Ware-Soft (A Warehouse management Software)
Re: Ware-Soft (A Warehouse management Software)
Hi Rathi,
I skipped this project :o (may be I was busy with my projects at that time)
Now I downloaded it.
Regarding installation. Can you please tell us how did you create the setup?
Your app is very efficient and easy to operate. I like the interface. :D
Your source codes are always a place of inspiration to me. :)
Thanks a lot for this project :D
Thanks a lot Sudip, for your comments.
I had found some bugs and I am in the process of solving them. Wait for the new version soon.
Setup is created using NSIS (Nullsoft Scriptable Install System) http://nsis.sourceforge.net/Main_Page
Hello Rathi,
Thanks for NSIS. :)
I downloaded it. As of now I am using Inno Setup (I also knew it from you) and SFX Zip Wizard (developed by Grigory Filatov). Both programs are very good :)
Now, I shall try NSIS :)
swapan
Post by swapan »
rathinagiri wrote:Thanks a lot Sudip, for your comments.
Using NSIS! That's great!!
I used to love this script language. Its more then 2 and half years that I've left NSIS domain after switching my job. The biggest advantage is that it is open source with constant developments and has a very good supportive forum (I don't know the current status though) like ours. I learned a lot from that forum.
It seems that I should re-visit the NSIS & its forum.
Thanks & Regards,
Swapan Das
http://www.swapandas.com/
swapan
Post by swapan »
sudip wrote:Hello Rathi,
Thanks for NSIS. :)
Sudip, with NSIS you can do lot of things and not just simple extracting of files and creating application desktop icon. Just visit the site, you will love it.
Thanks & Regards,
Swapan Das
swapan
Post by swapan »
rathinagiri wrote:Hi,
I am with a new project "Ware-Soft" here. :)
Ware-Soft is an open source inventory/warehouse management software.
Main features of the software are:
=> Multi-products with mutli-sub-groups and multi-groups management
=> Multi-locations management
=> User defined operations
=> User defined Unit(s) of measurement(s)
=> Product -> Unit of Measurement Control
=> Location -> Operation Control
=> Location -> Product Control
=> Location -> Product -> Unit of Measurement Control
=> Cost and Market Rate Masters
=> Multi-companies
=> Multi-stockbooks
=> Backend: SQLite DB Files
=> Many useful MIS reports
Source file is here.
Setup file is here.
Just have fun with the initial release of the software. I will explain about the software in detail soon. :)
Thats really great! This can be very useful for starters of HMG to have a first hand knowledge of a real-life project. Sharing your source in our fourm will immensely help many of us and thanks a lot for this. Rathi, you are doing a yeoman service!
Thanks & Regards,
Swapan Das
Hi Rathi:
had not seen his contribution, I saw comments on a correction of a bug, imagine he was still the old version but no.
As will wait to learn more about your type of encoding...
404 Not Found - Mozilla Firefox_2012-06-15_10-30-23.jpg (46.05 KiB) Viewed 6252 times
Thanks for reporting Daniel. Now I have hosted the whole project in sourceforge.net also.
You can download from there too.
https://sourceforge.net/projects/waresoft/
I am adding some screenshots too. :)
Hola Rathri:
estoy intentando instalar la aplicacion pero algo pasa.
Hello Ratrhi:
I'm trying to install your application but something happens.
Ware-Soft Setup Completed_2012-06-15_13-32-59.jpg (31.72 KiB) Viewed 6240 times
Win7 (C)_2012-06-15_13-33-47.jpg (25.05 KiB) Viewed 6240 times
earlier attempt to install with default values ​​and the same result
Windows 7 Home Premiun 64, install as administrator
