READ THE KEYBOARD
Re: READ THE KEYBOARD
Thanks Alex.
Alex Gustow wrote:But... can anybody translate comments etc in this to English (for better understanding and "internationalization")? I think it helps to many guys whose Spanish is "not the best"
You are right.
My excuses, my English is very poor.
Claudio Soto
Alex Gustow wrote:...translate comments etc in this to English (for better understanding and "internationalization")? I think it helps to many guys whose Spanish is "not the best" [like me :) ].
I agree heartily with Alex :!:
Saludos, regards
Alex Gustow wrote:translate comments etc in this to English (for better understanding and "internationalization")? I think it helps to many guys whose Spanish is "not the best"
Hi all,
READ THE KEYBOARD in English (using google).
Claudio Soto
* PROGRAMA: READ THE KEYBOARD
* LENGUAJE: HARBOUR-MINIGUI 3.0.29
* FECHA:    13 ABRIL 2010
* AUTOR:    CLAUDIO SOTO
* PAIS:     URUGUAY
* E-MAIL:   srvet@adinet.com.uy
* DESCRIPTION
* Read keyboard input entries and returns information about the key pressed.
* These functions intercept keyboard messages from the system will send the application
* (WM_KEYUP and WM_KEYDOWN) and stores information about the virtual key generated.
* SYNTAX:
* INSTALL_READ_KEYBOARD ()   // Install the "driver" that reads the keyboard (returns. T. if successful)
* UNINSTALL_READ_KEYBOARD () // Uninstall the "driver" that reads the keyboard (returns. T. if successful)
* GET_LAST_VK()              // Returns the virtual value (VK Code) of the key pressed
* GET_LAST_VK_NAME()         // Returns the name of the virtual key press
* GET_STATE_VK_SHIFT ()      // Returns. T. if SHIFT key is pressed
* GET_STATE_VK_CONTROL ()    // Returns. T. if CONTROL key is pressed
* GET_STATE_VK_ALT ()        // Returns. T. if ALT key is pressed
* PAUSE_READ_VK (.T.)        // Pause reading keyboard in order to process the key pressed
* PAUSE_READ_VK (.F.)        // Restore keyboard reading after the pause
* Virtual values (VK Code) of the different keys can be found in the file
* C:\hmg.3.0.29\MinGW\include\winuser.h
* They begin with the prefix # define VK_
* For example, # define VK_SHIFT 16
#include "minigui.ch"
SET LANGUAGE TO ENGLISH
	DEFINE WINDOW Form_1 ;
		WIDTH 400 ;
		HEIGHT 600 ;
		TITLE 'READ THE KEYBOARD' ;
		MAIN
        @  10 , 10 LABEL Label_1 AUTOSIZE BOLD FONTCOLOR RED
        @  40 , 10 LABEL Label_2 AUTOSIZE BOLD FONTCOLOR RED
        @  80 , 10 LABEL Label_3 AUTOSIZE BOLD FONTCOLOR BLUE
        @ 120 , 10 LABEL Label_4 AUTOSIZE BOLD FONTCOLOR BLUE
        @ 160 , 10 LABEL Label_5 AUTOSIZE BOLD FONTCOLOR BLUE
        @ 200 , 10 LABEL Label_6 AUTOSIZE BOLD FONTCOLOR BROWN
        @ 240 , 10 LABEL Label_7 AUTOSIZE BOLD FONTCOLOR BROWN
        @ 280 , 10 LABEL Label_8 AUTOSIZE BOLD FONTCOLOR BROWN
        @ 420 , 10 LABEL Label_9 AUTOSIZE BOLD
        @ 380 , 10 LABEL Label_10 VALUE "Press SHIFT + A open Dialog Box" AUTOSIZE BOLD
		@ 450 , 10 EDITBOX EditBox_1  WIDTH 200 HEIGHT 100 VALUE "Write"
		IF INSTALL_READ_KEYBOARD () = .F.
		   MsgInfo ("ERROR when installing READ_KEYBOARD")
		   DEFINE TIMER timer_1 OF Form_1 INTERVAL 100  action Show_Key ()
	//	IF UNINSTALL_READ_KEYBOARD () = .F.
	//	   MsgInfo ("ERROR when uninstalling READ_KEYBOARD")
	//  ELSE
	//     Form_1.Timer_1.Release
	//	ENDIF
	Form_1.Center
	Form_1.Activate
Procedure Show_Key
  Form_1.Label_1.Value := "VK Code: " + str (GET_LAST_VK())
  Form_1.Label_2.Value := "VK Name:            " + GET_LAST_VK_NAME()
  Form_1.Label_3.Value := "Pressed SHIFT :     " + IF (GET_STATE_VK_SHIFT()=.T.,"Yes","No")
  Form_1.Label_4.Value := "Pressed CONTROL:    " + IF (GET_STATE_VK_CONTROL()=.T.,"Yes","No")
  Form_1.Label_5.Value := "Pressed ALT:        " + IF (GET_STATE_VK_ALT()=.T.,"Yes","No")
  Form_1.Label_6.Value := "CAPS LOCK:          " + IF (IsCapsLockActive() =.T.,"On","Off") // HMG function
  Form_1.Label_7.Value := "NUM LOCK:           " + IF (IsNumLockActive()  =.T.,"On","Off") // HMG function
  Form_1.Label_8.Value := "INSERT:             " + IF (IsInsertActive() =.T.,"On","Off")   // HMG function
  IF (GET_STATE_VK_SHIFT()=.T. .OR. IsCapsLockActive() =.T.) .AND. GET_LAST_VK() <> 0
      Form_1.Label_9.Value := "Writing in CAPS"
      Form_1.Label_9.Value := "Writing in MINISCULE"
  IF GET_LAST_VK() = 65  .AND. GET_STATE_VK_SHIFT()=.T.  //  VK code  A = 65
      Form_1.Timer_1.Enabled := .F.
      Msginfo ("Process the action of the SHIFT + A")
      Form_1.Timer_1.Enabled := .T.
*   FUNCIONES EN C
#pragma begindump
#include <windows.h>
#include "hbapi.h"
BOOL flag_hhk = FALSE;
BOOL PAUSE_hhk = FALSE;
HHOOK hhk = NULL;
long VK_PRESIONADO = 0;
LONG VK_lParam = 0;
LRESULT CALLBACK KeyboardProc(int nCode, WPARAM wParam, LPARAM lParam)
    if (nCode < 0)
        return CallNextHookEx(hhk, nCode, wParam, lParam);
    if (PAUSE_hhk == FALSE)
    {   VK_PRESIONADO = (long) wParam;
        VK_lParam = (LONG) lParam;
    {   VK_PRESIONADO = 0;
        VK_lParam = 0;
HB_FUNC (GET_STATE_VK_SHIFT)
   if (GetKeyState(VK_SHIFT) & 0x8000)
       hb_retl (TRUE);
       hb_retl (FALSE);
HB_FUNC (GET_STATE_VK_CONTROL)
   if (GetKeyState(VK_CONTROL) & 0x8000)
       hb_retl (TRUE);
       hb_retl (FALSE);
HB_FUNC (GET_STATE_VK_ALT)
   if (GetKeyState(VK_MENU) & 0x8000)
       hb_retl (TRUE);
       hb_retl (FALSE);
HB_FUNC (GET_LAST_VK)
{  if (flag_hhk == TRUE)
       hb_retnl (VK_PRESIONADO);
      hb_retnl (0);
HB_FUNC (GET_LAST_VK_NAME)
{  CHAR cadena [128];
      {  GetKeyNameText (VK_lParam, (LPTSTR) &cadena, 128);
         hb_retc (cadena);
      hb_retc ("");
HB_FUNC (PAUSE_READ_VK)
{  if (hb_pcount () == 1 && hb_parinfo (1) == HB_IT_LOGICAL)
   {   if (hb_parl (1) == TRUE)
           VK_lParam = 0;
       PAUSE_hhk = hb_parl (1);
HB_FUNC (INSTALL_READ_KEYBOARD)
{  if (flag_hhk == FALSE)
   {    hhk = SetWindowsHookEx (WH_KEYBOARD, KeyboardProc, (HINSTANCE) NULL, GetCurrentThreadId());
        if (hhk == NULL)
            hb_retl (FALSE);
        {   flag_hhk = TRUE;
            hb_retl (TRUE);
      hb_retl (TRUE);
HB_FUNC (UNINSTALL_READ_KEYBOARD)
   {   if (UnhookWindowsHookEx (hhk) == TRUE)
       {   flag_hhk = FALSE;
           hb_retl (TRUE);
           hb_retl (FALSE);
      hb_retl (TRUE);
#pragma enddump
Thanks Dr.
By the way, does "srvt" means "speedy" :?: :D
Saludos cordiales.
jparada
Post by jparada »
Hola Claudio,
Muchas Gracias por esta implementación.
Realmente un gran esfuerzo de tu parte.
Javier
Hi Esgici,
esgici wrote:By the way, does "srvt" means "speedy"
Yes of course,
S = super
R = rápido (fast)
VET = Veterinary
No, it's a joke :lol:
srvet = Soto & Reinoso veterinary.
Valeria Reinoso is my wife.
srvet@adinet.com.uy is our professional e-mail
Claudio
jparada wrote:Hola Claudio,
Javier
Hola Javier,
Es un placer poder colaborar, programar es mi hobby.
Saludos,
Claudio Soto
Hola Dr.
Your joke is good as your programs :)
Your veterinary clinic is family-size, very well.
By the way, in my language we have a word most similar your nickname : servet : its mean is fortune, richness :)
Hi friend Esgici,
thanks for your always kind words.
In reality we not have a veterinary clinic.
We are ranchers (breeding cattle and sheep) and we work as consultants in animal production.
In Uruguay, the livestock is a very important activity for the country economy.
Claudio.
Hola Amigo Claudio
Well, working open-air may be fatiguing but more healthy, it isn't ?
I wish a life always fruitful to you and your wife; God bless you :)
