No HMG4 Font object
Re: No HMG4 Font object
Thanks a lot for your wish to join the team.
You have been added to the developers list. :)
Regarding the button caption,
yes there is a bug.
Change the line# 732 of /hmg.4/svn/source/control.prg to as follows and re-build hmg library:
         ::oQTObject:setText( cValue )
I will update the svn today. Thanks a lot for reporting.
concentra
Post by concentra »
Hi.
I found some other weird thinks...
While playing with fonts, if I change font properties and attribute this changed font to a button ( I am using buttons to test ) the button text font do not change.
But if I change a button ( not a font ) attribute related to font the font changes. And the weird part is that all the other changes made to the font attribute ( not the button ) are now applied !!!
Seems that when a font is attributed to a button object ( I did not tried other objects ) no "refresh" is made in the button font but when the change is made in a button atrtibute the font is "refreshed".
Could you inspect this please ?
In the folowing code the font is unchanged, but if you uncomment // oButton1:FontStrikeOut := .T. the changes are appied.
[[]] Mauricio Faria
Local oWindow , oButton1
With Object oWindow := Window():New()
:Width := 240
:Height := 80
:Type := WND_MAIN
:OnInit := { || oWindow:Center() }
With Object oButton1 := Button():New()
:Row := 20
:Col := 20
:Width := 200
:Caption := 'Click to Change Font'
:OnClick := { || ChangeFont(oButton1) }
End With
End With
oWindow:Activate()
FUNCTION ChangeFont(oButton1)
Static oFont1
Static lFont1
IF lFont1 == NIL
lFont1 := .T.
oFont1 := QFont()
IF lFont1
oFont1:setBold( .T. )
oFont1:setItalic( .T. )
oFont1:setUnderline( .T. )
oButton1:oFont := oFont1
oButton1:Caption := 'Bold, Italic, Strike and Underline'
oFont1:setBold( .F. )
oFont1:setItalic( .F. )
oFont1:setUnderline( .F. )
// oButton1:FontStrikeOut := .F.
oButton1:Caption := 'Normal Font'
lFont1 := ! lFont1
[[]] Mauricio Ventura Faria
I will check that out. Thanks for reporting.
The thing is, you are mingling both internal variables and external properties.
Actually, HMG is a wrapper of QT. You need not use any QT object directly. In this case, kindly see your sample modified as below:
This is how we have to use HMG.
   :Width := 240
   :Height := 80
   :Type := WND_MAIN
      :Row := 20
      :Col := 20
      :Width := 200
   End With
End With
oWindow:Activate()
Static lFont1
   IF lFont1 == NIL
      lFont1 := .T.
   IF lFont1
      oButton1:FontBold := .t.
      oButton1:FontItalic := .t.
      oButton1:FontUnderline := .t.
      oButton1:FontStrikeOut := .t.
      oButton1:FontBold := .f.
      oButton1:FontItalic := .f.
      oButton1:FontUnderline := .f.
      oButton1:FontStrikeOut := .f.
   lFont1 := ! lFont1
concentra
Post by concentra »
I am a bit confused here...
Need not or can´t ?
It "half" worked in my sample...
Actually I do not know what exactly a wrapper is ( have an idea ).
Could you explain a bit how it works and why shouldn´t I use QT objects directly ?
[[]] Maurício Faria
It is only 'you need not'. And it is not 'You can not'.
For this, I have to tell you about HMG version 1 to 3. You might have known about the difficulties of Win32 API (with various Handles and functions). HMG had done away with these API calls by simple XBase like commands by making a wrapper around the Win32 API. However, for some advanced things we might call Win32 API sometimes.
Once we have QT, we are wrapping QT. Even now, we can use QT objects in some advanced/specialized requirements apart from the HMG general functionality.
Now, why it had worked half:
When you change the attribute via an internal variable, like in your example:
The command is not passed on to QT. It is still in Harbour Level. Only when you call
The "FontStrikeOut" method of Control class is called. In this method we have a line like this:
         ::oQTObject:SetFont( ::oFont )
This is where QT is called actually. So, when you had commented out this line, the fonts are not updated.
I am sure you can understand my example.
concentra
Post by concentra »
Ok I got it ( maybe :) )
So, all this begun because of the need to manipulate separate font objects and then assign this particular font object to a control in order change it´s font.
If I understood, whenever I change some attributes in a control, an associated function is called to manipulate this change and send a message to QT to do this particular change.
Is this what you call a wraper ?
Ok, what should I change in the code in order to do exactly the same whenever I change the control´s font ?
In other words, why wrap when I change ::FontStrikeOut and not when I change ::oFont ?
If we do the same thing with both we do not need to write a FONT class to manipulate fonts in HMG4 since the QT one can do all the job...
Is this what you call a wrapper ?
Exactly.
Because, ::oFont is a class variable and ::FontStrikeOut is a class method. ::oFont is fundamentally a holder of the font object. It will not be applied unless we call setFont( ::oFont ) QT function.
Yes. IMHO, that's why a separate font class is not created. Now also, QT is doing all the jobs.
dhaine_adp
Post by dhaine_adp »
Hi Rathi,
Very good explanation.
Danny
Danny
Manila, Philippines
concentra
Post by concentra »
Hi
Ok, I got it.
May I sugest creating a ::Font method to apply font objects to controls ?
METHOD Font SETGET
METHOD Font( xValue ) CLASS CONTROL
IF ::lCreated
IF Pcount() == 0
RETURN ::oFont
ELSEIF Pcount() == 1
IF Valtype( xValue ) == "C"
RETURN FontName( xValue )
ELSEIF Valtype( xValue ) == "O"
::oFont := xValue
IF Pcount() == 0
RETURN ::oFont
::oFont := xValue
