HMG versus Extended HMG
Re: HMG versus Extended HMG
I installed both HMG and HMG Extended and both run just fine.
Thank you all.
Regards.
Welcome Sudip,
You are from India?!
salamandra
DBs Used: DBF, MySQL, SQL
Post by salamandra »
:D :D Welcome Sudip :D :D
[]'s Salamandra - Brazil
salamandra
;) Hi CCH,
For the past 2 years I had developed a lot of applications using HMG for the "real life" (as Rathinagiri said),
using MySQL and sometimes using DBF tables and had a few problems.
I can say that HMG is ** STABLE ENOUGH ** and ** MATURE ENOUGH ** to develop business applications.
Español
Durante los ultimos dos años he dessarrollado uma gran cantidad de programas y sistemas integrados
para uso en la "vida real" ( como dijo Rathinagiri ), tanto usando MySQL como tablas DBF y realmente
he tenido muy pocos problemas :D :D :D .
Puedo decir, sin duda, que HMG es ** SUFICIENTEMENTE ESTABLE ** y está
** SUFICIENTEMENTE MADURO ** como para ser usado en el desarrollo de aplicaciones comerciales
y de negócios.
about three years ago, I wrote my first application in HMG.
I was testing both HMG and extended HMG.
I stayed with basic HMG - it was (and I think It is :-) ) more stable.
Marek
Hi Everybody,
Thank you all!
I am assured!
Sorry, Rathi I couldn't answer your question (regarding "are you from India?"). As I was very "busy" to learn HMG!!! ;)
Yes, I am from Calcutta (now it is called Kolkata), India.
I am enjoying learning HMG from all of you (and sometimes along with you). :)
