Draw text and Draw Line in Window
spelman
Re: Draw text and Draw Line in Window
Post by spelman »
Hi Esgici,
Sorry for taking so long to say thanks for your sample code - I've been away from the computer for a few days.
I'll study your example, and make use of the tecniques. Actually I'm just at the stage of the project where I need
to do some line drawing , so it's very usefull to me ....
Thanks once again,
Steve
Hi Steve
spelman wrote:Sorry for taking so long to say thanks for your sample code
No problem, all we are friends here :)
spelman wrote:...so it's very usefull to me ....
I'm glad that :)
Very usefull example Mr. Esgici, thank you for you contribution and congratulations !
Thanks Pablo :)
Hi Esgici,
I have started using your idea but when drawing many lines and erasing them, I found that everytime all the lines are drawn and then erased. Can't we avoid that?
rathinagiri wrote: I have started using your idea but when drawing many lines and erasing them, I found that everytime all the lines are drawn and then erased. Can't we avoid that?
I want a few play with lines (ah, these gold days of DOS :( ) and me too, I'm wondering answer of this question :(
My opinion is: this is no erasing but drawing issue, because erasing by this way actually is drawing.
Maybe author of DRAW commands will explain this situation.
Hi Rathi
If version you are using include line :
RESTORE WINDOW frmEraseLine
could you try without it ?
I will check and tell you.
I have a dirty way of erasing the things.
All the draw commands are stored in _HMG_SYSDATA [ 102 ] ( i being the form index as I have mentioned in the first post in this thread).
They are in the order of our commands. So, if I want to erase the draw command that I have drawn first,
I use,
i := getformindex( cFormName )
adel( _HMG_SYSDATA [ 102 ] [ i ], 1 )
asize( _HMG_SYSDATA [ 102 ] [ i ], len( _HMG_SYSDATA [ 102 ] [ i ] ) - 1 )
that's all. Next time the window is painted, the first draw command is not drawn.
Hi Rathi
rathinagiri wrote:I will check and tell you.
I'm still waiting :(
rathinagiri wrote: I use, ...
Sorry, I can't achieve this method; it work (no causing any problem, error etc), but I can't see the result ( erasing drawn object ) :?
Could you give an example please ?
rathinagiri wrote: Next time the window is painted, ...
This point also is obscure for me :(
I don't know what is "time the window (re) painted" :(
If this is an "automatic" event made by system, when or under which conditions it occurs :?:
Thanks in advance :D
Best regards
Hi Esgici,
I will post an example tomorrow.
Window will be automatically repainted whenever it is moved, restored, minimized or movement of mouse over.
