Change Size Menuitem im hmg.4
Someone could answer my question please...
Pablo César wrote:Taking this chance to ask:
In HMG 3 is this possible to do ?
Upto now no body answer my question... snif snif ... :(
l3whmg
Re: Change Size Menuitem im hmg.4
Post by l3whmg »
Hi Pablo.
I'm not sure and I don't remember well (in the last months I only used - concentrated on - HMG4) but I think it's not possible. On the other hand, you can try by your self with HMG3 samples managing these values.
Remember that HMG3 has SetProperty and GetProperty functions: they are most powerfull!
Cheers
Luigi from Italy
www.L3W.it
Rossine
Post by Rossine »
Now the same example using command syntax HMG.3:
#include "hbqtgui.ch"
static Form_1
   HbQt_ErrorSys()
   DEFINE MAINWINDOW Form_1
      ROW    10
      COL    10
      WIDTH  400
      HEIGHT 400
      TITLE  "HMG4 demo change font menu"
      ONINIT Form_1:Center()
     DEFINE TOOLBAR oToolBar1 BUTTONSIZE 120, 80 FONT "ms sans serif" SIZE 12 MOVEABLE .F.
         TOOLBUTTON oButton1 ;
            Caption 'Font Menu Main' ;
            picture 'open.png' ;
            ACTION  { || Form_1:MainMenu:FontSize ++ }
            tooltip 'Change font of <Menu Main>'
         TOOLBUTTON oButton2 ;
            Caption 'Font Menu File' ;
            ACTION  { || Form_1:MainMenu:ItemFile:FontSize ++ }
            tooltip 'Change font of Option <File>'
         TOOLBUTTON oButton3 ;
            Caption 'Font Menu Help' ;
            ACTION  { || Form_1:MainMenu:ItemHelp:FontSize ++ }
            tooltip 'Change font of Option <Help>'
      END TOOLBAR
      DEFINE MAIN MENU NAME MainMenu
         :FontSize := 16  // yes, this work :-)
         Popup 'File' name ItemFile
           Item 'Open'        Action MsgInfo ( 'File:Open'  ) Image 'Check.Bmp'
           Item 'Save'        Action MsgInfo ( 'File:Save'  ) Image 'Free.Bmp'
           Separator
           Item 'Exit' Action Form_1.Release Image 'Exit.Bmp'
         End Popup
         DEFINE POPUP 'Help' name ItemHelp
            MENUITEM 'About' ACTION MsgInfo( 'About' ) IMAGE 'help.bmp'
         END POPUP
      END MENU
END WITH
ACTIVATE WINDOW Form_1
return NIL
Rossine.
Many thanks Luigi for your response. I have seem all HMG samples and did not found any example. I also tried SETFONT but it doesn´t differs.
Hi Rossine, you found a way to do it but in HMG 4. Have you go it in HMG 3 ? Because I´m still using HMG 3.
Rossine
Post by Rossine »
Hi Pablo,
I tested it on MiniGUI extended not know how. I tried the code below but it still fails. :cry:
DEFINE FONT font_4 FONTNAME 'Courier' SIZE 30
hFonte := GetFontHandle( "font_4" )
Define window Form_1 ;
   Define main menu
   End Menu
   SendMessage( _HMG_xMainMenuHandle, WM_SETFONT , hFonte, 0 )
end window
Maybe you can do this with "extended menu" of "MiniGUI extended". See the example at: <C:\MiniGUI\SAMPLES\Advanced\MenuEx\demo.prg>
See this image:
Rossine.
Thank again Rossine. I also note this in HMGE, but I would like to do all in HMG3. Seems that in HMG3 is missing this parameter. Any way I should change developement tool.
l3whmg
Post by l3whmg »
Hi Pablo
Pablo César wrote:Any way I should change developement tool.
I'm sorry for my request, but FROM .... TO ....?
Can you fill "..." please ? Only if you want, obviously.
Cheers
Luigi from Italy
www.L3W.it
l3whmg wrote:Hi Pablo
Cheers
Hi Dear Luigi, I really would like to choose for HMG4 but I am still not knowing how to used it.
l3whmg
Post by l3whmg »
Hi Pablo.
Many thanks for your answer.
Me and other people on this forum can help you :D
But I'm sorry: can you explain your unknowing? I'm at your disposal.
In these days (Xmas) I'm little busy, but next days I can give my time to you. You also use PM.
Cheers.
Luigi from Italy
www.L3W.it
