browse
klauskugel
Re: browse
Post by klauskugel »
Sorry Esgici,
I didn't want to annoy you or
to mix the browse-samples.
:cry:
FYI :
That are official samples of HMG, not mine.
Re: browse
klauskugel wrote: I didn't want to annoy you or
Hi Klaus
Please be calm,
No annoying occurred; my intervention was for clarification only.
Moreover, we are all friends here.
Regards.
browse
esgici wrote:Browse samples extracted from official HMG distribution for a long time ago :(
Attached file: BROWSES.zip
Thanks amigo Esgici, It was so usefull. But please note those sub-folders in BROWSES package when unpack file, the name of folders makes dificult to load in actual HMG IDE. Because IDE say "It´s can not contain spaces in project name", which means all the names: BROWSE.01, BROWSE.02, BROWSE.03 and so on... must be renamed as: BROWSE_01, BROWSE_02 and BROWSE_01 consequently. Just for remind all of you need Browses for compilation at IDE.
P.S. BROWSE.11 it is missing.
Re: browse
Olá Pablo
Pablo César wrote:... It was so usefull. But please note those sub-folders in BROWSES package when unpack file, the name of folders makes dificult to load in actual HMG IDE. Because IDE say "It´s can not contain spaces in project name", which means all the names: BROWSE.01, BROWSE.02, BROWSE.03 and so on... must be renamed as: BROWSE_01, BROWSE_02 and BROWSE_01 consequently. Just for remind all of you need Browses for compilation at IDE.
All of these samples borrowed from official release 3.0.0 TEST XIIIa of HMG and sent to forum without any modification; and all of theme are building and running without any problem like you noticed. Anyway, there isn't space in these folder names and a period (".") never been problem as far as know. May be your path ( up to project folder(s) ) may include spaces.
In other hand, since a long time IDE didn't made any protest to space included project paths. Just now copied BROWSE.26 folder to desktop, open demo.hbp by IDE and run, everything is OK :arrow:
And last point : BROWSE.11 is absent here too :(
Re: browse
Pablo : los Ejemplos Browse funciona correctamentes en HMG.3.1.1 con las modificacions que aporto el amigo Claudio Soto.
el ejemplo 11 no existe, hay que fijarse que paso en las versiones anteriores donde se incluian los ejemplos Browse.
quedo mi carpeta de instalacion HMg.3.1.1
Win7 (C)_2013-03-06_14-01-10.png (28.72 KiB) Viewed 4901 times
Re: browse
A correction :
esgici wrote:..., since a long time IDE didn't made any protest to space included project paths. ...
Sorry, this isn't correct :(
hbmk2 didn't accept space included project path :(
Regards / saludos
