Welcome to the Project Developers' Table
Re: Welcome to the Project Developers' Table
mol wrote:
Roberto Lopez wrote:
Finally put the code of the new properties in the control class, so, we can access it from the other controls.
Sorry, I don't know how :(
I've commited source\label.prg
Tomorrow, I will work on next properties.
Beginnings are difficult and very energy-intensive ;)
The code has some other problems.
I'll work on it...
test.rar
(691.48 KiB) Downloaded 220 times
Moving backcolor and fontcolor properties not worked because you've forgot to delete these lines from label class:
DATA aBackColor INIT Nil
DATA aFontColor INIT Nil
METHOD BackColor SETGET
METHOD FontColor SETGET
dhaine_adp
Post by dhaine_adp »
Hi Roberto,
I have updated (downloaded) my SVN copy of the Project files. I have installed QTSDK more than a month ago (but never read it though I played with the demos.)
I think I needed direction concerning GRID implementation. QT has this base class QAbstractItemView Class Reference which is inherrited by QColumnView, QHeaderView, QListView, QTableView, and QTreeView. Shall I inherit from the base class or the sub class QTableView?
Sorry I hope that I am not causing a delay on the project's over all progress.
Danny
Danny
Manila, Philippines
dhaine_adp wrote:Hi Roberto,
Danny
I'm just learning QT step by step, basically from HBQT samples (complementing it with QT official reference).
So, sorry, I not 'master' QT :)
Please, take a look at HBQT demos in Harbour distribution. There are Grid and Browse implementations that can give you an idea about how to start.
There is no problem about try and error at this stage of development...
Hi team!
These are the latest changes (right-click->tortoiseSVN->Show log):
Revision: 72
Author: roblez
Date: 19:13:14, martes, 17 de agosto de 2010
Message:
* Show and Hide Methods implemented in control class
modified samples/editbox/demo_1.prg
modified source/control.prg
Modified : /samples/editbox/demo_1.prg
Modified : /source/control.prg
Revision: 71
Author: roblez
Date: 18:55:13, martes, 17 de agosto de 2010
Message:
* Visible Property implemented in control class. Look at EditBox for usage at control creation.
modified source/editbox.prg
Modified : /source/editbox.prg
Revision: 70
Author: roblez
Date: 18:36:56, martes, 17 de agosto de 2010
Message:
Added : /TODO.TXT
Revision: 69
Author: roblez
Date: 18:29:33, martes, 17 de agosto de 2010
Message:
deleted Not.Supported.Txt
Deleted : /Not.Supported.Txt
Revision: 68
Author: roblez
Date: 18:21:53, martes, 17 de agosto de 2010
Message:
added Not.Supported.Txt
Added : /Not.Supported.Txt
Revision: 67
Author: roblez
Date: 18:01:26, martes, 17 de agosto de 2010
Message:
* Fixed backcolor/FontColor properties and label support fot them
modified samples/label/demo_1.prg
modified source/label.prg
Modified : /samples/label/demo_1.prg
Modified : /source/label.prg
Revision: 66
Author: roblez
Date: 17:26:19, martes, 17 de agosto de 2010
Message:
* New batch file at root (invokes libct required by color support)
modified samples/button/build.bat
modified samples/checkbox/build.bat
modified samples/editbox/build.bat
modified samples/frame/build.bat
modified samples/grid/build.bat
modified samples/label/build.bat
modified samples/spinner/build.bat
modified samples/textbox/build.bat
modified samples/window.main/build.bat
modified samples/window.modal/build.bat
modified samples/window.standard/build.bat
Added : /build.bat
Modified : /samples/button/build.bat
Modified : /samples/checkbox/build.bat
Modified : /samples/editbox/build.bat
Modified : /samples/frame/build.bat
Modified : /samples/grid/build.bat
Modified : /samples/label/build.bat
Modified : /samples/spinner/build.bat
Modified : /samples/textbox/build.bat
Modified : /samples/window.main/build.bat
Modified : /samples/window.modal/build.bat
Modified : /samples/window.standard/build.bat
Hi Again!
If for some reason you prefer to stop the works on a control and continue with other, please document the pending properties, events and methods in the TODO.TXT file that I've just added.
TIA.
Nice!
I've not tested yet, but appears to be that we can now change the colors of everything!
ie, buttons:
With Object oButton7 := Button():New()
:Row := 340
:Col := 40
:Width := 230
:Height := 28
:Caption := "oButton11:BackColor := { 255 , 0 , 0 } "
:OnClick := { || oButton1:BackColor := { 255 , 0 , 0 } }
End With
A little more done:
Revision: 74
Author: roblez
Date: 20:03:05, martes, 17 de agosto de 2010
Message:
* OnCHange Event implemented for editbox.prg
modified TODO.TXT
Modified : /TODO.TXT
Revision: 73
Author: roblez
Date: 19:30:26, martes, 17 de agosto de 2010
Message:
* Updated TODO.TXT (I've specified pending properties, events and methods from the control I'm working on (EditBox))
modified TODO.TXT
Revision: 72
Author: roblez
Message:
Revision: 71
Author: roblez
Message:
Revision: 78
Author: roblez
Date: 22:30:31, martes, 17 de agosto de 2010
Message:
* Little fix in editbox.prg
Revision: 77
Author: roblez
Date: 22:13:32, martes, 17 de agosto de 2010
Message:
* Enabled property implemented in control class
Revision: 76
Author: roblez
Date: 21:33:24, martes, 17 de agosto de 2010
Message:
* Release Method implemented in control class.
modified TODO.TXT
Revision: 75
Author: roblez
Date: 20:59:51, martes, 17 de agosto de 2010
Message:
* SetFocus() Method implemented in class control.prg
modified TODO.TXT
Great work Roberto. :)
