HMG_aChoice
Re: HMG_aChoice
sweet laziness at Croatia coast, hahaha :D
Re: HMG_aChoice
Hello Rathi,
Thanks a lot, today Swapan also wanted something like this in one of my projects :)
I like both of your programs. For my purpose I like 1st program more. Because:
1. Better user interface (IMHO ;) ) to find and search.
2. Mouse pointer hides in the list window in 2nd program.
Thank you again :)
Re: HMG_aChoice
I had improved this hmg_achoice version (which I had replaced in the first post of this thread too.) This time I have saved some keystrokes. ;)
Kindly check and give your suggestions!.
    private aCountries := HB_ATOKENS( MEMOREAD( "Countries.lst" ),   CRLF )
    public aVar := 1
    set navigation extended
    define window sample at 0,0 width 800 height 600 main
       define label label1
          row 10
          col 10
          width 100
          value "Name"
       end label
       define textbox textbox1
          row 10
          col 110
          width 100
       end textbox
       define label label2
          row 40
          col 10
          width 100
          value "Country"
       end label
       define textbox textbox2
          row 40
          col 110
          width 100
          on gotfocus HMG_AChoice( 10, 300, , , aCountries,,.f.)
       end textbox
       define label label3
          row 70
          col 10
          width 100
          value "City"
       end label
       define textbox textbox3
          row 70
          col 110
          width 100
       end textbox
    end window
    sample.center
    sample.activate
    function HMG_Achoice(nTop,nLeft,nBottom,nRight,aList,nDefault,lAnyWhere)
    local nRow := thiswindow.row
    local nCol := thiswindow.col
    local nWindowWidth := thiswindow.width
    local nWindowHeight := thiswindow.height
    local nWidth := 0
    local nHeight := 0
    local nFound := 0
    local i := 0
    local cInit := this.value
    private _aItems := aclone(aList)
    private _nSelected := 0
    private lAnyWhereSearch := .f.
    private cParentForm := thiswindow.name
    private cThisControl := this.name
    default lAnyWhere := .f.
    default nDefault := 0
    default nBottom := thiswindow.height - 10
    default nRight := thiswindow.width - 10
    lAnyWhereSearch := lAnyWhere
    nWidth := iif(nRight < nWindowWidth,  nRight - nLeft,nWindowWidth - nLeft - 10)
    nHeight := iif(nBottom < nWindowHeight, nBottom - nTop,nWindowHeight - nTop - 10)
    if .not. iswindowdefined(_HMG_AChoice)
       DEFINE WINDOW _HMG_aChoice AT     nRow+nTop, nCol+nLeft ;
                   WIDTH  nWidth  ;
                   HEIGHT nHeight ;
                   TITLE '' ;
                   MODAL ;
                   NOCAPTION;
                   NOSIZE
          define textbox _edit
             row 5
             col 5
             width nWidth - 10
             ON CHANGE     _aChoiceTextChanged( lAnyWhere )
             ON ENTER      _aChoiceSelected(  )
          end textbox
          define listbox _list
             row 30
             col 5
             width nWidth - 10
             height nHeight - 50
             items aList
             on change _achoicelistchanged()
             ON DBLCLICK _aChoiceSelected(  )
          end listbox
       end window
       ON KEY UP     OF _HMG_achoice ACTION _aChoiceDoUpKey()
       ON KEY DOWN   OF _HMG_achoice ACTION _aChoiceDoDownKey()
       ON KEY ESCAPE OF _HMG_achoice ACTION _aChoiceDoEscKey()
       _hmg_sysdata[296] := {||_aChoiceselected()}
       if len(_aItems) > 0
          if nDefault > 0
             _HMG_aChoice._list.value := nDefault
             _HMG_aChoice._edit.value := _aItems[nDefault]
             if len(alltrim(cInit)) > 0
                nFound := ascan(_aItems,cInit)
                if nFound > 0
                   _HMG_aChoice._list.value := nFound
                   _HMG_aChoice._edit.value := cInit
       _HMG_Achoice.activate
       _hmg_sysdata[296] := nil
       inserttab()
       inserttab()
    return nil
    STATIC PROC _aChoiceTextChanged( lAnyWhere )
       LOCAL cCurValue      := _HMG_aChoice._edit.value
       LOCAL nItemNo        := 0
       local lFound := .f.
       FOR nItemNo := 1 TO LEN(_aitems)
          IF lAnyWhere
             IF AT(UPPER(cCurValue),UPPER(_aItems[nItemNo])) > 0
                _HMG_aChoice._list.value := nItemNo
                lFound := .t.
                exit
             IF UPPER( LEFT( _aitems[ nItemNo ], LEN(cCurValue))) == UPPER(cCurValue)
                lFound := .t.
                exit
       NEXT nItemNo
       if .not. lFound
          _HMG_aChoice._list.value := 0
    function _aChoiceselected
    if _HMG_aChoice._List.value > 0
       setproperty(cParentForm,cThisControl,"VALUE",_HMG_aChoice._List.item(_HMG_aChoice._List.value))
       setproperty(cParentForm,cThisControl,"VALUE","")
    release window _HMG_aChoice
    return nil
    function _aChoiceDoUpKey()
       IF _HMG_aChoice._List.value > 1
          _HMG_aChoice._List.value := _HMG_aChoice._List.value - 1
          _HMG_aChoice._edit.value := _HMG_aChoice._List.item(_HMG_aChoice._List.value)
          textboxeditsetsel("_HMG_aChoice","_Edit",0,-1)
    return nil
    function _aChoiceDoDownKey()
       IF _HMG_aChoice._List.value < _HMG_aChoice._List.ItemCount
          _HMG_aChoice._List.value := _HMG_aChoice._List.value + 1
    return nil
    function _aChoiceDoEscKey()
    return nil
    function _achoicelistchanged
    if upper(this.name) == "_EDIT" .and. upper(thiswindow.name) == "_HMG_ACHOICE" .and. .not. lAnyWhereSearch
    return nil
    function textboxeditsetsel(cParent,cControl,nStart,nEnd)
    local nHandle := GetControlHandle (cControl,cParent)
    textboxsetsel(nHandle,nStart,nEnd)
    return nil
    #pragma BEGINDUMP
    #include <windows.h>
    #include <commctrl.h>
    #include "hbapi.h"
    #include <wingdi.h>
    HB_FUNC ( TEXTBOXSETSEL )
       HWND hWnd1;
       hWnd1 = (HWND) hb_parnl (1);
       SendMessage((HWND) hWnd1,EM_SETSEL, (WPARAM)(int) hb_parni(2),(LPARAM) (int) hb_parni(3));
    #pragma ENDDUMP
Re: HMG_aChoice
Thanks Rathi
Good improvement :)
By the way, inserttab() is very nice ( both function itself and usage by you ); SSE (short, simple and effective) :D
Re: HMG_aChoice
Yes!
While seeing HMG's source I found this function usage by Roberto. (That's the reason for SSE!)
Re: HMG_aChoice
Hi Rathi,
Thanks a lot :)
I downloaded (copied) it. I shall test and send you feedback. :)
Re: HMG_aChoice
Tested. Runs fine :)
BTW, how can I use this or CSB with Grid?
Thanks in advance.
