Just upgraded to 3.0.38, but have problem...
Re: Just upgraded to 3.0.38, but have problem...
rathinagiri wrote:Hi Marek,
hbvpdf library is not included I think. :(
Try include these files in your project code or create a separate library.
I had this library from previous version of harbour :D
thanks , Rathi!
James
Post by James »
Hi, Rathinagiri,
Thanks for your help!
I'm having difficulty making a console app, because when I put HB_GT_WIN_DEFAULT in the .prg, I get an error:
Maybe I'm doing something wrong... :(
l3whmg
Post by l3whmg »
Hi guys.
I have some problem with HMG 3.x and Harbour. I think, because I'm working with different installation.
Anyway:
I receive this errorlog from AGENDA samples:
hbmk2: Processing environment options: -compiler=mingw
Harbour 3.1.0dev (Rev. 16957)
Copyright (c) 1999-2011, http://harbour-project.org/
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(h_controlmisc.o):h_controlmisc.c:(.data+0xf18): undefined reference to `HB_FUN_FREELIBRARY'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(h_controlmisc.o):h_controlmisc.c:(.data+0x1948): undefined reference to `HB_FUN_TOLEAUTO'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_windows.o):c_windows.c:(.text+0x1780): undefined reference to `ISNIL'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_windows.o):c_windows.c:(.text+0x2e4c): undefined reference to `ISCHAR'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_winapimisc.o):c_winapimisc.c:(.text+0x741): undefined reference to `ISNIL'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_winapimisc.o):c_winapimisc.c:(.text+0xded): undefined reference to `ISNIL'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_winapimisc.o):c_winapimisc.c:(.text+0xe03): undefined reference to `ISNIL'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_winapimisc.o):c_winapimisc.c:(.text+0xe23): undefined reference to `ISNIL'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_winapimisc.o):c_winapimisc.c:(.text+0xfe7): undefined reference to `ISCHAR'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_winapimisc.o):c_winapimisc.c:(.text+0x1013): undefined reference to `ISNIL'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_dialogs.o):c_dialogs.c:(.text+0x8ee): undefined reference to `ISARRAY'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_dialogs.o):c_dialogs.c:(.text+0x915): undefined reference to `ISARRAY'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_dialogs.o):c_dialogs.c:(.text+0x93c): undefined reference to `ISARRAY'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_dialogs.o):c_dialogs.c:(.text+0x963): undefined reference to `ISARRAY'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_dialogs.o):c_dialogs.c:(.text+0x98a): undefined reference to `ISARRAY'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_dialogs.o):c_dialogs.c:(.text+0x9b1): more undefined references to `ISARRAY' follow
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_dialogs.o):c_dialogs.c:(.text+0xb6d): undefined reference to `ISNIL'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_dialogs.o):c_dialogs.c:(.text+0xb8a): undefined reference to `ISNIL'
D:/HMiniGui/HMiniGui3/hmg/lib/libhmg.a(c_dialogs.o):c_dialogs.c:(.text+0xbac): undefined reference to `ISNIL'
D:\HMiniGui\HARBOUR\comp\mingw\bin\gcc.exe C:/DOCUME~1/luigi/IMPOST~1/Temp/hbmk_qs8xgv.dir/agenda.o C:/DOCUME~1/luigi/IMPOST~1/Temp/hbmk_qs8xgv.dir/hbmk_0aoflx.o D:/HMiniGui/HMiniGui3/hmg/SAMPLES/AGENDA/_temp.o -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lhfcl -lini -lreport -lmsvfw32 -lvfw32 -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbmysql -lmysql -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbfimage -lhbpgsql -lhbnetio -lhbextern -lhbdebug -lhbvm -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oagenda.exe -LD:/HMiniGui/HARBOUR/lib/win/mingw -LD:/HMiniGui/HARBOUR/bin -LD:/HMiniGui/HMiniGui3/hmg/lib
I'm using this environment:
A) D:\HMiniGui\harbour: I have centralized Harbour distribution (bin and source complete)
B) D:\HMiniGui\HMiniGui3\hmg: hmg distribution without HARBOUR and MINGW folder
C) I do these little change within batch command:
C.1 buildlib.bat I add these lines to adjust Harbour path and keep clean my PATH var
SET HB_COMPILER=mingw
SET HRBHOME=D:\HMiniGui\HARBOUR
SET HRBBIN=%HRBHOME%\bin
SET HRBLOG=hb_error.log
SET SAVPATH=%PATH%
SET PATH=%PATH%;%MGWBIN%;%HRBBIN%
C.2 build.bat I add these lines to adjust Harbour path and Mingw path (windres problem) and keep clean my PATH var
	SET HMGPATH=%~dp0
SET MGWHOME=%HRBHOME%\comp\mingw
SET MGWBIN=%MGWHOME%\bin
rem ******************************************************************************
rem SET BINARIES PATHS
rem	SET PATH=%HMGPATH%\harbour\bin;%HMGPATH%\mingw\bin;%PATH%
SET SAVPATH=%PATH%
SET PATH=%PATH%;%HRBBIN%;%MGWBIN%
Some idea about these problems?
Many thanks in advance.
Cheers
Luigi from Italy
www.L3W.it
l3whmg
Post by l3whmg »
Hi guys,
no one? Well, I find the solution! The problem was harbour libs list. I have copied from hb.hbc all lines inside "# harbour contrib list" and then I can compile and run my program.
But a little question: what is the minimal lib list required by HMG3.0.38? ie I don't use: "crypt", "edit", "editex", "graph", "hfcl", "ini" and "report". In this situation what are the harbour contrib library that I must include (about hmg, obviously).
Many thanks.
Cheers
Luigi from Italy
www.L3W.it
James wrote: I'm having difficulty making a console app, because when I put HB_GT_WIN_DEFAULT in the .prg, I get an error:
Hi James:
I do not use HB_GT_WIN_DEFAULT on mi .prg
build.bat simply use this in my folder where my console application
@echo off
@echo
SET HMGPATH=C:\HMG3.0.38\
if "%1"=="" goto Input
call %HMGPATH%build.bat  %*
goto Finish
:Input
SET Filename=
SET Parameter=
@cls
@echo ********************************************************************************
@echo   This batch file passes information to hbmk2 to make possible an easy
@echo   (zero configuration build of HMG applications).
@echo.
rem @color 01
@echo Enter Filename to compile, Filename.hbp assume if it exists
@echo.
rem @echo Enter <Esc> for Exit
@Set /p Filename=                        Application Name :
@echo.
if {%Filename%}=={} goto :Finish
@echo  Extra parameters
@echo                           /n	no run after build
@echo                           /d	enabled debugger
@echo                           /c	console mode
@echo Note: " <Enter> key entering no parameter is passed "
@echo.
@Set /p Parameter=                      passing parameters :
@echo.
rem @if %Filename%
If "%Parameter%"=="" goto Continue
@echo compilation with parameters
@if EXIST %Filename%.hbp Goto HBPParameters
@if EXIST %Filename%.prg Goto PRGParameters
@echo
@echo HMG Source not found !!!!!
@echo Press any key and Retry.....
@Pause >nul
goto Input
:HBPParameters
@Echo Compile %Filename%.hbp With %Parameter%
call %HMGPATH%build.bat %Parameter% %filename%.hbp
goto Input
:PRGParameters
@Echo Compile %Filename%.PRG With %Parameter%
call %HMGPATH%build.bat %Parameter% %%filename%.prg
@Pause
goto Input
:Continue
@echo no parameters compilation
@echo.
@echo
@pause > nul
@goto Input
:HBP
call %HMGPATH%build.bat %filename%.hbp
goto Input
:PRG
@Echo Compile %Filename%.prg
call %HMGPATH%build.bat %filename%.prg
goto Input
:Finish
@exit
Hi James:
Mrs Rathinagiri Refers:
REQUEST HB_GT_WIN_DEFAULT in PRG code.
Example .PRG :
#include "HMG.CH"
REQUEST HB_GT_CGI_DEFAULT
STATIC .....
Function MAIN
l3whmg wrote:Hi guys,
Many thanks.
Cheers
Had you seen hmg.hbc in hmg main folder?
James
Post by James »
danielmaximiliano wrote:Hi James:
Thanks, Daniel, I'm working now! :)
l3whmg
Post by l3whmg »
Hello Rathinagiri,
yes I see hmg.hbc, but please pay attention to these personal observations:
A) I dont' use crypt, edit, editex, graph, hfcl, ini and report.
B) On the other hand why I must include (ie) hbmysql and mysql or hbodcb or odbc32, etc.. if I dont' use them?
C) I want to keep clean HMG distribution. I don't want mix with my projects
D) My folders structure it's different and I think everyone can have a different structure.
For these reasons I need to cutomize batch command.
I'm using this structure (note: if I can, I never use primary partition C: on MsWindow system)
  • D:\HMiniGui this is my main work folder for HMG development
    D:\HMiniGui\Harbour (1) this folder contains Harbour and MinGw official distribution (nightly)
    D:\HMiniGui\HMiniGui3 this main folder for HMG 3 version
    D:\HMiniGui\HMiniGui4 this main folder for HMG 4 version
subfolders
  • D:\HMiniGui\HMiniGui3\Hmg official HMG3 distribution. Note I want to keep original and clean
    D:\HMiniGui\HMiniGui3\Dbf projects based upon DBF file
    D:\HMiniGui\HMiniGui3\MySql project based upon MySql DB
    D:\HMiniGui\HMiniGui3\Pogres project based upon PostGres DB
    D:\HMiniGui\HMiniGui3\L3wSys personal libraries and resources used by all HMG3 projects
About D:\HMiniGui\HMiniGui4 the structure is the same
1) I want use the last Harbour/MinGw distribution see note (1) and for this reason I don't use HARBOUR and MINGW distribuited with Hmg
2) I don't use IDE
3) I have problem with hmb.hbc about this line: sources=$(hb_curdir)_temp.o. I receive File not found
For these reasons I must customize build.bat (paths, resources and libraries) and I must change buildlib.bat; both to gain Harbour commands than to gain MinGw commands ( within "D:\HMiniGui\Harbour" subfolders )
These facts are the basis of my question: what is the minimum list of libraries?
Anyway, now I can compile and use HMG3 and compile and link my projects.
Many thanks.
Cheers
Luigi from Italy
www.L3W.it
l3whmg
Post by l3whmg »
Hi, please someone can tell me where is located this "ToleAuto():New()" used by h_controlmisc.prg.
I think there are differences between Harbour distribution and HMG-Harbour distribution; ie hbgs.a
Cheers
Luigi from Italy
www.L3W.it
