HMG4: image icon resource file
Re: HMG4: image icon resource file
Excellent find Luigi! :idea:
Congratulations.
This we should have seen from "harbour\contrib\hbqt\test\testres.qrc"
I see that, we don't require ":/resource" as the second parameter for registerResource_1()
Now, we can introduce a command "set resource to xxxxx" to register the resource files.
Hi Luigi,
I had a simple implementation of what you have suggested by the latest commit. If the .qrc file is in the name of the executable filename, we need not specify registerResource() inside main. :)
Kindly update and check it up.
l3whmg
Post by l3whmg »
Hi Rathinagiri,
this a good news ;) and "SET REGISTER" command it's a good :idea:
Now I do other tests: I would pretend to be a consumer and try to use HMG4
For the future, how can I proceed with these implementation inside developer's team?
1) SetWindowIcon inside window.prg
2) Problem about Statusbar
3) (after test) about icons/image
In other words, you can update SF ripository or I'll do these update?
Cheers
Luigi from Italy
www.L3W.it
Hi Luigi,
I had already updated in SF repository. Kindly update the source and see in samples/resource directory.
l3whmg
Post by l3whmg »
Hi Rethinagiri,
many thanks! I'll donwload.
Cheers
Luigi from Italy
www.L3W.it
l3whmg
Post by l3whmg »
Hi Rathinagiri,
I hope I can enter this post replay for the 4 time :x
I check your code but I have some problems:
A) about "SET RESOURCE TO " I've done this change
      :RegisterResource( <cResource> ) ;;
In this way I can use SET RESOURCE TO "CUSIMAGE"
What do You think?
B) about resource class
IF TYPE( cResFileName ) == "UI"
      ::s_qRes:registerResource_1( &cResFileName )
      aadd( ::s_aResources, cResFileName )
I've added a simple test to check if function exist else my program crash.
What do You think?
Cheers
Luigi from Italy
www.L3W.it
l3whmg
Post by l3whmg »
I'm sorry..
about B) the test inside "METHOD New CLASS RESOURCE" but I can't enter all the code.
Cheers
Luigi from Italy
www.L3W.it
l3whmg
Post by l3whmg »
Hi Rathinagiri,
I've included revised code resource.prg. I've applied my test in all register...function. I've used Harbour function to find program name. I rewrite code in according with HMG4 rules.
I hope it gives you pleasure.
Cheers
resource.zip
resource.prg
(578 Bytes) Downloaded 241 times
Luigi from Italy
www.L3W.it
That's great man!
I think you can commit by yourself!
l3whmg
Post by l3whmg »
Hi Rathinagiri,
your comment are welcom!
Well, If I can I try to apply ONLY changes about resource.prg and hmg.ch.
I write this because it's the first time for me with SVN...
Can I do?
Cheers
Luigi from Italy
www.L3W.it
