Page 2 of 6
Re: Adaptation of FiveWin class TsBrowse to HMG
Posted: Thu Jun 03, 2010 6:24 pm
If the in-place edit cell is a spinner, we can't get out using key board. We have to click another cell with mouse to get away.
Posted: Thu Jun 03, 2010 6:27 pm
Also, the previous data in in-place edit text box is not deleted once we start typing new data. Is that configurable?
Posted: Thu Jun 03, 2010 6:36 pm
by gfilatov
rathinagiri wrote:If the in-place edit cell is a spinner, we can't get out using key board. We have to click another cell with mouse to get away.
Thanks for your bugreport!
It seems that a similar wrong behaviour exists in minigui ext.'s adaptation also :(
Posted: Thu Jun 03, 2010 6:45 pm
by gfilatov
rathinagiri wrote:Also, the previous data in in-place edit text box is not deleted once we start typing new data. Is that configurable?
It's must be fixed (the reason is different behaviour between TextBox and GetBox controls). :|
There is an idea to select the value on gotfocus text box :idea:
Posted: Thu Jun 03, 2010 6:55 pm
Yep. You are right!
Posted: Thu Jun 03, 2010 7:57 pm
by Roberto Lopez
Despite I've asked you to port GETBOX references in TSBROWSE to TEXTBOX, if you consider necessary to add GETBOX code to TSBROWSE to achieve adequate functionality, please, do it. No problem from my part.
If you do it, please, include GETBOX code under the same conditional compilation constant as TSBROWSE.
TIA.
Posted: Thu Jun 03, 2010 10:59 pm
by jucar_es
ALELUYA....
MUCHAS MUCHAS MUCHAS GRACIAS
very very very thanks
Posted: Fri Jun 04, 2010 1:59 am
by fchirico
...::: SPANISH:
Gracias Grigory!!!
Excelente!
En el ejemplo 1 (c:\hmg\SAMPLES\tbrowse.1) si seleciono el menú "Samples on Window" y escojo el "Sample 7", al editar la columna "STATE", arroja varios errores.
Un abrazo.
...::: ENGLISH:
Grigory Thanks!
Excellent!
In example 1 (c: \ hmg \ SAMPLES \ tbrowse.1) if selects the menu "Samples on Window" and choose the "Sample 7" in editing the column "STATE", gives several errors.
A hug.
Posted: Fri Jun 04, 2010 2:07 am
by Roberto Lopez
Grigory,
I've briefly tested and I've found some little problems:
1. When changing column width using mouse, vertical bars stays in the bottom of TBROWSE window (it arises in various samples).
2. In sample 7 (browse on window) when clicking cells a cell frame is drawn at a position different from the clicked cell one (upper left):
3. Moving mouse pointer over headers, cursor flicks.
4. Dragging vertical scrollbar does not work (in all samples).
5. Combo does not match cell height in sample 2 (window):
6. In super columns sample, when you attempt to drag the 'January' column, the four arrows pointer is shown, but the column can´t be dragged.
7. In super headers (bitmaps) sample, if you go to the last column and click the horizontal scrollbar (the space between bar left arrow and bar button) you will not be able to scroll to the left.
8. Report / Excel connectivity present (apparently) a problem with the paper size and/or orientation:
9. I've got randomly (or via an undiscovered steps sequence) the following error:
Error BASE/1004  No exported method: EVAL
10. I've got some errors on editing:
@...TEXTBOX: Wrong InputMask Definition
I've tested with HMG 3.0.34 on Windows 7.
I hope this info be useful.
Posted: Fri Jun 04, 2010 2:15 am
by fchirico
Other error on the demos to edit the cell "NAME":
