer
Hello,
I "re-initialized" my MySql journey. I am still using TMySqlServer! Tried HbSqlRdd, but decided to try it later. Meanwhile I came to know another library HBTIP from Roberto Lopez. It's harder but more secure. So, I am now working with TMySqlServer.
Today I added Add, Modify and Delete options to my MySql project. I used Insert key for Add, Dbl Click for Edit and Delete key to delete records. Very simple and basic project. Taken help from Rathi's code and some Idea from Demo_2 example.
Thank you Roberto Lopez, Rathinagiri, Grigory Filatov, Esgici (Esgici your comments always inspire me :))
Please download it.
Demo.zip
(3.51 KiB) Downloaded 460 times
Then compile and run.
And please send your advice.
Re: MySql Primer
I had gone through your code and it is neat.
A small suggestion, perhaps not regarding MySQL.
 @ 20,120 TEXTBOX txtHostName ;
         HEIGHT 25 ;
         VALUE cHostName ;
         WIDTH 120 ;
      ON ENTER iif( !Empty(frmLogon.txtHostName.Value),  frmLogon.txtUser.SetFocus, frmLogon.txtHostName.SetFocus )
      @ 50,30 LABEL lblUser ;
         VALUE "User" ;
         WIDTH 120 ;
         HEIGHT 35
      @ 50,120 TEXTBOX  txtUser ;
         HEIGHT 25 ;
         VALUE cUser ;
         WIDTH 120 ;
         ON ENTER iif( !Empty(frmLogon.txtUser.Value), frmLogon.txtPassword.SetFocus, frmLogon.txtuser.SetFocus  )
      @ 80,30 LABEL lblPassword ;
         VALUE "Password" ;
         WIDTH 120 ;
         HEIGHT 35
      @ 80,120 TEXTBOX txtPassword ;
         VALUE cPassWord ;
         PASSWORD ;
         ON ENTER frmLogon.cmdLogin.SetFocus
IMHO, you need not give Setfocus command for every control, since the natural order of tab would be in the defined order of the controls. If you want to check the value, you can use 'valid' clause.
Re: MySql Primer
rathinagiri wrote:I had gone through your code and it is neat.
Thank you Rathi for checking codes thoroughly and sending advice for improvement!!! I like it so much :)
This is the problem of Copy-Paste programming.;) I copied that part (and slightly modified) from Demo_2!!! :)
swapan
Re: MySql Primer
Post by swapan »
Great going Sudip!
Hope your this thread will be a great help for the members who want to give a try to MySQL - the free RDBMS!
Swapan
Thanks & Regards,
Swapan Das
http://www.swapandas.com/
t57042
Re: MySql Primer
Post by t57042 »
Hello Sudip,
trying to compile your code.
Get errormessage fro line : Value:=DATATOSQL(value): unknown function.
rgds
Richard
Re: MySql Primer
Richard,
It will be something like this code:
XDATUM = DTOC(XDATUM)
XDATUM = SUBSTR(XDATUM,7,4) + '-' + SUBSTR(XDATUM,4,2) + '-' + SUBSTR(XDATUM,1,2)
IF XDATUM = '    -  -  '
	XDATUM = 'NULL'
RETURN (XDATUM)
