Grid - Changing the sort order on a column heading click
Re: Grid - Changing the sort order on a column heading click
Czarny_Pijar wrote:
esgici wrote:
JALMAG wrote: Hello Esgici, what compiling?
Hi JALMAG
Sorry for inconvenience :(
My project became old ;)
Bad news... With HMG ver.3.034 this happend again :?
Which is exactly the problem?
Czarny_Pijar wrote: Bad news... With HMG ver.3.034 this happend again :?
Hi Czarny,
What is happened ?
Please more specific
Czarny_Pijar
Post by Czarny_Pijar »
The construction "window in the window" is forbiden now, the compilation error occurs.
( frmAbout inside frmMiniAgenda )
Despite this "SoftSeek" and "ColumnSort" (the gems of this demo) works excellent :)
Czarny_Pijar wrote:The construction "window in the window" is forbiden now, the compilation error occurs.
Could you be so kind to post the sources giving this error?
TIA.
Czarny_Pijar
The code was taken directly from the kind contribution of esgici (located in this topic):
esgici wrote:Hi Ralph
Please look at one of my humble contributions.
I hope that help you.
alongside with his corrections:
esgici wrote:Hi JALMAG
- rename MAgenda.Hpj to MAgenda.Hbp
- open this .hbp with HMG-IDE
- add C:\hmg\HFCL\Include to Include paths of configuration tab of Project Browser
- add hfcl to additional libs of configuration tab of Project Browser
and press RUN button :)
Hi
This is a problem arise after PANEL type windows introduced.
Simply change WINDOW TYPE as MODAL from CHILD.
This is corrected code snap beginning with line 159 in MAgenda.prg.
      DEFINE WINDOW frmAbout ;
         AT 0, 0 ;
         WIDTH  320 ;
         HEIGHT 300 ;
         MODAL ;
         NOSIZE ;
         NOCAPTION
Czarny_Pijar wrote:The code was taken directly from the kind contribution of esgici (located in this topic):
Ok.
Nested window definitions were never supported (it just worked in some occasion if you tried).
When I've added panel windows, I've put in place a proper validation that generates the error.
Well, no nested window definition included version of Mini Agenda attached.
Enjoy !
PS: Please don't forget adding "hfcl" infos to "configuration" page or build script.
MAgendaA6.rar
June 2010 version of Mini Agenda
(6.32 KiB) Downloaded 301 times
