Is XP/Vista Themes (llol and fee) supported by HMG ?
CCH4CLIPPER
Re: Is XP/Vista Themes (llol and fee) supported by HMG ?
Post by CCH4CLIPPER »
Hi Rathinagiri
I am anxiously awaiting your UDF :-)
CCH
http://cch4clipper.blogspot.com
Sorry for the delay,
Here comes my udf.
call it main.prg
# include "minigui.ch"
function main
define window sample at 0,0 width 800 height 600 main
   define button button1
      row 10
      col 10
      caption "Click here"
      action showtext("readme.txt")
   end button
end window
sample.center
sample.activate
return nil
call it udf.prg
#include "minigui.ch"
function showtext(_filename)
local _pointchar := at(".",_filename)
local _winname := ""
private _winwidth := 700 //getdesktopwidth() - 60
private _winheight := 550 //getdesktopheight() - 60
if _pointchar > 0
   _winname := substr(_filename,1,_pointchar - 1)
   _winname := _filename
if iswindowdefined(&_winname)
   release window &_winname
define window &_winname at 0,0 width _winwidth height _winheight title _filename modal nosize on init textshow(_filename,_winname)
   @ _winheight - 60,int(_winwidth /2)-90  button exit1  caption "Exit" width 80 action textshowexit(_winname)
   @ _winheight - 60,int(_winwidth /2)+10  button print1  caption "Print" width 80 action textfileprint(_filename)
end window
center window &_winname
activate window &_winname
return nil
function textshowexit(_winname)
return nil
function textshow(_filename,_winname)
local lines := {}
local handle := fopen(_filename,0)
local size1 := 0
local size2 := 0
local sample := 0
local lineno := 0
local eof1 := .f.
local linestr := ""
local c := ""
local len1 := 0
local x := 0
local finished := .f.
local m := 0
local length1 := 0
local totpages := 0
local linecount := 0
local length2 := 0
local pagecount := 0
local start := 0
local end := 0
local v := 0
local v1 := 0
if handle == -1
   return nil
size1 := fseek(handle,0,2)
size2 := size1
if size1 > 65000
   sample := 65000
   sample := size1
fseek(handle,0)
lineno := 1
aadd(lines,"")
c := space(sample)
eof1 := .f.
linestr := ""
len1 := 0
do while .not. eof1
   x := 0
   x := fread(handle,@c,sample)
   len1 := len1 + sample
   if x < 1
      eof1 := .t.
      lines[lineno] := linestr
      finished := .f.
      do while .not. finished
         m := at(chr(13),c)
         if m > 0
            if m == 1
               linestr := ""
               lineno := lineno + 1
               aadd(lines,"")
               c := substr(c,m+1,len(c))
               if len(alltrim(linestr)) > 0
                  linestr := linestr + substr(c,1,m-1)
                  linestr := substr(c,1,m-1)
               linestr := ""
               aadd(lines,"")
            linestr := c
            finished := .t.
      enddo
      c := space(sample)
enddo
fclose(handle)
define tab pages of &_winname at 10,10 width _winwidth - 20 height _winheight - 90
length1 := len(lines)
if length1 <= 10000
   totpages := 1
   totpages := 0
   length2 := length1
   do while length2 > 0
      length2 := length2 - 10000
      totpages := totpages + 1
   enddo
if totpages > 15
   return nil
for pagecount := 1 to totpages
   start := ((pagecount-1) * 10000) + 1
   if pagecount == totpages
      end := len(lines)
      end := start + 9999
   page "Page "+alltrim(str(pagecount))
      v := "lb"+alltrim(str(pagecount))
      v1 := "page"+alltrim(str(pagecount))
      &v1 := {}
      for linecount := start to end
         aadd(&v1,{substr(lines[linecount],2,len(lines[linecount]))})
      next j
      @ 25,10 grid &v width _winwidth - 50 height  _winheight - 120 headers {_filename} widths {800} items &v1 value 1 font "courier new" size 10 nolines
   end page
next pagecount
end tab
return nil
function textfileprint(_filename)
copy file (_filename) to lpt1
return nil
I had attached the same for your kind reference. Compile using HMG-IDE and tell me about your comments. The udf can show a text file as read only.
showtext.zip
User Defined Function to show a text file as read only.
(1.97 KiB) Downloaded 384 times
CCH4CLIPPER
Hi Rathinagiri
TQVM for the codes, which I will definitely check out.
Whilst waiting for you, I was EXECUTE 'notepad.ex ' PARAMETERS <'textfilename'>
CCH
rathinagiri wrote: Here comes my udf.
Hi Rathi
Reading a text file is a challenging issue and your work is very nice ( as always ).
But sorry, we have a comprehensive library module for this purpose ( in the our mysterious treasure of course ). Moreover it is documented !
But don't worry, me too discovered it after writing my own.
I hope help you.
TFILEREAD
Read a file one line at a time Previous Top Next
SYNTAX : TFileRead():New( <cFileName> [, <nReadSize> ] ) ==> oFile
ARGUMENTS :
<cFileName> is the required name of the file to be read.
<nReadSize> is the optional size to use when reading from the file. The default value is 4096 and the allowed range is 1 through 65535. Any value outside of this range causes the default value to be used.
RETURNS : An instance of the File Reader class
DESCRIPTION :
TFileRead() is used to access a file one line at a time. You must specify the name of the file when an instance of the class is created.
The class data should be considered private to the class.
The class methods are as follows:
New() : Creates a new instance of the TFileRead class.
Open([<nFlags>]) : Opens the file for reading. The optional nFlags parameter can use any of the FOPEN() flags from fileio.ch. The default is FO_READ + FO_SHARED. Calling this method when the file is already open causes the next ReadLine() to start over from the beginning of the file.
Close() : Closes the file.
ReadLine() : Returns one line from the file, stripping the newline characters. The following sequences are treated as one newline:
1) CR CR LF;
2) CR LF;
3) LF; and
4) CR.
Note: LF CR is 2 newlines.
Name() : Returns the name of the file.
IsOpen() : Returns .T. if the file is open.
MoreToRead() : Returns .T. if there are more lines to be read (think of it as an inverse EOF function).
Error() : Returns .T. if an error has occurred.
ErrorNo() : Returns the current error code.
ErrorMsg([<cPre>]) : Returns a formatted error message.
EXAMPLES :
#include "fileio.ch"
PROCEDURE Main( cFile )
LOCAL oFile := TFileRead():New( cFile )
oFile:Open()
IF oFile:Error()
QOUT( oFile:ErrorMsg( "FileRead: " ) )
WHILE oFile:MoreToRead()
OUTSTD( oFile:ReadLine() )
OUTSTD( NEW_LINE )
END WHILE
oFile:Close()
END IF
QUIT
FILES :
Library is libmisc
SEE ALSO :
TClass()
Hi Esgici,
As you have said, we would discover a helpful module once we write it on our own. :)
Thanks a lot.
However, I am not using txt files to show reports in any of my software and am using grid2print.
Hello Rathinagiri,
I also downloaded your showtext program. It's very good. For 'tab' we need to add some codes (I suppose).
BTW, you mentioned Grid2print. I can't find it in HMG. Is it included in HMG or user defined function?
Hello ESGICI,
Thanks for tFileread. I didn't know it. (Actually there are most of the things in the world which we don't know)
And thank you very much again for simplicity of code.
sudip wrote:Hello Rathinagiri,
Hi Sudip,
FYKI Grid2print is an user defined function which is shared here. Please download the latest version and use it.
Hi Rathinagiri,
Thank you very much!
The link you mentioned goes to a message, where I read usage and excellent screen shot of your program. But I couldn't find the link to download Grid2Print(). May be I missed it ;( . Can you please tell me where can I download it.
Sudip Bhattacharyya
Ya. It can be downloaded here.
