how to post messages using programming in "C"
Re: how to post messages using programming in "C"
jairpinho wrote:HMG in 3.0.xx IDE does not perform the function
Pablo César wrote:For me it is working ! See attached files, you can execute .exe
Ola Jair , Ola Cesar
não funciona porque ele simplesmente não tem o módulo Main.PRG no projeto,
no funciona porque simplemente falta el Modulo Main.PRG en el proyecto,
simplemente ejecute el DEMO.EXE
not work because it simply lacks the module Main.PRG in the project,
simply run the Demo.exe
Ahhh si, no me imaginaba que Jair dejara de colocar en su código "Function Main()"... rsrs
Gracias Daniel !
I didn't lack it, copy pasted, saved and compiled; but didn't see resultado : x + y = 20 in the screen (console ) :(
Is it possible the demo.exe (sent into CCode.rar) builded from another ( or slightly different) .prg :?:
Saludos / regards
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
Hi to all :) ,
Compiled in console mode using HMG 3.0.40 and works fine.
[]´s Salamandra
