Re: Exploring Bos Taurus
Posted: Sun Nov 17, 2013 7:55 pm
Hi Friend,esgici wrote:Hi All
esgici wrote:
Another trial to explore Bos Taurus : Image Converter
Added :
- Save As PDF
- Image file validity check
wow, very nice !!!
I did small improvements in your project.
I hope is useful.
Claudio.
#include "hfcl.ch"
#define BTExp_FILEFORMAT_PDF 0xFF
PROCEDURE Main()
SET CENT ON
SET DATE GERM
hImage := 0
hImageDisplay := 0
cImgFilName := ''
DEFINE WINDOW frmBTExp_IC;
AT 0,0;
WIDTH 700;
HEIGHT 600;
TITLE "Exploring Bos Taurus for HMG -- Image Converter";
ICON "BT_Icon" ;
ON INIT BTExp_OpenImgFile() ;
ON RELEASE BT_BitmapRelease ( hImage ) ;
ON MAXIMIZE BTExp_SetImageAdjust() ;
ON SIZE BTExp_SetImageAdjust() ;
DEFINE MAIN MENU
DEFINE POPUP '&File'
ITEM "&Open" NAME mit_RFile ACTION BTExp_OpenImgFile()
DEFINE POPUP '&Save As ...' NAME mitSaveAs
ITEM "&BMP" NAME mit_WFBMP_0 ACTION SaveAs ( BT_FILEFORMAT_BMP )
ITEM "&JPG" NAME mit_WFJPG_1 ACTION SaveAs ( BT_FILEFORMAT_JPG )
ITEM "&GIF" NAME mit_WFGIF_2 ACTION SaveAs ( BT_FILEFORMAT_GIF )
ITEM "&TIF" NAME mit_WFTIF_3 ACTION SaveAs ( BT_FILEFORMAT_TIF )
ITEM "&PNG" NAME mit_WFPNG_4 ACTION SaveAs ( BT_FILEFORMAT_TIF )
ITEM "&PDF" NAME mit_WFPDF_5 ACTION SaveAs ( BTExp_FILEFORMAT_PDF )
END POPUP // File
ITEM "&Print" NAME mit_Print ACTION Pict2Prn()
ITEM "&Close" NAME mit_Close ACTION BTExp_CloseImgFile()
SEPARATOR
ITEM "E&xit" ACTION ThisWindow.Release
END POPUP // File
POPUP '?'
ITEM 'About &BT' ACTION MsgInfo( BT_InfoName() + Space(3) + ;
BT_InfoVersion() + CRLF + ;
BT_InfoAuthor () + CRLF + ;
"E-MAIL: srvet@adinet.com.uy" + CRLF + ;
"BLOG: http://srvet.blogspot.com", "BT Info" )
ITEM '&Author' ACTION MsgInfo( "AUTHOR: B. Esgici "+ CRLF + ;
"E-MAIL: esgici@gmail.com" + CRLF + ;
"BLOG: http://vivaclipper.wordpress.com", "Author Info" )
END POPUP // Info
@ 0, 0 IMAGE imgTestImage PICTURE NIL ACTION NIL
END MENU // MAIN
DEFINE STATUSBAR FONT 'Verdana' SIZE 8
STATUSITEM ""
STATUSITEM ""
DATE WIDTH 80
CLOCK WIDTH 90
END STATUSBAR
END WINDOW // frmBTExp_IC
frmBTExp_IC.mitSaveAs.Enabled := .F.
frmBTExp_IC.mit_Print.Enabled := .F.
frmBTExp_IC.mit_Close.Enabled := .F.
CENTER WINDOW frmBTExp_IC
ACTIVATE WINDOW frmBTExp_IC
RETURN // BTExplore.Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
PROCEDURE BTExp_CloseImgFile() // Close an Image file
IF hImage <> 0
frmBTExp_IC.StatusBar.Item( 1 ) := ''
frmBTExp_IC.StatusBar.Item( 2 ) := ''
// BT_BitmapRelease ( hImageDisplay ) // is not necessary because hImageDisplay is associated to the @...IMAGE control
BT_HMGSetImage( "frmBTExp_IC", "imgTestImage", 0 ) // Sets a specified bitmap into an Image Control of HMG (@...IMAGE) and automatically
// releases the handle of the bitmap previously associated to the Image Control
hImage := 0
hImageDisplay := 0
cImgFilName := ''
PROCEDURE BTExp_SetImageAdjust()
LOCAL New_Width , New_Height
IF hImage <> 0
New_Width := min ( BT_ClientAreaWidth ( "frmBTExp_IC" ) , BT_BitmapWidth (hImage) )
New_Height := min ( BT_ClientAreaHeight ( "frmBTExp_IC" ) , BT_BitmapHeight(hImage) )
hImageDisplay := BT_BitmapCopyAndResize( hImage, New_Width, New_Height, BT_SCALE )
BT_HMGSetImage( "frmBTExp_IC", "imgTestImage", hImageDisplay ) // Sets a specified bitmap into an Image Control of HMG (@...IMAGE) and automatically
PROCEDURE BTExp_OpenImgFile() // Open an Image file
cImgFilName := Getfile( { {'All images','*.png; *.jpg; *.bmp; *.tif; *.gif'},; // acFilter
{'PNG Files', '*.png'},;
{'JPG Files', '*.jpg'},;
{'BMP Files', '*.bmp'},;
{'TIF Files', '*.tif'},;
{'GIF Files', '*.gif'} },;
'Open Image' )
IF ! EMPTY( cImgFilName ) .OR. FILE( cImgFilName )
hImage := BT_BitmapLoadFile( cImgFilName )
IF hImage <> 0
frmBTExp_IC.StatusBar.Item( 1 ) := cImgFilName
frmBTExp_IC.StatusBar.Item( 2 ) := HB_NTOS( BT_BitmapWidth(hImage) ) +' x '+ HB_NTOS( BT_BitmapHeight(hImage) ) +" pixels"
frmBTExp_IC.mitSaveAs.Enabled := .T.
frmBTExp_IC.mit_Print.Enabled := .T.
frmBTExp_IC.mit_Close.Enabled := .T.
MsgStop( "Couldn't open " + cImgFilName + " file as a image !"+CRLF+CRLF+;
"Not Image File OR unsupported file format ! ", "OPEN ERROR !" )
ENDIF ! EMPTY( cBMFileName )
RETURN // BTExp_OpenImgFile()
PROCEDURE SaveAs ( nNewImageType )
LOCAL cNewImageType,;
cTargetFileNam,;
lContinue := .T.
LOCAL nImgOrjWidth,;
nImgOrjHeight,;
nAspectRatio,;
nImgPDFWidth,;
nImgPDFHeight,;
lSelPDF
IF ! EMPTY( cImgFilName ) .AND. hImage # 0
cNewImageType := HB_USUBSTR( This.Name, 7, 3 )
cTargetFileNam := HB_ULEFT( cImgFilName, HMG_LEN( cImgFilName )- 3 ) + cNewImageType
IF FILE( cTargetFileNam )
lContinue := MsgYesNo( cTargetFileNam + " file exist;" + CRLF + CRLF +;
"OVERWRITE ?", "Confirm Overwrite" )
IF lContinue
IF nNewImageType <> BTExp_FILEFORMAT_PDF
IF BT_BitmapSaveFile( hImage, cTargetFileNam, nNewImageType )
MsgInfo( "Image saved as " + cNewImageType + " in:" + CRLF + cTargetFileNam )
MsgInfo( "Saving as " + cNewImageType + " is UNSUCCESSFUL !", "ERROR !")
ELSE // Target is PDF
Pict2PDF( cTargetFileNam )
ENDIF lContinue
RETURN // SaveAs()
PROCEDURE Pict2PDF( ;
cTargetFileNam )
LOCAL cTmpFName := TEMPFILE(, "png")
nImgOrjWidth := BT_BitmapWidth( hImage )
nImgOrjHeight := BT_BitmapHeight( hImage )
nImgPDFWidth := MIN( nImgOrjWidth / 2.54, 170 )
IF nImgPDFWidth # nImgOrjWidth
nImgPDFHeight := nImgOrjHeight / ( nImgOrjWidth / nImgPDFWidth )
BT_BitmapSaveFile( hImage, cTmpFName, 4 )
SELECT HPDFDOC ( cTargetFileNam ) TO lSelPDF // papersize HPDF_PAPER_A4
IF lSelPDF
START HPDFDOC
START HPDFPAGE
@ 20, 20 HPDFPRINT IMAGE cTmpFName WIDTH nImgPDFWidth HEIGHT nImgPDFHeight
END HPDFPAGE
END HPDFDOC
MsgInfo( "PDF Builded as " + cTargetFileNam )
MsgStop( "PDF Building Unsuccessful :(" + CRLF + CRLF + ;
"May be UNICODE incompatibilty isssue;" + CRLF + ;
"Please check your folder for file names.", ;
"Unexpected ERROR !" )
ENDIF FILE( cTargetFileNam )
MsgStop( "SELECT PDFDOC is unsuccessful :(", "ERROR !" )
ENDIF lSelPDF
FILEDELETE( cTmpFName )
RETURN // Pict2PDF()
PROCEDURE Pict2Prn() // ( previously loaded ) Picture -> Print
LOCAL lSelPrntr
SELECT PRINTER DIALOG TO lSelPrntr PREVIEW
IF lSelPrntr
START PRINTDOC
START PRINTPAGE
@ 20, 20 PRINT IMAGE cImgFilName;
WIDTH 170 ;
HEIGHT 170
END PRINTPAGE
END PRINTDOC
MsgInfo('Print Picture Finished')
MsgBox( "Printing Picture is unsuccessful :(" )
ENDIF lSelPrntr
RETURN // Pict2Prn()
