DBF<-->SQLite Exporter
Re: DBF->SQLite Exporter
rathinagiri wrote:...changed DBF->SQLite Exporter to DBF<-->SQLite Exporter...
Thanks a lot Rathi, it's exactly what I need :D
Best regards
claudiotedesco
Re: DBF<-->SQLite Exporter
Post by claudiotedesco »
Hello rathinagiri
Queria saber como debo compilar el sqlite2dbf con la version HMG 3.0.35 ?
Se puede con dicha version?
Muchas Gracias
Claudio
Quizás quisiste decir: Hello ratnagiri Queria saber como debo compilar el sqlite2dbf con la version HMG 3.0.35 ? Se puede con dicha version? Muchas Gracias Claudio
Hello rathinagiri
I wanted to know how to compile the sqlite2dbf HMG version 3.0.35?
You can with this version?
thank you very much
Claudio
In that case, you have to attach this file also, and delete the references of hmgsqlite in hbc file..
c:\hmg.3.0.39\hmgsql\source\hmgsqlite.prg
claudiotedesco
ok, lo voy a probar
Gracias
Claudio
rathinagiri wrote:Hi,
As per Esgici's request, I have changed DBF->SQLite Exporter to DBF<-->SQLite Exporter. :)
Now, a SQLite Table can be exported to DBF. It seems to work fine for me. Kindly let me know if there is any bug/error...
Thank you.
Hi Rathi,
I have a two small corrections in the function export2dbf():
1) retrieve of max field's content length of character field must be rewritten as
            aTable1 := sql( oDB1, 'select max( length( ' + cFieldName + ' ) ) from ' + c2sql( cSQLTable ) )
2) max lenght of field name of DBF must be restricted to 10 symbols in the following lines
            for j := 1 to len( aRecord )
               cFieldName := Left( aStruct[ j, 1 ], 10 )  // <-- changed here
               replace &cFieldName with aRecord[ j ]
            next j
Hope that helps :idea:
Thanks a lot for the corrections Grigory. I have made the corrections.
bels79
DBs Used: DBF, MySQL
Post by bels79 »
Thanks, I try to compile but can not because there is error
" C:/DOCUME~1/prima/LOCALS~1/Temp/hbmk_cyffzc.dir/main.o:main.c:(.data+0x348): und
efined reference to `HB_FUN_MISCSQL'
C:/DOCUME~1/prima/LOCALS~1/Temp/hbmk_cyffzc.dir/main.o:main.c:(.data+0x3a8): und
efined reference to `HB_FUN_C2SQL'
C:/DOCUME~1/prima/LOCALS~1/Temp/hbmk_cyffzc.dir/main.o:main.c:(.data+0x408): und
efined reference to `HB_FUN_CONNECT2DB'
C:/DOCUME~1/prima/LOCALS~1/Temp/hbmk_cyffzc.dir/sqlite2dbf.o:sqlite2dbf.c:(.data
+0x88): undefined reference to `HB_FUN_CONNECT2DB'
+0xc8): undefined reference to `HB_FUN_SQL'
+0x158): undefined reference to `HB_FUN_C2SQL'
hbmk2: Error: Running linker. 1 "
Have you included hmgsqlite library while compiling?
bels79
Post by bels79 »
Thank you, to get the file where?
can you please give instructions
Thank you,
beni
IMATECH
Post by IMATECH »
Hello bels79 !
You just need to edit file: dbf2sqlite.hbp ( can be edited via HMG IDE )
If you dont have "HMGSQL LIB" just download from link below:
viewtopic.php?f=8&t=1562&p=12079&hilit=HmgSql#p12079
dbf2sqlite.hbp - before changes:
main.prg
sqlite2dbf.prg
dbf2sqlite.hbp - After changes:
main.prg
sqlite2dbf.prg
# libs
-lhbsqlit3
# .hbc files
hbsqlit3.hbc
dbf2sqlite.hbc
M., Ronaldo
By: IMATECH
Imation Tecnologia
