Tree within a Grid
Re: Tree within a Grid
U R a real Transformer Rossine!
Hello All,
QT is really powerful.
Many thanks to Roberto for starting this wonderful project and all who contribute to it to grow
I found the necessary functions for these implementations and tested only. I'll pass along to you where I implemented for you to see the best way to use them:
in TREE.PRG:
Perhaps this could be implemented like this:
Thank you for the attention of all
Rossine.
in TREE.PRG:
New
METHOD New( cName, oParent ) CLASS TREE
::HeaderItem( .T. ) // this don't show header. If you add a Caption to the QtreeWidget it will be .F.
::Expanding( .T. ) // This property holds whether to show controls for expanding and collapsing top-level items
::Animation( .T. ) // This property holds whether animations are enabled
::oQTObject:setColumnCount( 3 ) // rossine
::oQtObject:setSortingEnabled( .T. ) // rossine
RETURN Self
Caption
METHOD Caption( cArg1 ) CLASS TREE
ELSEIF PCOUNT() == 1
IF hb_IsChar( cArg1 ) == .T.
::cCaption := cArg1
::oQtObject:setHeaderLabel( ::cCaption )
::oQTObject:headerItem():settext( 1, "coluna 2" ) // rossine
::oQTObject:headerItem():settext( 2, "coluna 3" ) // rossine
::HeaderItem( .F. )
Caption
METHOD Caption( cArg1 ) CLASS TREEITEM
::oQtObject:setText( 0, cArg1 )
::oQtObject:setText( 1, "ola2" ) // rossine
::oQtObject:setText( 2, "ola3" ) // rossine
::oQtObject:setToolTip( 0, "tool1" ) // rossine
::oQtObject:setToolTip( 1, "tool2" ) // rossine
::oQtObject:setToolTip( 2, "tool3" ) // rossine
::oQtObject:settextAlignment( 0, 0 ) // rossine
::oQtObject:settextAlignment( 1, 1 ) // rossine
::oQtObject:settextAlignment( 2, 1 ) // rossine
ItemImages
TODO: remove/disable icons
METHOD ItemImages( aArg1 ) CLASS TREEITEM
IF LEN( aArg1 ) >= 1
::aImages := aArg1
oNewIcon := QPixmap( ::aImages[1] )
::oIcon:addPixmap( oNewIcon, QIcon_Normal, QIcon_On )
::oQtObject:setIcon( 0, ::oIcon ) // rossine
::oQtObject:setIcon( 1, ::oIcon ) // rossine
::oQtObject:setIcon( 2, ::oIcon ) // rossine
IF LEN( ::aImages ) == 2
oNewIcon := QPixmap( ::aImages[2] )
::oIcon:addPixmap( oNewIcon, QIcon_Selected, QIcon_On )
NODE "Item1"
TREEITEM { "Item1.1", "Item1.1.1", "Item1.1.2"}
TREEITEM { "Item2.1", "Item2.1.1", "Item2.1.2"}
END NODE
Rossine.
Did you notice it ?Rossine wrote:
QT is really powerful.![]()
If you want I can set up an outline of how the would be new command accepting tree for mult-columns. What do you think ?
Rossine.
