Error in Graph_4 Sample
Re: Error in Graph_4 Sample
Hi
Excellent !
Tested, worked fine on Sudip's example.
Thanks a lot.
This is difference between worker ( me ) and the master.
esgici wrote:Hi
Excellent !
Thanks a lot.
Thanks!... I'll wrote to you when feel depressed :)
The solution was pretty simple.
When the calculated arc (in degrees) for a part is zero, I avoid the attempt to draw in the main loop of the routine.
That's all.
Roberto Lopez wrote: When the calculated arc (in degrees) for a part is zero, I avoid the attempt to draw in the main loop of the routine.
And... the idea come to me from your original message: When the value is near 0% you see 'nothing' in your graph, so it must not be drawn :)
Hi Roberto
Roberto Lopez wrote:[
... the idea come to me from your original message ...
Thanks, someones dreams and someones achieves.
A confusion occured; I just send a post, now attachment exist but post lost !
So I'll resend.
And, an exaggerated test :
      SERIES {10^6,1500,0,500,800};
Best Regards
Hello Roberto,
Thanks a lot! It works fine! :)
Yesterday I installed an add-on software in one of my client's computer, to create graphs from my old application.
I faced the problem in front of my client. :(
Now I can send the corrected software to him. :)
Hi Esgici,
Thank you again for helping so much :)
With best regards to you all.
sudip wrote: I faced the problem in front of my client. :(
The worst things occurs when the clients are even NEAR our apps :)
rathinagiri wrote:
(In the ADORDD WITH ACCESS DATABASES topic) :
Yes. It was once upon a time.
Hi Rathi
I had know already you are a real diamond; but just learned that you are also a hidden treasure :)
The h_graph.prg doesn't include your name as a copyright notice. IMHO this is a big missing part :(
Hi Roberto and Rathi
I have a humble suggestion on PieGraph :
What are your opinions for changing
value aname+iif(lxval," - "+alltrim(str(series,10,2))+" ("+alltrim(str(degrees / 360 * 100,6,2))+" %)","")
line ( Line no : 1083 ) to
value aname+iif(lxval," - "+alltrim(str(series,19,2))+" ("+alltrim(str(degrees / 360 * 100,6,2))+"%)","")
For a value greater than 7 digit ( integer ) a format overflow occurs and user may assume that the Pie Graph don't accept big numbers.
Best Regards
esgici wrote: The h_graph.prg doesn't include your name as a copyright notice. IMHO this is a big missing part :(
I'll fix it.
esgici wrote: Hi Roberto and Rathi
Best Regards
It looks good. I'll test it.
Hello Roberto,
May be I can't understand what do you mean by "NEAR our apps". Do you want to say that we shouldn't show our products to our clients without thorough testing? Please tell me, because I regard your advice very much. :)
Actually I am very much excited about the new "LIFE LINE" of my old apps!!! (And also for future apps) So I can't resist myself to show the advancement of my old creations to others. :)
Don't worry Sudip. It is only a lighter way!
See this when you have time.
