HMG 3.0.29 Patch 'a'
claudiotedesco
Re: HMG 3.0.29 Patch 'a'
Post by claudiotedesco »
Hola Roberto
Vi tu ejemplo y funciona.
Te paso el error que me da
HMG Errorlog File
Date:16/04/2010 Time: 08:10:15
Error BASE/1066 Argument error: conditional
Called from _DEFINEWINDOW(3700)
Called from MAIN(4)
Este error se produce cuando instalo el patch "a" en Windows 2000 SP4.
Debe ser el sistema operativo. Si no tengo instalado este patch funciona perfectamente.
Cualquier cosa me avisas
Claudio
Mario Mansilla
Post by Mario Mansilla »
Hola Roberto :
Este ultimo error que menciona claudio :
Called from MAIN(4)
me dio tambien a mí , solo que a mi me decia MAIN(5) . Esto sucedio cuando abrir y ejecute desde el ide un proyecto construido con versiones anteriores hasta la 28 .
Lo que hice fue simular una modificacion del form principal , grabarlo y ejecutar nuevamente desde el ide y se soluciono el problema .
Espero que sea de ayuda .
Saludos .
Mario Mansilla
Hola Roberto:
This last mentioned error claudio:
BASE/1066 Error Argument error: conditional
Called from _DEFINEWINDOW (3700)
Called from MAIN (4)
I also gave to me, just told me that my MAIN (5). This happened when to open and run from the ide a project built with previous versions to 28.
What I did was simulate a modification of the main form, save it and run again from the ide and fix the problem.
I hope it helps.
Greetings.
Mario Mansilla
You're using hmg 3.0.28 with patch 3.0.29a, I think.
I've got such an error when I mixed versions.
Try to reinstall 3.0.29 and then patch it.
Marek
mol wrote:You're using hmg 3.0.28 with patch 3.0.29a, I think.
Marek
I agree with this.
Please, do a clean 3.0.29 installation and copy the new libminigui.a to the \lib folder.
Or, you could wait until 3.0.30 and test again.
