HMG OOP?... WHY NOT?... ;) [UPDATED]
karweru
DBs Used: DBF,mysql,mariadb,postgresql,sqlite,odbc
Re: HMG OOP?... WHY NOT?... ;) [UPDATED]
Post by karweru »
Roberto,
To say I'm happy about this development would be an understatement. I've struggled in the past to implement OOP by using the alternate syntax but it has been rather difficult, especially with the window class. I'm extremely impressed with your style of calling :new() without parameters....you have such an exciting way of doing things. Thank you very much ad may God bless you abundantly!
Kind regards,
Gilbert.
sistemascvc wrote:the best way is that you choose.
I agree with you
if i need add a control after the window has been activated
how you do it? (the syntax)
best regards
Ciro
Exactly the same, but you must add the 'Create()' method (it calls _Define* function).
ie:
   * Frame Definition *
   With Object oFrame := Frame():New()
      :Parent      := oWindow
      :Row         := 10
      :Col         := 10
      :Width       := 350
      :Height      := 340
      :Caption     := 'This is an OOP Frame!!!'
      :Create()
   End With
rathinagiri wrote:Nice implementation Roberto. Go ahead.
Thanks. The idea is to give to HMG an alternate personality, so, those wanting to use a GUI in the Clipper OOP style, can do it.
Now that the hard work is done, the rest of the controls will be easy, since most properties, events and methods will inherit from CONTROL class already created.
Besides that, event when not necessary, xBase command directives can be created to meet Clipper style.
karweru wrote:I'm extremely impressed with your style of calling :new() without parameters....you have such an exciting way of doing things. Thank you very much ad may God bless you abundantly!
Thanks.
Anyway, this is not a particularly original idea :)
Clipper's GetNew() function used to create a GET object can be called without parameters.
fchirico
Post by fchirico »
Simplemente Maravilloso!
Ahora quién se quedará fuera de HMG ( oficial, por supuesto ) ?
Gracias porque realmente no manejo la programación OOP, esto me ayudará a comprenderla y utilizarla.
Simply Wonderful!
Now who will be out of HMG (official, of course)?
Thank you because I do not use OOP programming, this will help me understand and use.
Saludos, Fernando Chirico.
fchirico wrote: Simply Wonderful!
I'm thinking same as Fernando, so many thanks for this important enhancement :)
Sorry my ignorance; in this way does we will build our own controls ?
Saludos, regards
Saludos, regards
Not necessarily, but it could be do the things easier.
Take a look at the sources.
FRAME class is very compact because it inherits most properties, events and methods from CONTROL class.
So, If you want to create a new control, your class could inherit from CONTROL class too, saving you a lot of work.
swapan
Post by swapan »
OOPS? WHY NOT?!
Please go ahead and see if anything could be done in this regard.........
Thanks & Regards,
Swapan Das
http://www.swapandas.com/
dhaine_adp
Post by dhaine_adp »
Hi Roberto,
Your OOP code is very elegant and very simple and yet very powerful. You have established the base class of the controls for which all controls can inherit. I tried to experiment with your sample. I modified Test1 and added grid on it.
Unfortunately I am not successful. On the first try, while running the program, the supposed to be window does not display at all. No error log, it simply exit. A little later I added an altd() debugger call and inserted oGrid1:Hide() right before oWindow.Activate. It gives me this error message:
Control: _HMG_OBJECT_3 Of _HMG_OBJECT_1 Not defined. Program Terminated
Called from DOMETHOD(7426)
Called from GRID:HIDE(128)
Called from MAIN(58)
In the OOPLIB.PRG I added this line: Set Procedure To lib\grid
In the spirit of learning I followed the FRAME Class and the GRID Class source code looks like this:
#include "hbclass.ch"
#include "common.ch"
* Class Grid ..................................................................*
CLASS GRID FROM CONTROL
	* Internal Data
   DATA Tooltip INIT NIL
   DATA aHeaders INIT {}
   DATA aWidths INIT {}
   DATA aRows INIT {}
   DATA value INIT {0,0}
   DATA nogrid	INIT .F.
   DATA aImage	INIT {}
   DATA aJust	INIT {}
   DATA break	INIT .F.
   DATA HelpId	INIT NIL
   DATA bold	INIT .F.
   DATA italic		INIT .F.
   DATA underline	INIT .F.
   DATA strikeout	INIT .F.
   DATA ownerdata	INIT .T.
   DATA ondispinfo INIT {}
   DATA itemcount	INIT 0
   DATA available0 INIT .T.
   DATA available1 INIT .T.
   DATA available2 INIT .T.
   DATA multiselec INIT .F.
   DATA available3 INIT .F.
   DATA backcolor	INIT {}
   DATA fontcolor	INIT {}
   DATA inplace	INIT .F.
   DATA editcontrols	INIT NIL
   DATA dynamicbackcolor INIT {}
   DATA dynamicforecolor INIT {}
   DATA columnvalid  INIT {}
   DATA columnwhen  	INIT {}
   DATA columnheaders  INIT {}
   DATA aHeaderImages  INIT NIL
   DATA cellnavigation INIT .T.
   DATA recordsource	INIT NIL
   DATA columnfields	INIT NIL
   DATA append		INIT .F.
   DATA buffered	INIT .T.
   DATA allowdelete     INIT .F.
   DATA dynamicdisplay 	INIT NIL
   DATA OnChange INIT NIL
   DATA DblClick  INIT NIL
   DATA aHeadClick INIT NIL
   DATA GotFocus  INIT NIL
   DATA LostFocus INIT NIL
   DATA OnSave INIT NIL
	* Methods
   METHOD Create()
	* Events
   METHOD Onchange     INLINE EVAL ( ::OnChange )
   METHOD Ondblclick   INLINE EVAL ( ::DblClick )
   METHOD OnaHeadClick INLINE EVAL ( ::aHeadClick )
   METHOD Ongotfocus   INLINE EVAL ( ::GotFocus )
   METHOD Onlostfocus  INLINE EVAL ( ::LostFocus )
   METHOD Onsave       INLINE EVAL ( ::OnSave )
ENDCLASS
* Methods .....................................................................*
METHOD Create() CLASS GRID
   _DefineGrid ( ::cName, ;
   			::cParent, ;
   			::nRow, ;
   			::nCol, ;
   			::nWidth,;
   			::nHeight, ;
   			::aHeaders	, ;
   			::aWidths		, ;
   			::aRows		, ;
   			::value		, ;
   			::fontname	, ;
   			::fontsize	, ;
   			::tooltip		, ;
   			::Onchange		, ;
   			::DblClick	, ;
   			::aHeadClick	, ;
   			::GotFocus	, ;
   			::LostFocus	, ;
   			::nogrid		, ;
   			::aImage		, ;
   			::aJust		, ;
   			::break		, ;
   			::HelpId		, ;
   			::bold		, ;
   			::italic		, ;
   			::underline	, ;
   			::strikeout	, ;
   			::ownerdata	, ;
   			::ondispinfo	, ;
   			::itemcount	, ;
   			::available0	, ;
   			::available1	, ;
   			::available2	, ;
   			::multiselect	, ;
   			::available3	, ;
   			::backcolor	, ;
   			::fontcolor	, ;
   			::inplace		, ;
   			::editcontrols	, ;
   			::dynamicbackcolor ,;
   			::dynamicforecolor ,;
   			::columnvalid , 	  ;
   			::columnwhen , 	  ;
   			::columnheaders ,   ;
   			::aHeaderImages ,   ;
   			::cellnavigation ,  ;
   			::recordsource	, ;
   			::columnfields	, ;
   			::append		, ;
   			::buffered	, ;
   			::allowdelete     , ;
   			::dynamicdisplay 	, ;
   			::OnSave )
         ::lCreated := .T.
RETURN Self
This is the test source code including my altd() call:
#include "include\hmgoop.ch"
Set Procedure To lib\OopLib
Local oFrame
Local oWindow
local oGrid1
PRIVATE aRows_ := ARRAY( 20 )
	_HMG_SYSDATA [ 323 ] := 0
   SetTestData()
	* Window Definition *
	With Object oWindow := Window():New()
		:Row		:= 10
		:Col		:= 10
		:Width		:= 400
		:Height		:= 400
		:Title		:= 'Nice OOP Demo!!!'
		:WindowType	:= WND_MAIN
		:OnInit		:= { || oWindow:Center() }
	End With
		:Parent		:= oWindow
		:Row		:= 10
		:Col		:= 10
		:Width		:= 350
		:Height		:= 340
		:Caption	:= 'This is an OOP Frame and Grid!!!'
	End With
   with object oGrid1 := Grid():New()
      :Parent := oWindow
      :Row    := 15
      :Col    := 15
      :Width  := 330
      :Height := 320
      :aHeaders := { "Last Name", "First Name", "Phone" }
      :aWidths := { 100, 200, 100 }
      :aRows   := aRows_
      :Value   := {1,1}
   End with
altd()
oGrid1:Hide()
	oWindow:Activate()
static function SetTestData()
      aRows_[1]	:= {'Simpson','Homer','555-5555'}
		aRows_[2]	:= {'Mulder','Fox','324-6432'}
		aRows_[3]	:= {'Smart','Max','432-5892'}
		aRows_[4]	:= {'Grillo','Pepe','894-2332'}
		aRows_[5]	:= {'Kirk','James','346-9873'}
		aRows_[6]	:= {'Barriga','Carlos','394-9654'}
		aRows_[7]	:= {'Flanders','Ned','435-3211'}
		aRows_[8]	:= {'Smith','John','123-1234'}
		aRows_[9]	:= {'Pedemonti','Flavio','000-0000'}
		aRows_[10]	:= {'Gomez','Juan','583-4832'}
		aRows_[11]	:= {'Fernandez','Raul','321-4332'}
		aRows_[12]	:= {'Borges','Javier','326-9430'}
		aRows_[13]	:= {'Alvarez','Alberto','543-7898'}
		aRows_[14]	:= {'Gonzalez','Ambo','437-8473'}
		aRows_[15]	:= {'Batistuta','Gol','485-2843'}
		aRows_[16]	:= {'Vinazzi','Amigo','394-5983'}
		aRows_[17]	:= {'Pedemonti','Flavio','534-7984'}
		aRows_[18]	:= {'Samarbide','Armando','854-7873'}
		aRows_[19]	:= {'Pradon','Alejandra','???-????'}
		aRows_[20]	:= {'Reyes','Monica','432-5836'}
		return
My intention in doing this is to see how the exe file would grow, if HMG and OOPLib could run side by side (I believed it would because classes have their own separate space) and the application performance in terms of speed and stability.
Your OOP experimental code is a new world to be explore and it's thrilling to play with.
I have a feeling that my problem lies on the class DATA initialization of the GRID & of course those bugs on my code. :oops:
Congrats and thank you very much for drafting a new toy for us!
Danny
Danny
Manila, Philippines
Estimado Roberto
Mis felicitaciones, nuevamente me sorprendes con tus novedades.
sigues en un camino muy interesante, espero poder serte de utilidad.
saludos cordiales,
Luis Vasquez
