Variables Vacias * * URGE * *
Re: Variables Vacias * * URGE * *
esgici wrote:Hola Daniel
I agree with you,
I didn't encountered any problem to say "not stable" for HMG 3.1.5 patched version 8-)
Viva HMG :D
I agree with you,
Viva HMG :D
Gracias el esfuerzo de Claudio, Rathi y demas integrantes de HMG tenemos nuestra herramienta de trabajo bien aceitada; solo es necesario actualizar Harbour a
Thanks effort Claudio, Rathi and other members of HMG have our well-oiled working tool, it is only necessary to upgrade Harbour
Harbour Build Info
Version: Harbour 3.2.0dev (r1310302212)
Compiler: MinGW GNU C 4.6.1 (32-bit)
Platform: Windows 7 6.1.7601 Service Pack 1
PCode version: 0.3
ChangeLog last entry: 2013-10-30 23:12 UTC+0100 Przemyslaw Czerpak (druzus/at/poczta.onet.pl)
ChangeLog ID: 4cd3443a77d764a2177101781f283f7a29685566
Built on: Oct 31 2013 02:42:02
Build options: (Clipper 5.3b) (Clipper 5.x undoc)
agregando 2 nuevas aplicaciones que serviran de mucho a todos nuestros amigos de HMG.
Sample Explorer por Pablo
y si es posible desde HMG extended
adding two new applications which would serve as much to all our friends HMG.
Sample Explorer by Pablo
and if possible from HMG extended
* New: 'Harbour librarian' utility.
Contributed by Igor Nazarov.
Revised by Grigory Filatov <gfilatov@inbox.ru>
(see in folder \Utils\HB_LIB)
AidTIC
Post by AidTIC »
Muchas Gracias,
Pues me bajo la HMG 3.1.5 y el parche, y ya les cuento
Skydone Solutions
www.skydone.com
AidTIC
Post by AidTIC »
Perdon,
Donde encuentro el parche ???
Skydone Solutions
www.skydone.com
AidTIC wrote:Where can I find the patch ???
viewtopic.php?f=43&t=3092&p=28397#p28397
C:\MiniGUI\UTILS\HB_LIB
danielmaximiliano wrote:agregando 2 nuevas aplicaciones que serviran de mucho a todos nuestros amigos de HMG.
Daniel y demás, para no hacer desvio de asunto, crié nuevo tópico tratando sobre esto, por favor fijate aqui: http://hmgforum.com/viewtopic.php?p=30252#p30252
AidTIC
Post by AidTIC »
Hola,
he instalado la version hmg.3.1.5 con el parche que me comentasteis.
He compilado un fuente, que me funcionaba perfectamente con hmh.3.0.46, y la primera en la frente.
Los botones que tenia con GIf, con fondo transparente, me sale con fondo negro, :-(((
y cuando entro al primer mantenimiento, me abre el la ventana, muestra el un GRID, y me da un eror de programa.
"Error DBCMD/2001 workarea not in use: DBgoto
Called from DBGOTO(0)
Called from GETDATAGRIDCELLDATA(2366)
Called from EVENTS(2795)
Called from _ACTIVATEWINDOWS(5210)
Called from MAIN(88)
Solo os puedo decir que el la llamada MAIN(88) es donde activo la ventana del menu principal.
ACTIVATE WINDOW Win_1
podeis orientarme??
Gracias
Skydone Solutions
www.skydone.com
AidTIC wrote:Hola,
podeis orientarme??
Gracias
Did you re-build library and test demos as Dr. Soto told ?
AidTIC
Post by AidTIC »
Perfecto, he ejecutado el BuildAllLib.bat y ha desaparecido el error.
Ahora me fata los .gif, que salen con fondo negro en vez de transparente,
Los convierto a Png???
Skydone Solutions
www.skydone.com
AidTIC wrote:Perfecto, he ejecutado el BuildAllLib.bat y ha desaparecido el error.
un Gif es una secuencia de imagenes , un PNG no; es una imagen estatica.
