New Forum for user functions
Re: Search string in EDITBOX
A good organization of the forum and the topics will be very much useful for the new comers and even for ourselves to find the pin in the hay stock.
For example, the first of post of any topic should be reserved for the latest code/function.
Also, if some of the volunteers from the members come forward, we can make them as moderators. They can move topics to the required places and edit them (if required). This they can do whenever they come across the functions useful to all. After some pooling, we can add them into HFCL library.
rathinagiri wrote:A good organization of the forum and the topics will be very much useful for the new comers and even for ourselves to find the pin in the hay stock.
Is cool 8-)
At least to start without making major changes.
Is a simple and humble idea: to create a topic where every post contains a short description of the function and a link to the post where's the source code referred (without duplicating the code or the post, only links).
As far as possible with the subject as: Control / Action / Procedure - Method (author), eg. EDITBOX: search string with MyFuncSearch (author)
When someone suggest a modification to one of these post make it via private message or put them somewhere else, without adding post to: discussions, congratulations, etc.
danielmaximiliano wrote:Hola Rathi y Serge :
creo que sería buena idea de tener un nuevo foro donde se encuentren todas estas funciones que se generan y crean a partir de una
solicitud de parte de algunos de los miembros de HMG.
Hi Rathi and Serge:
I think it would be good idea to have a new forum where all these functions are generated and create from a
request by some members of HMG.
Dear Rathi, this matter is becoming off topic. I suggest to divide topic, in order to treat separately.
All messages concerning "Search string in EDITBOX" should be in another section for HMG technical discuss and keep with diferent title for "New section" in forum.
