ADORDD WITH ACCESS DATABASES...
Re: ADORDD WITH ACCESS DATABASES...
Roberto Lopez wrote:Hi All!,
Since HMG's Browse rely on recno() function to work, it does not work :)
I've decided to remove the sample until new Harbour version be released (hopefully the problem will be solved).
If someone has additional info about this, please, let me know.
Hi Roberto,
FYI I've used an old adordd.prg (Rev.8953 2008-07-08) and Browse control works properly (recno() function is updated correctly).
gfilatov wrote: FYI I've used an old adordd.prg (Rev.8953 2008-07-08) and Browse control works properly (recno() function is updated correctly).
I have not archived old Harbour versions.
Could you be so kind to post it here?
Had you tested with other databases (ie: MySql)?
TIA.
Roberto,
I've tested with MDB file only :|
The source is below :arrow:
 * $Id: adordd.prg 8953 2008-07-08 06:06:06Z vszakats $
 * Harbour Project source code:
 * ADORDD - RDD to automatically manage Microsoft ADO
 * Copyright 2007 Fernando Mancera <fmancera@viaopen.com> and
 * Antonio Linares <alinares@fivetechsoft.com>
 * www - http://www.harbour-project.org
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2, or (at your option)
 * any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this software; see the file COPYING.  if not, write to
 * the Free Software Foundation, Inc., 59 Temple Place, Suite 330,
 * Boston, MA 02111-1307 USA (or visit the web site http://www.gnu.org/).
 * As a special exception, the Harbour Project gives permission for
 * additional uses of the text contained in its release of Harbour.
 * The exception is that, if you link the Harbour libraries with other
 * files to produce an executable, this does not by itself cause the
 * resulting executable to be covered by the GNU General Public License.
 * Your use of that executable is in no way restricted on account of
 * linking the Harbour library code into it.
 * This exception does not however invalidate any other reasons why
 * the executable file might be covered by the GNU General Public License.
 * This exception applies only to the code released by the Harbour
 * Project under the name Harbour.  if you copy code from other
 * Harbour Project or Free Software Foundation releases into a copy of
 * Harbour, as the General Public License permits, the exception does
 * not apply to the code that you add in this way.  To avoid misleading
 * anyone as to the status of such modified files, you must delete
 * this exception notice from them.
 * if you write modifications of your own for Harbour, it is your choice
 * whether to permit this exception to apply to your modifications.
 * if you do not wish that, delete this exception notice.
#include "rddsys.ch"
#include "fileio.ch"
#include "error.ch"
#include "adordd.ch"
#include "common.ch"
#include "dbstruct.ch"
#ifndef __XHARBOUR__
   #include "hbusrrdd.ch"
   #xcommand TRY              => bError := errorBlock( {|oErr| break( oErr ) } ) ;;
                                 BEGIN SEQUENCE
   #xcommand CATCH [<!oErr!>] => errorBlock( bError ) ;;
                                 RECOVER [USING <oErr>] <-oErr-> ;;
#else
   #include "usrrdd.ch"
#endif
#define WA_RECORDSET  1
#define WA_BOF        2
#define WA_EOF        3
#define WA_CONNECTION 4
#define WA_CATALOG    5
#define WA_TABLENAME  6
#define WA_ENGINE     7
#define WA_SERVER     8
#define WA_USERNAME   9
#define WA_PASSWORD  10
#define WA_QUERY     11
#define WA_LOCATEFOR 12
#define WA_SCOPEINFO 13
#define WA_SQLSTRUCT 14
#define WA_SIZE      14
ANNOUNCE ADORDD
static bError, s_cTableName, s_cEngine, s_cServer, s_cUserName, s_cPassword, s_cQuery := ""
#ifdef __XHARBOUR__
static function HB_TokenGet( cText, nPos, cSep )
   local aTokens := HB_ATokens( cText, cSep )
return iif( nPos <= Len( aTokens ), aTokens[ nPos ], "" )
#endif
static function ADO_INIT( nRDD )
   local aRData
   USRRDD_RDDDATA( nRDD, aRData )
return SUCCESS
static function ADO_NEW( nWA )
   local aWAData := Array( WA_SIZE )
   aWAData[ WA_BOF ] := .F.
   aWAData[ WA_EOF ] := .F.
   USRRDD_AREADATA( nWA, aWAData )
return SUCCESS
static function ADO_CREATE( nWA, aOpenInfo )
   local cDataBase   := HB_TokenGet( aOpenInfo[ UR_OI_NAME ], 1, ";" )
   local cTableName  := HB_TokenGet( aOpenInfo[ UR_OI_NAME ], 2, ";" )
   local cDbEngine   := HB_TokenGet( aOpenInfo[ UR_OI_NAME ], 3, ";" )
   local cServer     := HB_TokenGet( aOpenInfo[ UR_OI_NAME ], 4, ";" )
   local cUserName   := HB_TokenGet( aOpenInfo[ UR_OI_NAME ], 5, ";" )
   local cPassword   := HB_TokenGet( aOpenInfo[ UR_OI_NAME ], 6, ";" )
   local oConnection := TOleAuto():New( "ADODB.Connection" )
   local oCatalog    := TOleAuto():New( "ADOX.Catalog" )
   local aWAData     := USRRDD_AREADATA( nWA )
   local oError
   do case
      case Lower( Right( cDataBase, 4 ) ) == ".mdb"
           if ! File( cDataBase )
              oCatalog:Create( "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" + cDataBase )
           oConnection:Open( "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" + cDataBase )
      case Upper( cDbEngine ) == "MYSQL"
           oConnection:Open( "DRIVER={MySQL ODBC 3.51 Driver};" + ;
                             "server=" + cServer + ;
                             ";database=" + cDataBase + ;
                             ";uid=" + cUserName + ;
                             ";pwd=" + cPassword )
   endcase
   TRY
      oConnection:Execute( "DROP TABLE " + cTableName )
   CATCH
   END
   TRY
      oConnection:Execute( "CREATE TABLE [" + cTableName + "] (" + aWAData[ WA_SQLSTRUCT ] + ")" )
   CATCH
      oError := ErrorNew()
      oError:GenCode     := EG_CREATE
      oError:SubCode     := 1004
      oError:Description := HB_LANGERRMSG( EG_CREATE ) + " (" + ;
                            HB_LANGERRMSG( EG_UNSUPPORTED ) + ")"
      oError:FileName    := aOpenInfo[ UR_OI_NAME ]
      oError:CanDefault  := .T.
      UR_SUPER_ERROR( nWA, oError )
   END
   oConnection:Close()
return SUCCESS
static function ADO_CREATEFIELDS( nWA, aStruct )
   local n
   aWAData[ WA_SQLSTRUCT ] := ""
   for n := 1 to Len( aStruct )
      if n > 1
         aWAData[ WA_SQLSTRUCT ] += ", "
      aWAData[ WA_SQLSTRUCT ] += "[" + aStruct[ n ][ DBS_NAME ] + "]"
      do case
         case aStruct[ n ][ DBS_TYPE ] $ "C,Character"
              aWAData[ WA_SQLSTRUCT ] += " CHAR(" + AllTrim( Str( aStruct[ n ][ DBS_LEN ] ) ) + ") NULL"
         case aStruct[ n ][ DBS_TYPE ] == "N"
              aWAData[ WA_SQLSTRUCT ] += " NUMERIC(" + AllTrim( Str( aStruct[ n ][ DBS_LEN ] ) ) + ")"
         case aStruct[ n ][ DBS_TYPE ] == "L"
              aWAData[ WA_SQLSTRUCT ] += " LOGICAL"
      endcase
   next
return SUCCESS
static function ADO_OPEN( nWA, aOpenInfo )
   local cName, aField, oError, nResult
   local oRecordSet, nTotalFields, n
   // When there is no ALIAS we will create new one using file name
   if aOpenInfo[ UR_OI_ALIAS ] == nil
      HB_FNAMESPLIT( aOpenInfo[ UR_OI_NAME ], , @cName )
      aOpenInfo[ UR_OI_ALIAS ] := cName
   aWAData[ WA_CONNECTION ] := TOleAuto():New( "ADODB.Connection" )
   aWAData[ WA_TABLENAME ] := s_cTableName
   aWAData[ WA_QUERY ]    := s_cQuery
   aWAData[ WA_USERNAME ] := s_cUserName
   aWAData[ WA_PASSWORD ] := s_cPassword
   aWAData[ WA_SERVER ] := s_cServer
   aWAData[ WA_ENGINE ] := s_cEngine
   do case
      case Lower( Right( aOpenInfo[ UR_OI_NAME ], 4 ) ) == ".mdb"
           if Empty( aWAData[ WA_PASSWORD ] )
              aWAData[ WA_CONNECTION ]:Open( "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" + aOpenInfo[ UR_OI_NAME ] )
              aWAData[ WA_CONNECTION ]:Open( "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" + aOpenInfo[ UR_OI_NAME ] + ";Jet OLEDB:Database Password=" + AllTrim( aWAData[ WA_PASSWORD ] ) )
      case Lower( Right( aOpenInfo[ UR_OI_NAME ], 4 ) ) == ".xls"
           aWAData[ WA_CONNECTION ]:Open( "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" + aOpenInfo[ UR_OI_NAME ] + ";Extended Properties='Excel 8.0;HDR=YES';Persist Security Info=False" )
      case Lower( Right( aOpenInfo[ UR_OI_NAME ], 4 ) ) == ".dbf"
           aWAData[ WA_CONNECTION ]:Open( "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" + aOpenInfo[ UR_OI_NAME ] + ";Extended Properties=dBASE IV;User ID=Admin;Password=;" )
      case Lower( Right( aOpenInfo[ UR_OI_NAME ], 3 ) ) == ".db"
           aWAData[ WA_CONNECTION ]:Open( "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" + aOpenInfo[ UR_OI_NAME ] + ";Extended Properties='Paradox 3.x';" )
      case aWAData[ WA_ENGINE ] == "MYSQL"
           aWAData[ WA_CONNECTION ]:Open( "DRIVER={MySQL ODBC 3.51 Driver};" + ;
                                          "server=" + aWAData[ WA_SERVER ] + ;
                                          ";database=" + aOpenInfo[ UR_OI_NAME ] + ;
                                          ";uid=" + aWAData[ WA_USERNAME ] + ;
                                          ";pwd=" + aWAData[ WA_PASSWORD ] )
      case aWAData[ WA_ENGINE ] == "SQL"
           aWAData[ WA_CONNECTION ]:Open( "Provider=SQLOLEDB;" + ;
      case aWAData[ WA_ENGINE ] == "ORACLE"
           aWAData[ WA_CONNECTION ]:Open( "Provider=MSDAORA.1;" + ;
                                          "Persist Security Info=False" + ;
                                          iif( Empty( aWAData[ WA_SERVER ] ),;
                                          "", ";Data source=" + aWAData[ WA_SERVER ] ) + ;
                                          ";User ID=" + aWAData[ WA_USERNAME ] + ;
                                          ";Password=" + aWAData[ WA_PASSWORD ] )
   endcase
   oRecordSet := TOleAuto():New( "ADODB.Recordset" )
   oRecordSet:CursorType     := adOpenDynamic
   oRecordSet:CursorLocation := adUseClient
   oRecordSet:LockType       := adLockPessimistic
   oRecordSet:Open( aWAData[ WA_QUERY ] + aWAData[ WA_TABLENAME ], aWAData[ WA_CONNECTION ] )
   aWAData[ WA_CATALOG ] := TOleAuto():New( "ADOX.Catalog" )
   aWAData[ WA_CATALOG ]:ActiveConnection := aWAData[ WA_CONNECTION ]
   if oRecordSet == NIL
      oError:GenCode     := EG_OPEN
      oError:SubCode     := 1001
      oError:Description := HB_LANGERRMSG( EG_OPEN )
      oError:OsCode      := 0 // To be implemented
      return FAILURE
   aWAData[ WA_RECORDSET ] := oRecordSet
   aWAData[ WA_BOF ] := aWAData[ WA_EOF ] := .F.
   UR_SUPER_SETFIELDEXTENT( nWA, nTotalFields := oRecordSet:Fields:Count )
   FOR n := 1 TO nTotalFields
      aField := ARRAY( UR_FI_SIZE )
      aField[ UR_FI_NAME ]    := oRecordSet:Fields( n - 1 ):Name
      aField[ UR_FI_TYPE ]    := ADO_GETFIELDTYPE( oRecordSet:Fields( n - 1 ):Type )
      aField[ UR_FI_TYPEEXT ] := 0
      aField[ UR_FI_LEN ]     := ADO_GETFIELDSIZE( aField[ UR_FI_TYPE ], oRecordSet:Fields( n - 1 ):DefinedSize )
      aField[ UR_FI_DEC ]     := 0
      UR_SUPER_ADDFIELD( nWA, aField )
   nResult := UR_SUPER_OPEN( nWA, aOpenInfo )
   if nResult == SUCCESS
      ADO_GOTOP( nWA )
return nResult
static function ADO_CLOSE( nWA )
   local oRecordSet := USRRDD_AREADATA( nWA )[ WA_RECORDSET ]
   TRY
      // oRecordSet:Close()
   CATCH
   END
return UR_SUPER_CLOSE( nWA )
static function ADO_GETVALUE( nWA, nField, xValue )
   if aWAData[ WA_EOF ] .or. oRecordSet:RecordCount() == 0
      xValue := nil
      xValue := oRecordSet:Fields( nField - 1 ):Value
return SUCCESS
static function ADO_GOTOID( nWA, nRecord )
   local oRecordSet := USRRDD_AREADATA( nWA )[ WA_RECORDSET ], nRecNo
   if oRecordSet:RecordCount() > 0
      oRecordSet:MoveFirst()
      oRecordSet:Move( nRecord - 1, 0 )
    ADO_RECID( nWA, @nRecNo )
RETURN iif( nRecord == nRecNo, SUCCESS, FAILURE )
static function ADO_GOTOP( nWA )
   local oRecordSet := aWAData[ WA_RECORDSET ]
   if oRecordSet:RecordCount() != 0
return SUCCESS
static function ADO_GOBOTTOM( nWA )
   oRecordSet:MoveLast()
return SUCCESS
static function ADO_SKIPRAW( nWA, nRecords )
   if nRecords != 0
         if nRecords > 0
            return SUCCESS
         ADO_GOBOTTOM( nWA )
         ++nRecords
       if nRecords < 0 .AND. oRecordSet:AbsolutePosition <= -nRecords
          aWAData[ WA_BOF ] := .T.
          aWAData[ WA_EOF ] := oRecordSet:EOF
       elseif nRecords != 0
          oRecordSet:Move( nRecords )
return SUCCESS
static function ADO_BOF( nWA, lBof )
   lBof := aWAData[ WA_BOF ]
return SUCCESS
static function ADO_EOF( nWA, lEof )
   lEof := ( oRecordSet:AbsolutePosition == -3 )
return SUCCESS
static function ADO_DELETED( nWA, lDeleted )
  TRY
     if oRecordSet:Status == adRecDeleted
        lDeleted := .T.
        lDeleted := .F.
  CATCH
     lDeleted := .f.
  END
return SUCCESS
static function ADO_DELETE( nWA )
   oRecordSet:Delete()
   ADO_SKIPRAW( nWA, 1 )
return SUCCESS
static function ADO_RECID( nWA, nRecNo )
   nRecno := iif( oRecordSet:AbsolutePosition == -3, oRecordSet:RecordCount() + 1, oRecordSet:AbsolutePosition )
return SUCCESS
static function ADO_RECCOUNT( nWA, nRecords )
   nRecords := oRecordSet:RecordCount()
return SUCCESS
static function ADO_PUTVALUE( nWA, nField, xValue )
   if ! aWAData[ WA_EOF ] .and. !( oRecordSet:Fields( nField - 1 ):Value == xValue )
      oRecordSet:Fields( nField - 1 ):Value := xValue
      TRY
         oRecordSet:Update()
      CATCH
      END
return SUCCESS
static function ADO_APPEND( nWA, lUnLockAll )
  HB_SYMBOL_UNUSED( lUnLockAll )
  oRecordSet:AddNew()
  TRY
     oRecordSet:Update()
  CATCH
  END
return SUCCESS
static function ADO_FLUSH( nWA )
   TRY
      oRecordSet:Update()
   CATCH
   END
return SUCCESS
static function ADO_ORDINFO( nWA, nIndex, aOrderInfo )
   do case
      case nIndex == UR_ORI_TAG
           if aOrderInfo[ UR_ORI_TAG ] != Nil .and. aOrderInfo[ UR_ORI_TAG ] < aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Indexes:Count
              aOrderInfo[ UR_ORI_RESULT ] := aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Indexes( aOrderInfo[ UR_ORI_TAG ] ):Name
              aOrderInfo[ UR_ORI_RESULT ] := ""
   endcase
return SUCCESS
static function ADO_PACK( nWA )
return SUCCESS
static function ADO_RAWLOCK( nWA, nAction, nRecNo )
  HB_SYMBOL_UNUSED( nAction )
  HB_SYMBOL_UNUSED( nRecNo )
return SUCCESS
static function ADO_LOCK( nWA, aLockInfo  )
   aLockInfo[ UR_LI_METHOD ] := DBLM_MULTIPLE
   aLockInfo[ UR_LI_RECORD ] := RECNO()
   aLockInfo[ UR_LI_RESULT ] := .T.
return SUCCESS
static function ADO_UNLOCK( nWA, xRecID )
  HB_SYMBOL_UNUSED( xRecID )
return SUCCESS
static function ADO_SETFILTER( nWA, aFilterInfo )
   oRecordSet:Filter := SQLTranslate( aFilterInfo[ UR_FRI_CEXPR ] )
return SUCCESS
static function ADO_CLEARFILTER( nWA )
   TRY
      oRecordSet:Filter := ""
   CATCH
   END
return SUCCESS
static function ADO_ZAP( nWA )
   if aWAData[ WA_CONNECTION ] != nil .and. aWAData[ WA_TABLENAME ] != nil
      TRY
         aWAData[ WA_CONNECTION ]:Execute( "TRUNCATE TABLE " + aWAData[ WA_TABLENAME ] )
      CATCH
         aWAData[ WA_CONNECTION ]:Execute( "DELETE * FROM " + aWAData[ WA_TABLENAME ] )
      END
      oRecordSet:Requery()
return SUCCESS
static function ADO_SETLOCATE( nWA, aScopeInfo )
   aScopeInfo[ UR_SI_CFOR ] := SQLTranslate( aWAData[ WA_LOCATEFOR ] )
   aWAData[ WA_SCOPEINFO ] := aScopeInfo
return SUCCESS
static function ADO_LOCATE( nWA, lContinue )
   oRecordSet:Find( aWAData[ WA_SCOPEINFO ][ UR_SI_CFOR ], iif( lContinue, 1, 0 ) )
   USRRDD_SETFOUND( nWA, ! oRecordSet:EOF )
return SUCCESS
static function ADO_CLEARREL( nWA )
   local nKeys := 0, cKeyName
   if aWAData[ WA_CATALOG ] != nil .and. aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Keys != nil
      TRY
         nKeys := aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Keys:Count
      CATCH
      END
   if nKeys > 0
      cKeyName := aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Keys( nKeys - 1 ):Name
      if !( Upper( cKeyName ) == "PRIMARYKEY" )
         aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Keys:Delete( cKeyName )
return SUCCESS
static function ADO_RELAREA( nWA, nRelNo, nRelArea )
   if nRelNo <= aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Keys:Count()
      nRelArea := Select( aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Keys( nRelNo - 1 ):RelatedTable )
return SUCCESS
static function ADO_RELTEXT( nWA, nRelNo, cExpr )
      cExpr := aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Keys( nRelNo - 1 ):Columns( 0 ):RelatedColumn
return SUCCESS
static function ADO_SETREL( nWA, aRelInfo )
   local cParent := Alias( aRelInfo[ UR_RI_PARENT ] )
   local cChild  := Alias( aRelInfo[ UR_RI_CHILD ] )
   local cKeyName := cParent + "_" + cChild
   TRY
      aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Keys:Append( cKeyName, adKeyForeign,;
                                    aRelInfo[ UR_RI_CEXPR ], cChild, aRelInfo[ UR_RI_CEXPR ] )
   CATCH
      // raise error for can't create relation
   END
return SUCCESS
static function ADO_ORDLSTADD( nWA, aOrderInfo )
   TRY
      oRecordSet:Index := aOrderInfo[ UR_ORI_BAG ]
   CATCH
   END
return SUCCESS
static function ADO_ORDLSTCLEAR( nWA )
   TRY
      oRecordSet:Index := ""
   CATCH
   END
return SUCCESS
static function ADO_ORDLSTFOCUS( nWA, aOrderInfo )
   TRY
      oRecordSet:Index = aOrderInfo[ UR_ORI_BAG ]
   CATCH
   END
return SUCCESS
static function ADO_ORDCREATE( nWA, aOrderCreateInfo )
   local oIndex, oError, n, lFound := .f.
   if aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Indexes != nil
      for n := 1 to aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Indexes:Count
          oIndex := aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Indexes( n - 1 )
          if oIndex:Name == iif( ! Empty( aOrderCreateInfo[ UR_ORCR_TAGNAME ] ), aOrderCreateInfo[ UR_ORCR_TAGNAME ], aOrderCreateInfo[ UR_ORCR_CKEY ] )
             lFound := .T.
             exit
      next
   TRY
      if aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Indexes == nil .or. ! lFound
         oIndex := TOleAuto():New( "ADOX.Index" )
         oIndex:Name := iif( ! Empty( aOrderCreateInfo[ UR_ORCR_TAGNAME ] ), aOrderCreateInfo[ UR_ORCR_TAGNAME ], aOrderCreateInfo[ UR_ORCR_CKEY ] )
         oIndex:PrimaryKey := .F.
         oIndex:Unique := aOrderCreateInfo[ UR_ORCR_UNIQUE ]
         oIndex:Columns:Append( aOrderCreateInfo[ UR_ORCR_CKEY ] )
         aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Indexes:Append( oIndex )
   CATCH
      oError:FileName    := aOrderCreateInfo[ UR_ORCR_BAGNAME ]
   END
return SUCCESS
static function ADO_ORDDESTROY( nWA, aOrderInfo )
   local aWAData := USRRDD_AREADATA( nWA ), n, oIndex
          if oIndex:Name == aOrderInfo[ UR_ORI_TAG ]
             aWAData[ WA_CATALOG ]:Tables( aWAData[ WA_TABLENAME ] ):Indexes:Delete( oIndex:Name )
      next
return SUCCESS
function ADORDD_GETFUNCTABLE( pFuncCount, pFuncTable, pSuperTable, nRddID )
   local cSuperRDD   /* NO SUPER RDD */
   local aADOFunc[ UR_METHODCOUNT ]
   aADOFunc[ UR_INIT ]         := ( @ADO_INIT() )
   aADOFunc[ UR_NEW ]          := ( @ADO_NEW() )
   aADOFunc[ UR_CREATE ]       := ( @ADO_CREATE() )
   aADOFunc[ UR_CREATEFIELDS ] := ( @ADO_CREATEFIELDS() )
   aADOFunc[ UR_OPEN ]         := ( @ADO_OPEN() )
   aADOFunc[ UR_CLOSE ]        := ( @ADO_CLOSE() )
   aADOFunc[ UR_BOF  ]         := ( @ADO_BOF() )
   aADOFunc[ UR_EOF  ]         := ( @ADO_EOF() )
   aADOFunc[ UR_DELETED ]      := ( @ADO_DELETED() )
   aADOFunc[ UR_SKIPRAW ]      := ( @ADO_SKIPRAW() )
   aADOFunc[ UR_GOTO ]         := ( @ADO_GOTOID() )
   aADOFunc[ UR_GOTOID ]       := ( @ADO_GOTOID() )
   aADOFunc[ UR_GOTOP ]        := ( @ADO_GOTOP() )
   aADOFunc[ UR_GOBOTTOM ]     := ( @ADO_GOBOTTOM() )
   aADOFunc[ UR_RECID ]        := ( @ADO_RECID() )
   aADOFunc[ UR_RECCOUNT ]     := ( @ADO_RECCOUNT() )
   aADOFunc[ UR_GETVALUE ]     := ( @ADO_GETVALUE() )
   aADOFunc[ UR_PUTVALUE ]     := ( @ADO_PUTVALUE() )
   aADOFunc[ UR_DELETE ]       := ( @ADO_DELETE() )
   aADOFunc[ UR_APPEND ]       := ( @ADO_APPEND() )
   aADOFunc[ UR_FLUSH ]        := ( @ADO_FLUSH() )
   aADOFunc[ UR_ORDINFO ]      := ( @ADO_ORDINFO() )
   aADOFunc[ UR_PACK ]         := ( @ADO_PACK() )
   aADOFunc[ UR_RAWLOCK ]      := ( @ADO_RAWLOCK() )
   aADOFunc[ UR_LOCK ]         := ( @ADO_LOCK() )
   aADOFunc[ UR_UNLOCK ]       := ( @ADO_UNLOCK() )
   aADOFunc[ UR_SETFILTER ]    := ( @ADO_SETFILTER() )
   aADOFunc[ UR_CLEARFILTER ]  := ( @ADO_CLEARFILTER() )
   aADOFunc[ UR_ZAP ]          := ( @ADO_ZAP() )
   aADOFunc[ UR_SETLOCATE ]    := ( @ADO_SETLOCATE() )
   aADOFunc[ UR_LOCATE ]       := ( @ADO_LOCATE() )
   aADOFunc[ UR_CLEARREL ]     := ( @ADO_CLEARREL() )
   aADOFunc[ UR_RELAREA ]      := ( @ADO_RELAREA() )
   aADOFunc[ UR_RELTEXT ]      := ( @ADO_RELTEXT() )
   aADOFunc[ UR_SETREL ]       := ( @ADO_SETREL() )
   aADOFunc[ UR_ORDCREATE ]    := ( @ADO_ORDCREATE() )
   aADOFunc[ UR_ORDDESTROY ]   := ( @ADO_ORDDESTROY() )
   aADOFunc[ UR_ORDLSTADD ]    := ( @ADO_ORDLSTADD() )
   aADOFunc[ UR_ORDLSTCLEAR ]  := ( @ADO_ORDLSTCLEAR() )
   aADOFunc[ UR_ORDLSTFOCUS ]  := ( @ADO_ORDLSTFOCUS() )
return USRRDD_GETFUNCTABLE( pFuncCount, pFuncTable, pSuperTable, nRddID, cSuperRDD,;
                            aADOFunc )
init procedure ADORDD_INIT()
   rddRegister( "ADORDD", RDT_FULL )
return
static function ADO_GETFIELDSIZE( nDBFFieldType, nADOFieldSize )
   local nDBFFieldSize := 0
   do case
      case nDBFFieldType == HB_FT_STRING
           nDBFFieldSize := nADOFieldSize
      case nDBFFieldType == HB_FT_INTEGER
      case nDBFFieldType == HB_FT_DOUBLE
      case nDBFFieldType == HB_FT_DATE
           nDBFFieldSize := 8
      case nDBFFieldType == HB_FT_LOGICAL
           nDBFFieldSize := 1
      case nDBFFieldType == HB_FT_MEMO
           nDBFFieldSize := 10
   endcase
return nDBFFieldSize
static function ADO_GETFIELDTYPE( nADOFieldType )
   local nDBFFieldType := 0
   do case
      case nADOFieldType == adEmpty
      case nADOFieldType == adTinyInt
           nDBFFieldType := HB_FT_INTEGER
      case nADOFieldType == adSmallInt
      case nADOFieldType == adInteger
      case nADOFieldType == adBigInt
      case nADOFieldType == adUnsignedTinyInt
      case nADOFieldType == adUnsignedSmallInt
      case nADOFieldType == adUnsignedInt
      case nADOFieldType == adUnsignedBigInt
      case nADOFieldType == adSingle
      case nADOFieldType == adDouble
           nDBFFieldType := HB_FT_DOUBLE
      case nADOFieldType == adCurrency
      case nADOFieldType == adDecimal
           nDBFFieldType := HB_FT_LONG
      case nADOFieldType == adNumeric
      case nADOFieldType == adError
      case nADOFieldType == adUserDefined
      case nADOFieldType == adVariant
           nDBFFieldType := HB_FT_ANY
      case nADOFieldType == adIDispatch
      case nADOFieldType == adIUnknown
      case nADOFieldType == adGUID
           nDBFFieldType := HB_FT_STRING
      case nADOFieldType == adDate
           nDBFFieldType := HB_FT_DATE
      case nADOFieldType == adDBDate
      case nADOFieldType == adDBTime
          //nDBFFieldType := HB_FT_DATE
      case nADOFieldType == adDBTimeStamp
      case nADOFieldType == adFileTime
      case nADOFieldType == adBSTR
      case nADOFieldType == adChar
      case nADOFieldType == adVarChar
      case nADOFieldType == adLongVarChar
      case nADOFieldType == adWChar
      case nADOFieldType == adVarWChar
      case nADOFieldType == adBinary
      case nADOFieldType == adVarBinary
      case nADOFieldType == adLongVarBinary
      case nADOFieldType == adChapter
      case nADOFieldType == adVarNumeric
      // case nADOFieldType == adArray
      case nADOFieldType == adBoolean
           nDBFFieldType := HB_FT_LOGICAL
      case nADOFieldType == adLongVarWChar
           nDBFFieldType := HB_FT_MEMO
      case nADOFieldType == adPropVariant
   endcase
return nDBFFieldType
function HB_AdoSetTable( cTableName )
   s_cTableName := cTableName
return nil
function HB_AdoSetEngine( cEngine )
   s_cEngine := cEngine
return nil
function HB_AdoSetServer( cServer )
   s_cServer := cServer
return nil
function HB_AdoSetUser( cUser )
   s_cUserName := cUser
return nil
function HB_AdoSetPassword( cPassword )
   s_cPassword := cPassword
return nil
function HB_AdoSetQuery( cQuery )
   DEFAULT cQuery TO "SELECT * FROM "
   s_cQuery := cQuery
return nil
function HB_AdoSetLocateFor( cLocateFor )
   USRRDD_AREADATA( Select() )[ WA_LOCATEFOR ] := cLocateFor
return nil
static function SQLTranslate( cExpr )
   if Left( cExpr, 1 ) == '"' .and. Right( cExpr, 1 ) == '"'
      cExpr := SubStr( cExpr, 2, Len( cExpr ) - 2 )
   cExpr := StrTran( cExpr, '""', "" )
   cExpr := StrTran( cExpr, '"', "'" )
   cExpr := StrTran( cExpr, "''", "'" )
   cExpr := StrTran( cExpr, "==", "=" )
   cExpr := StrTran( cExpr, ".and.", "AND" )
   cExpr := StrTran( cExpr, ".or.", "OR" )
   cExpr := StrTran( cExpr, ".AND.", "AND" )
   cExpr := StrTran( cExpr, ".OR.", "OR" )
return cExpr
function HB_AdoRddGetConnection( nWA )
   DEFAULT nWA TO Select()
return USRRDD_AREADATA( nWA )[ WA_CONNECTION ]
function HB_AdoRddGetCatalog( nWA )
return USRRDD_AREADATA( nWA )[ WA_CATALOG ]
function HB_AdoRddGetRecordSet( nWA )
   local aWAData
return iif( aWAData != nil, aWAData[ WA_RECORDSET ], nil )
and header file is :
 * $Id: adordd.ch 8239 2008-01-26 09:02:24Z vszakats $
 * along with this software; see the file COPYING.  If not, write to
 * Project under the name Harbour.  If you copy code from other
 * If you write modifications of your own for Harbour, it is your choice
 * If you do not wish that, delete this exception notice.
#ifndef _ADORDD_CH
#define _ADORDD_CH
// Cursor Type
#define adOpenForwardOnly     0
#define adOpenKeyset          1
#define adOpenDynamic         2
#define adOpenStatic          3
// Lock Types
#define adLockReadOnly        1
#define adLockPessimistic     2
#define adLockOptimistic      3
#define adLockBatchOptimistic 4
// Field Types
#define adEmpty 					    0
#define adTinyInt 					 16
#define adSmallInt 						2
#define adInteger 						3
#define adBigInt 					   20
#define adUnsignedTinyInt 	 17
#define adUnsignedSmallInt 	 18
#define adUnsignedInt 			 19
#define adUnsignedBigInt 		 21
#define adSingle 						  4
#define adDouble 						  5
#define adCurrency 					  6
#define adDecimal 					 14
#define adNumeric 				  131
#define adBoolean 				   11
#define adError 						 10
#define adUserDefined 		  132
#define adVariant 					 12
#define adIDispatch 					9
#define adIUnknown 				   13
#define adGUID 							 72
#define adDate 							  7
#define adDBDate 					  133
#define adDBTime 					  134
#define adDBTimeStamp 		  135
#define adBSTR 						    8
#define adChar 							129
#define adVarChar 					200
#define adLongVarChar 			201
#define adWChar 						130
#define adVarWChar 					202
#define adLongVarWChar 			203
#define adBinary 						128
#define adVarBinary 				204
#define adLongVarBinary 		205
#define adChapter 					136
#define adFileTime 				   64
#define adPropVariant 			138
#define adVarNumeric 				139
#define adArray 							// &H2000
#define adRecDeleted				  4
#define adUseNone             1
#define adUseServer           2
#define adUseClient           3
#define adUseClientBatch      3
#define adKeyForeign	        2
#command USE <(db)> [VIA <rdd>] [ALIAS <a>] [<nw: NEW>] ;
            [<ex: EXCLUSIVE>] [<sh: SHARED>] [<ro: READONLY>] ;
            [CODEPAGE <cp>] [INDEX <(index1)> [, <(indexN)>]] ;
            [ TABLE <cTable> ] ;
            [ <dbEngine: ACCESS, MYSQL, ORACLE, INFORMIX, SQL> ];
            [ FROM <cServer> ] ;
            [ QUERY <cQuery> ] ;
            [ USER <cUser> PASSWORD <cPassword> ]=> ;
         [ HB_AdoSetTable( <cTable> ) ; ] ;
         [ HB_AdoSetEngine( <(dbEngine)> ) ; ] ;
         [ HB_AdoSetServer( <cServer> ) ; ] ;
         [ HB_AdoSetQuery( <cQuery> ) ; ] ;
         [ HB_AdoSetUser( <cUser> ); HB_AdoSetPassword( <cPassword> ) ; ] ;
         dbUseArea( <.nw.>, <rdd>, <(db)>, <(a)>, ;
                    if(<.sh.> .or. <.ex.>, !<.ex.>, NIL), <.ro.> [, <cp>] ) ;
         [; dbSetIndex( <(index1)> )] ;
         [; dbSetIndex( <(indexN)> )]
#command LOCATE [FOR <for>] [WHILE <while>] [NEXT <next>] ;
                [RECORD <rec>] [<rest:REST>] [ALL] => ;
         [ HB_AdoSetLocateFor( <(for)> ); ] ;
         __dbLocate( <{for}>, <{while}>, <next>, <rec>, <.rest.> )
#endif
gfilatov wrote: I've tested with MDB file only :|
Ok. I'll setup MySql to test it.
The problem arises in Harbour BCC version too?
Do you know if someone had reported the ADORDD recno() issue on Harbour developers list?
If not, I guess we should do.
Thanks.
Roberto Lopez wrote:...
Roberto,
The current ADORDD version in SVN don't work properly with HMG.
I've used an old adordd.prg in HMG Extended Edition.
But nobody hadn't reported recno() issue on Harbour developers list AFAIK :oops:
gfilatov wrote: Roberto,
Ok.
My point is that the true problem is not in HMG.
If recno() function fails this is a Harbour ADORDD problem.
If you test the console sample bundled with Harbour, you can see the '0' as 'recno' in the native (console) Harbour Browse.
My question about if you've tested on BCC is to give a better report to Harbour developers.
Thanks.
Roberto Lopez wrote: My point is that the true problem is not in HMG.
This sample shows '0' as recno in native (console mode) Browse():
 * $Id: access1.prg 9312 2008-09-05 00:08:34Z vszakats $
REQUEST ADORDD
function Main()
   USE Test.mdb VIA "ADORDD" TABLE "Tabla1"
   Browse()
   USE
return nil
Here is the screenshot.
Roberto,
I confirm the recno() function fails (=0) in the console Harbour test on BCC.
Roberto,
Thanks a lot!
