Print Preview in HMG, CatchysoftActiveX,PrintPreview Activex
Re: Print Preview in HMG, CatchysoftActiveX,PrintPreview Act
Carlos Britos wrote:...in the hmg cousin, oohg exist a code to print in pdf.
The class is TPrint, maybe adapting this code to hmg. The file is h_print.prg.
Thanks Carlos
Seen.
Very complex for me :(
May be a guru will adapt it ;)
TIA
I have tried to use libhbpdf from the official distribution from Harbour.
IMHO, it will be easy to adapt with HMG print commands. I start creating a wrapper for HMG print commands and hbpdf library. Let us make it happen.
This is my first pdf file. :)
You have to add 'libs=libhpdf' in configuration.
#include "harupdf.ch"
   define window main at 0, 0 width 800 height 600 main
      define button print
         row 10
         col 10
         caption 'PDF'
         action pdf_create()
      end button
   end window
   main.center
   main.activate
function pdf_create
   LOCAL pdf := HPDF_New()
   IF pdf == NIL
      MsgInfo( "PDF could not be created!" )
   page := HPDF_AddPage( pdf )
   height := HPDF_Page_GetHeight( page )
   width  := HPDF_Page_GetWidth( page )
   def_font := HPDF_GetFont( pdf, "Helvetica", NIL )
   HPDF_Page_SetFontAndSize( page, def_font, 24 )
   tw := HPDF_Page_TextWidth( page, 'This is the page title' )
   HPDF_Page_BeginText( page )
   HPDF_Page_TextOut( page, ( width - tw ) / 2, height - 50, 'This is the page title' )
   HPDF_Page_EndText( page )
   HPDF_SaveToFile( pdf, 'giri.pdf' )
   HPDF_Free( pdf )
   execute file 'giri.pdf'
return nil
Hi Rathi
rathinagiri wrote:I have tried to use libhbpdf from the official distribution from Harbour.
Thanks, very good method and extremely useful starting, as always :D
Do you think improving it and please guide us: where we find documentation on HaruPDF :?:
As always I say, you are a real diamond :)
Best regards
PS: Will be good to open a separate thread / topic for this subject ?
Hi Esgici,
HaruPDF is based on LibHaru. The full documentation API can be seen here.
http://libharu.org/wiki/Documentation
I think we can make a quick and simple wrapper for this library using HMG print commands.
rathinagiri wrote: HaruPDF is based on LibHaru. The full documentation API can be seen here.
Thanks a lot Rathi,
I'll go into it :)
Best regards
The library is very extensive and powerful too.
First we shall try to implement the HMG print commands. Then we can extend further. What do you think?
Hi Rathi
rathinagiri wrote:The library is very extensive and powerful too.
implement the HMG print commands is a bit confusing :?
Since we must protect current HMG print system, do yo think something like this :
SetPrintSystem( <"Standard"> / <"HaruPDF"> )
or
SET PRINT SYSTEM  <"Standard"> / <"HaruPDF">
If so, will be perfect for me :)
And "extend further" too is a good news :D
Best regards
No. I am thinking of not touching HMG commands at all but having a similar structure.
For example:
start printdoc => start pdfdoc
start printpage => start pdfpage
@ 10, 10 print => @ 10, 10 pdfprint
like that.
Perfect :arrow:
Thanks a lot :)
Best regards
Just remember: does we will have in the future more pdf-building systems other than Haru ?
So we add a prefix to keywords, such as:
start pdfdoc => start Hpdfdoc
start pdfpage => start Hpdfpage
@ 10, 10 pdfprint :> @ 10, 10 Hpdfprint
Only an idea :?
Best regards
