Major bug in resource management
Ricci
Re: Major bug in resource management
Post by Ricci »
Hello Grigory !
Yes ty, it helps a lot ... but the GDI handles a still increasing, but slower. So i have to find other code bugs ;)
I will report when I found them.
Regards ... Ricci
Ricci
Post by Ricci »
Grigory, here is the next one to fix:
The command <ParentWindowName>.<ControlName>.Picture := cImageName for an IMAGE control increase the GDI handles with 1
Regards ... Ricci
Ricci
Post by Ricci »
Hello, Grigory !
Here are some more:
When creating a sub-window with DEFINE WINDOW <WindowName> and closing it with <WindowName>.Release you loose 2 GDI handles every time.
If you create a grafical Button is the window above with BUTTON <ControlName> ... PICTURE <cPictureName> you loose 4 GDI handles more when closing the window.
Enough for today ... :D
Regards ... Ricci
dhaine_adp
Post by dhaine_adp »
IMAGELIST_DESTROY ( _HMG_SYSDATA [ 37 ] [y] ) in the h_controlmisc.prg and recompile HMG library by batch file hmg\source\makehmg.bat.
Hello Grigory,
Thank you for posting the patch. Very fast indeed.
Danny
Danny
Manila, Philippines
Ricci
Post by Ricci »
Ok, i found the solution for the increasing GDI handles using the command <ParentWindowName>.<ControlName>.Picture := cImageName for an IMAGE control.
In c_image.c there is a HDC defined with
HDC tmp2DC = CreateCompatibleDC(imgDC);
but it´s not always deleted at the end of the function.
Here is the corrected file.
Regards ... Ricci
c_image-upd.zip
(2.89 KiB) Downloaded 285 times
Ricci
Post by Ricci »
And another problem solved.
If you create a grafical button in a subwindow with BUTTON <ControlName> ... PICTURE <cPictureName> you loose 4 GDI handles more when releasing the window.
Here is the corrected file (I added some code at line number 2959)
Regard ... Ricci
h_windows-upd.zip
(26.63 KiB) Downloaded 300 times
Thanks Ricci.
Let Roberto reviews the code and accommodates the changes.
Ricci
Post by Ricci »
rathinagiri wrote:Thanks Ricci.
Now we only need a fix for the last error:
Ricci
Post by Ricci »
Ricci wrote:When creating a sub-window with DEFINE WINDOW <WindowName> and closing it with <WindowName>.Release you loose 2 GDI handles every time.
I was able to localize the error above but unable to fix it. A job for Grigory or Roberto this time ;-)
If you open a subwindow with this command:
DEFINE WINDOW Form_2 ;
      AT 100,100 WIDTH 200 HEIGHT 100
ACTIVATE WINDOW Form_2
the program use 12 GDI handles. Closing it, 5 handles are released. If you open it a second time, only 5 handles are used and released when closing.
So this is OK.
Defining the window as MODAL, the behavior is changing:
      AT 100,100 WIDTH 200 HEIGHT 100 MODAL
The program still use 12 GDI handles the first time. But when closing it, only 3 handles are released. Opening it a second time 5 handles are used but every time only 3 GDI handles are released when closing.
So the program consume 2 GDI handles re(opening) and closing MODAL windows. Sounds little, but if you work a long time with a program it could be too much.
Regards ... Ricci
I'll do ASAP.
Thanks!!!
