HMG 2.6.6
Re: HMG 2.6.6
I have a function, called from window OknoUstawienia, which opens new window in position related to row of grid
function ZmienPozycjePlatnosci
param lNowyRekord
local x,y
private ZapiszZmiany := .f.
load window OknoZmianPlatnosci
x:= OknoUstawienia.ROW+OknoUstawienia.B_KodyPlatnosci.Row+20
// this line I must change to:
//x := GetProperty("OknoUstawienia","ROW")+OknoUstawienia.B_KodyPlatnosci.Row + 20
y:=OknoUstawienia.COL+OknoUstawienia.B_KodyPlatnosci.Col+20
// y := GetProperty("OknoUstawienia","COL")+OknoUstawienia.B_KodyPlatnosci.Col + 20
OknoZmianPlatnosci.Row := x
OknoZmianPlatnosci.Col := y
if !Nowyrekord
OknoZmianPlatnosci.T_Nazwa.Value := kody_pl->nazwa
OknoZmianPlatnosci.T_LiczbaDni.Value := kody_pl->liczba_dni
OknoZmianPlatnosci.C_Zaplacono.Value := kody_pl->zaplacono
OknoZmianPlatnosci.title := if(lNowyRekord,"Nowa forma płatności","Popraw formę płatności")
activate window OknoZmianPlatnosci
set key K_ESC to
return
Error occurs during compilation time when I have changed hmg to ver 2.6.6
Regards, Marek
Re: HMG 2.6.6
mol wrote:I have a function, called from window OknoUstawienia, which opens new window in position related to row of grid
param lNowyRekord
local x,y
if !Nowyrekord
set key K_ESC to
return
Marek,
Kindly try to change your function as follows
param lNowyRekord
local x := OknoUstawienia.ROW
local y := OknoUstawienia.COL
x += OknoUstawienia.B_KodyPlatnosci.Row+20
y += OknoUstawienia.B_KodyPlatnosci.Col+20
I hope that give you an idea :idea:
Re: HMG 2.6.6
Regards, Marek
Marek,
As I've said in a previous message, the changes I've made must be backwards compatible, if not, there are bugs that I must fix.
Could you be so kind to post a little (complete) sample to allow to me to analyze the problem ?
TIA.
Re: HMG 2.6.6
Roberto Lopez wrote:...
Roberto,
Please take a look for the following sample:
* MiniGUI Hello World Demo
* (c) 2002 Andrea Migliazzi
#include "minigui.ch"
Local aRows [20] [3]
	DEFINE WINDOW Form_1 ;
		WIDTH 450 ;
		HEIGHT 400 ;
		TITLE 'Hello World!' ;
		MAIN ;
		ON SIZE onsize()
		aRows [1]	:= {'Simpson','Homer','555-5555'}
		aRows [2]	:= {'Mulder','Fox','324-6432'}
		aRows [3]	:= {'Smart','Max','432-5892'}
		aRows [4]	:= {'Grillo','Pepe','894-2332'}
		aRows [5]	:= {'Kirk','James','346-9873'}
		aRows [6]	:= {'Barriga','Carlos','394-9654'}
		aRows [7]	:= {'Flanders','Ned','435-3211'}
		aRows [8]	:= {'Smith','John','123-1234'}
		aRows [9]	:= {'Pedemonti','Flavio','000-0000'}
		aRows [10]	:= {'Gomez','Juan','583-4832'}
		aRows [11]	:= {'Fernandez','Raul','321-4332'}
		aRows [12]	:= {'Borges','Javier','326-9430'}
		aRows [13]	:= {'Alvarez','Alberto','543-7898'}
		aRows [14]	:= {'Gonzalez','Ambo','437-8473'}
		aRows [15]	:= {'Batistuta','Gol','485-2843'}
		aRows [16]	:= {'Vinazzi','Amigo','394-5983'}
		aRows [17]	:= {'Pedemonti','Flavio','534-7984'}
		aRows [18]	:= {'Samarbide','Armando','854-7873'}
		aRows [19]	:= {'Pradon','Alejandra','???-????'}
		aRows [20]	:= {'Reyes','Monica','432-5836'}
		@ 10,10 GRID Grid_1 ;
		WIDTH 400 ;
		HEIGHT 330 ;
		HEADERS {'Last Name','First Name','Phone'} ;
		WIDTHS {140,140,140};
		ITEMS aRows ;
		VALUE 1 ;
		TOOLTIP 'Editable Grid Control' ;
		EDIT ;
                JUSTIFY { BROWSE_JTFY_LEFT,BROWSE_JTFY_RIGHT, BROWSE_JTFY_RIGHT }
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
procedure onsize()
	form_1.grid_1.width := form_1.width - 50
	form_1.grid_1.height:= form_1.height - form_1.grid_1.row - 60
return
You will got the error message below after resizing the form_1 in aboved sample:
Harbour MiniGui Errorlog File
Date:10/07/08 Time: 13:39:10
Error BASE/1003 Variable does not exist: _FORM_1_HEIGHT
Called from GETCONTROLTYPE(871)
Called from GETPROPERTY(6864)
Called from ONSIZE(62)
Called from (b)MAIN(18)
Called from _DOWINDOWEVENTPROCEDURE(4418)
Called from EVENTS(1183)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4083)
Called from MAIN(56)
because there is a mistake in the preprocessing for procedure onsize():
procedure onsize()
    SetProperty ( "Form_1", "grid_1" , "width" , GetProperty ( "Form_1", "width" ) - 50 )
    SetProperty ( "Form_1", "grid_1" , "height" , GetProperty ( "Form_1", "height - form_1" , "grid_1" , "row" ) - 60 )
return
BTW This sample works properly with hmg 2.6.4 :!:
Re: HMG 2.6.6
Roberto,
Thanks a lot Grigory!
I'll review it (and try to fix) ASAP.
Re: HMG 2.6.6
Well... I've fixed, but since the fix could have undesirable side effects
, I'm posting it here for testing prior to create a full new build.
Any reports are welcome.
You only must to replace i_windows.ch in 2.6.6 with this:
 MINIGUI - Harbour Win32 GUI library source code
 Copyright 2002-2008 Roberto Lopez <harbourminigui@gmail.com>
 http://harbourminigui.googlepages.com/
 This program is free software; you can redistribute it and/or modify it under
 the terms of the GNU General Public License as published by the Free Software
 Foundation; either version 2 of the License, or (at your option) any later
 version.
 This program is distributed in the hope that it will be useful, but WITHOUT
 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
 You should have received a copy of the GNU General Public License along with
 this software; see the file COPYING. If not, write to the Free Software
 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA (or
 visit the web site http://www.gnu.org/).
 As a special exception, you have permission for additional uses of the text
 contained in this release of Harbour Minigui.
 The exception is that, if you link the Harbour Minigui library with other
 files to produce an executable, this does not by itself cause the resulting
 executable to be covered by the GNU General Public License.
 Your use of that executable is in no way restricted on account of linking the
 Harbour-Minigui library code into it.
 Parts of this project are based upon:
	"Harbour GUI framework for Win32"
 	Copyright 2001 Alexander S.Kresin <alex@belacy.belgorod.su>
 	Copyright 2001 Antonio Linares <alinares@fivetech.com>
	www - http://www.harbour-project.org
	"Harbour Project"
	Copyright 1999-2003, http://www.harbour-project.org/
	"WHAT32"
	Copyright 2002 AJ Wos <andrwos@aust1.net>
	"HWGUI"
  	Copyright 2001-2007 Alexander S.Kresin <alex@belacy.belgorod.su>
// DECLARE WINDOW Translate Map (Semi-OOP Properties/Methods Access)
// 01-01	->	Window Property Get
// 02-02	->	Window Property Set
// 03-03	->	Window Methods
// 04-18	->	Standard Controls
// 19-20	->	ToolBar Child Buttons
// 21-33	->	Tab Child COntrols
// 34-48	->	SplitBox Child Controls
// 49-50	->	SplitBox Child ToolBar Buttons
	#xcommand DECLARE WINDOW <w> ;
	#xtranslate <w>	. \<p:Name,Title,Height,Width,Col,Row,NotifyIcon,NotifyToolTip,FocusedControl> => GetProperty ( <"w">, \<"p"\> )  ;;
	#xtranslate <w>	. \<p:Name,Title,Height,Width,Col,Row,NotifyIcon,NotifyToolTip,FocusedControl,Cursor> := \<n\> => SetProperty ( <"w">, \<"p"\> , \<n\> ) ;;
	#xtranslate <w>	. \<p:Activate,Center,Release,Maximize,Minimize,Restore,Show,Hide,SetFocus,Print,Capture> \[()\] => DoMethod ( <"w">, \<"p"\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:Value,Name,Value,Address,BackColor,FontColor,Picture,ToolTip,FontName,FontSize,FontBold,FontItalic,FontUnderline,FontStrikeOut,Caption,Row,DisplayValue,Col,Width,Height,Visible,Enabled,Checked,ItemCount,RangeMin,RangeMax,Position,CaretPos,ForeColor,AllowEdit,Object,InputItems,DisplayItems\> => GetProperty ( <"w">, \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:Value,Name,Value,Address,BackColor,FontColor,Picture,ToolTip,FontName,FontSize,FontBold,FontItalic,FontUnderline,FontStrikeOut,Caption,Row,DisplayValue,Col,Width,Height,Visible,Enabled,Checked,ItemCount,RangeMin,RangeMax,Position,CaretPos,ForeColor,AllowEdit,InputItems,DisplayItems\> := \<n\> => SetProperty ( <"w">, \<"c"\> , \<"p"\> , \<n\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:AllowAppend,AllowDelete,ReadOnly> => GetProperty ( <"w">, \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:AllowAppend,AllowDelete,ReadOnly> := \<n\> => SetProperty ( <"w">, \<"c"\> , \<"p"\> , \<n\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:Caption,Header,Item,Icon,HeaderImages> (\<arg\>) => GetProperty ( <"w">, \<"c"\> , \<"p"\> , \<arg\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:Caption,Header,Item,Icon,HeaderImages> (\<arg\>) := \<n\> => SetProperty ( <"w">, \<"c"\> , \<"p"\> , \<arg\> , \<n\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:Cell> (\<arg1\>,\<arg2\>) => GetProperty ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:Cell> (\<arg1\>,\<arg2\>) := \<n\> => SetProperty ( <"w">, \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\> , \<n\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:Refresh,SetFocus,DeleteAllItems,Release,Show,Save,Hide,Play,Stop,Close,Pause,Eject,OpenDialog,Resume,Action,OnClick> \[()\] => Domethod ( <"w">, \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:AddItem,DeleteItem,Open,DeletePage,DeleteColumn,Expand,Collapse,Seek> (\<a\>) => Domethod ( <"w">, \<"c"\> , \<"p"\> , \<a\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:AddItem,AddPage> (\<a1\> , \<a2\>) => Domethod ( <"w">, \<"c"\> , \<"p"\> , \<a1\> , \<a2\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:AddItem,AddPage> (\<a1\> , \<a2\> , \<a3\> ) => Domethod ( <"w">, \<"c"\> , \<"p"\> , \<a1\> , \<a2\> , \<a3\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:AddItem,AddColumn,AddControl\> (\<a1\> , \<a2\> , \<a3\> , \<a4\> ) => Domethod ( <"w">, \<"c"\> , \<"p"\> , \<a1\> , \<a2\> , \<a3\> , \<a4\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:Name,Length\> => GetProperty ( <"w">, \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. \<c\> . \<p:ReadOnly,Speed,Volume,Zoom\> := \<n\> => SetProperty ( <"w">, \<"c"\> , \<"p"\> , \<n\> ) ;;
	#xtranslate <w>	. \<x\> . \<c\> . \<p:Caption,Enabled,Value> => GetProperty ( <"w"> , \<"x"\> , \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. \<x\> . \<c\> . \<p:Caption,Enabled,Value> := \<n\> => SetProperty ( <"w"> , \<"x"\> , \<"c"\> , \<"p"\> , \<n\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:Value,Name,Value,Address,BackColor,FontColor,Picture,ToolTip,FontName,FontSize,FontBold,FontItalic,FontUnderline,FontStrikeOut,Caption,Row,DisplayValue,Col,Width,Height,Visible,Enabled,Checked,ItemCount,RangeMin,RangeMax,Position,CaretPos,ForeColor\> => GetProperty ( <"w">, \<"x"\> , \<k\> , \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:Value,Name,Value,Address,BackColor,FontColor,Picture,ToolTip,FontName,FontSize,FontBold,FontItalic,FontUnderline,FontStrikeOut,Caption,Row,DisplayValue,Col,Width,Height,Visible,Enabled,Checked,ItemCount,RangeMin,RangeMax,Position,CaretPos,ForeColor\> := \<n\> => SetProperty ( <"w"> , \<"x"\> , \<k\> , \<"c"\> , \<"p"\> , \<n\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:Caption,Header,Item,Icon> (\<arg\>) => GetProperty ( <"w">, \<"x"\> , \<k\> , \<"c"\> , \<"p"\> , \<arg\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:Caption,Header,Item,Icon> (\<arg\>) := \<n\> => SetProperty ( <"w">, \<"x"\> , \<k\> , \<"c"\> , \<"p"\> , \<arg\> , \<n\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:Refresh,SetFocus,DeleteAllItems,Release,Show,Save,Hide,Play,Stop,Close,Pause,Eject,OpenDialog,Resume,Action,OnClick\> \[()\] => Domethod ( <"w">, \<"x"\> , \<k\> , \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:AddItem,DeleteItem,Open,DeletePage,DeleteColumn,Expand,Collapse,Seek\> (\<a\>) => Domethod ( <"w">, \<"x"\> , \<k\> , \<"c"\> , \<"p"\> , \<a\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:AddItem,AddPage> (\<a1\> , \<a2\>) => Domethod ( <"w">, \<"x"\> , \<k\> , \<"c"\> , \<"p"\> , \<a1\> , \<a2\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:AddItem,AddPage> (\<a1\> , \<a2\> , \<a3\> ) => Domethod ( <"w">, \<"x"\> , \<k\> , \<"c"\> , \<"p"\> , \<a1\> , \<a2\> , \<a3\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:AddItem,AddColumn,AddControl> (\<a1\> , \<a2\> , \<a3\> , \<a4\> ) => Domethod ( <"w">, \<"x"\> , \<k\> , \<"c"\> , \<"p"\> , \<a1\> , \<a2\> , \<a3\> , \<a4\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:Name,Length> => GetProperty ( <"w">, \<"x"\> , \<k\> , \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:ReadOnly,Speed,Volume,Zoom> := \<n\> => SetProperty ( <"w">, \<"x"\> , \<k\> , \<"c"\> , \<"p"\> , \<n\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:Cell> (\<arg1\>,\<arg2\>) =>          GetProperty ( <"w">, \<"x"\> , \<k\> , \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\> ) ;;
	#xtranslate <w>	. \<x\> (\<k\>) . \<c\> . \<p:Cell> (\<arg1\>,\<arg2\>) := \<n\> => SetProperty ( <"w">, \<"x"\> , \<k\> , \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\> , \<n\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:Value,Name,Value,Address,BackColor,FontColor,Picture,ToolTip,FontName,FontSize,FontBold,FontItalic,FontUnderline,FontStrikeOut,Caption,Row,DisplayValue,Col,Width,Height,Visible,Enabled,Checked,ItemCount,RangeMin,RangeMax,Position,CaretPos,ForeColor,AllowEdit,Object,InputItems,DisplayItems\> => GetProperty ( <"w">, "SplitBox" , \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:Value,Name,Value,Address,BackColor,FontColor,Picture,ToolTip,FontName,FontSize,FontBold,FontItalic,FontUnderline,FontStrikeOut,Caption,Row,DisplayValue,Col,Width,Height,Visible,Enabled,Checked,ItemCount,RangeMin,RangeMax,Position,CaretPos,ForeColor,AllowEdit,InputItems,DisplayItems\> := \<n\> => SetProperty ( <"w">, "SplitBox" , \<"c"\> , \<"p"\> , \<n\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:AllowAppend,AllowDelete,ReadOnly> => GetProperty ( <"w">, "SplitBox", \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:AllowAppend,AllowDelete,ReadOnly> := \<n\> => SetProperty ( <"w">, "SplitBox", \<"c"\> , \<"p"\> , \<n\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:Caption,Header,Item,Icon,HeaderImages> (\<arg\>) => GetProperty ( <"w">, "SplitBox", \<"c"\> , \<"p"\> , \<arg\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:Caption,Header,Item,Icon,HeaderImages> (\<arg\>) := \<n\> => SetProperty ( <"w">, "SplitBox", \<"c"\> , \<"p"\> , \<arg\> , \<n\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:Cell> (\<arg1\>,\<arg2\>) => GetProperty ( <"w">, "SplitBox", \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:Cell> (\<arg1\>,\<arg2\>) := \<n\> => SetProperty ( <"w">, "SplitBox", \<"c"\> , \<"p"\> , \<arg1\> , \<arg2\> , \<n\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:Refresh,SetFocus,DeleteAllItems,Release,Show,Save,Hide,Play,Stop,Close,Pause,Eject,OpenDialog,Resume,Action,OnClick> \[()\] => Domethod ( <"w">, "SplitBox", \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:AddItem,DeleteItem,Open,DeletePage,DeleteColumn,Expand,Collapse,Seek> (\<a\>) => Domethod ( <"w">, "SplitBox", \<"c"\> , \<"p"\> , \<a\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:AddItem,AddPage> (\<a1\> , \<a2\>) => Domethod ( <"w">, "SplitBox", \<"c"\> , \<"p"\> , \<a1\> , \<a2\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:AddItem,AddPage> (\<a1\> , \<a2\> , \<a3\> ) => Domethod ( <"w">, "SplitBox", \<"c"\> , \<"p"\> , \<a1\> , \<a2\> , \<a3\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:AddItem,AddColumn,AddControl\> (\<a1\> , \<a2\> , \<a3\> , \<a4\> ) => Domethod ( <"w">, "SplitBox", \<"c"\> , \<"p"\> , \<a1\> , \<a2\> , \<a3\> , \<a4\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:Name,Length\> => GetProperty ( <"w">, "SplitBox", \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. SplitBox . \<c\> . \<p:ReadOnly,Speed,Volume,Zoom\> := \<n\> => SetProperty ( <"w">, "SplitBox", \<"c"\> , \<"p"\> , \<n\> ) ;;
	#xtranslate <w>	. SplitBox . \<x\> . \<c\> . \<p:Caption,Enabled,Value> => GetProperty ( <"w"> , "SplitBox" , \<"x"\> , \<"c"\> , \<"p"\> ) ;;
	#xtranslate <w>	. SplitBox . \<x\> . \<c\> . \<p:Caption,Enabled,Value> := \<n\> => SetProperty ( <"w"> , "SplitBox", \<"x"\> , \<"c"\> , \<"p"\> , \<n\> )
	#xcommand DEFINE WINDOW <w> ;
			AT <row>,<col> ;
			WIDTH <wi> ;
			HEIGHT <h> ;
			[ VIRTUAL WIDTH <vWidth> ] ;
			[ VIRTUAL HEIGHT <vHeight> ] ;
			[ TITLE <title> ] ;
			[ ICON <icon> ] ;
			[ <main:  MAIN> ] ;
			[ <child: CHILD> ] ;
			[ <noshow: NOSHOW> ] ;
			[ <topmost: TOPMOST> ] ;
			[ <noautorelease: NOAUTORELEASE> ] ;
			[ <nominimize: NOMINIMIZE> ] ;
			[ <nomaximize: NOMAXIMIZE> ] ;
			[ <nosize: NOSIZE> ] ;
			[ <nosysmenu: NOSYSMENU> ] ;
			[ <nocaption: NOCAPTION> ] ;
			[ CURSOR <cursor> ] ;
			[ ON INIT <InitProcedure> ] ;
			[ ON RELEASE <ReleaseProcedure> ] ;
			[ ON INTERACTIVECLOSE <interactivecloseprocedure> ] ;
			[ ON MOUSECLICK <ClickProcedure> ] ;
			[ ON MOUSEDRAG <MouseDragProcedure> ] ;
			[ ON MOUSEMOVE <MouseMoveProcedure> ] ;
			[ ON SIZE <SizeProcedure> ] ;
			[ ON MAXIMIZE <MaximizeProcedure> ] ;
			[ ON MINIMIZE <MinimizeProcedure> ] ;
			[ ON PAINT <PaintProcedure> ] ;
		        [ BACKCOLOR <backcolor> ] ;
			[ FONT <FontName> SIZE <FontSize> ] ;
			[ NOTIFYICON <NotifyIcon> ] ;
			[ NOTIFYTOOLTIP <NotifyIconTooltip> ] ;
			[ ON NOTIFYCLICK <NotifyLeftClick> ] ;
			[ ON GOTFOCUS <GotFocusProcedure> ] ;
			[ ON LOSTFOCUS <LostFocusProcedure> ] ;
			[ ON SCROLLUP <scrollup> ] ;
			[ ON SCROLLDOWN <scrolldown> ] ;
			[ ON SCROLLLEFT <scrollleft> ] ;
			[ ON SCROLLRIGHT <scrollright> ] ;
			[ ON HSCROLLBOX <hScrollBox> ] ;
			[ ON VSCROLLBOX <vScrollBox> ] ;
			[ <helpbutton:  HELPBUTTON> ] ;
	DECLARE WINDOW <w>  ;;
	DECLARE CUSTOM COMPONENTS <w> ;;
	_DefineWindow ( <"w">, <title>, <col>, <row>, <wi>, <h>, <.nominimize.>, <.nomaximize.>, <.nosize.>, <.nosysmenu.>, <.nocaption.>,.F., '',<{InitProcedure}>, <{ReleaseProcedure}> , <{MouseDragProcedure}>, <{SizeProcedure}> , <{ClickProcedure}> , <{MouseMoveProcedure}>, <backcolor> , <{PaintProcedure}> , <.noshow.> , <.topmost.> , <.main.> , <icon> , <.child.> , <FontName> , <FontSize>, <NotifyIcon> , <NotifyIconTooltip> , <{NotifyLeftClick}>  , <{GotFocusProcedure}>, <{LostFocusProcedure}> , <vHeight> , <vWidth> , <{scrollleft}> , <{scrollright}> , <{scrollup}> , <{scrolldown}> , <{hScrollBox}> , <{vScrollBox}> , <.helpbutton.> , <{MaximizeProcedure}> , <{MinimizeProcedure}> , <cursor> , <.noautorelease.> , <{interactivecloseprocedure}> )
			AT <row>,<col> ;
			WIDTH <wi> ;
			HEIGHT <h> ;
			[ TITLE <title> ] ;
			[ ICON <icon> ] ;
			MODAL ;
       _DefineModalWindow ( <"w">, <title>, <col>, <row>, <wi>, <h>, "" , <.nosize.>, <.nosysmenu.>, <.nocaption.> ,.F., '',<{InitProcedure}>, <{ReleaseProcedure}> , <{MouseDragProcedure}> , <{SizeProcedure}> , <{ClickProcedure}> , <{MouseMoveProcedure}>, [<backcolor>]  , <{PaintProcedure}> , <icon> , <FontName> , <FontSize> , <{GotFocusProcedure}>, <{LostFocusProcedure}> , <vHeight>  , <vWidth>  , <{scrollleft}> , <{scrollright}> , <{scrollup}> , <{scrolldown}> , <{hScrollBox}> , <{vScrollBox}>  , <.helpbutton.> , <cursor> , <.noshow.>  , <.noautorelease.>  , <{interactivecloseprocedure}> )
		WIDTH <wi> ;
		HEIGHT <h> ;
		[ TITLE <title> ] ;
		SPLITCHILD ;
		[ GRIPPERTEXT <grippertext> ] ;
		[ <break: BREAK> ] ;
		[ <focused: FOCUSED> ] ;
	_DefineSplitChildWindow ( <"w">, <wi>, <h> , <.break.> , <grippertext> , <.nocaption.> , <title> , <FontName> , <FontSize> , <{GotFocusProcedure}>, <{LostFocusProcedure}> , <vHeight>  , <vWidth> , <.focused.>  , <{scrollleft}> , <{scrollright}> , <{scrollup}> , <{scrolldown}> , <{hScrollBox}> , <{vScrollBox}> , <cursor> ) ;;
	#xcommand LOAD WINDOW <w> ;
	_HMG_SYSDATA \[ 214 \] := <"w"> ;;
	#include \<<w>.fmg\>
	#xcommand LOAD WINDOW <ww> AS <w> ;
	_HMG_SYSDATA \[ 214 \] := <"w"> ; #include \<<ww>.fmg\>
#command RELEASE WINDOW <name> ;
	DoMethod ( <"name"> , 'Release' )
#command RELEASE WINDOW ALL  ;
	ReleaseAllWindows()
#command RELEASE WINDOW MAIN  ;
	ReleaseAllWindows()
#xtranslate EXIT PROGRAM  ;
	ReleaseAllWindows()
#command ACTIVATE WINDOW <name, ...> ;
    _ActivateWindow ( \{<"name">\} )
#command ACTIVATE WINDOW ALL ;
    _ActivateAllWindows()
#command CENTER WINDOW <name> ;
	DoMethod ( <"name"> , 'Center' )
#command MAXIMIZE WINDOW <name> ;
	DoMethod ( <"name"> , 'Maximize' )
#command MINIMIZE WINDOW <name> ;
	DoMethod ( <"name"> , 'Minimize' )
#command RESTORE WINDOW <name> ;
	DoMethod ( <"name"> , 'Restore' )
#command SHOW WINDOW <name> ;
	DoMethod ( <"name"> , 'Show' )
#command HIDE WINDOW <name> ;
	DoMethod ( <"name"> , 'Hide' )
#command END WINDOW ;
_EndWindow ()
#xcommand DO EVENTS => ProcessMessages()
#xtranslate FETCH [ PROPERTY ] [ WINDOW ] <Arg1> <Arg2> TO <Arg3> ;
<Arg3> := GetProperty ( <"Arg1"> , <"Arg2"> )
#xtranslate MODIFY [ PROPERTY ] [ WINDOW ] <Arg1> <Arg2> <Arg3> ;
SetProperty ( <"Arg1"> , <"Arg2"> , <Arg3> )
#command DEFINE WINDOW TEMPLATE ;
			AT <row>,<col> ;
			WIDTH <wi> ;
			HEIGHT <h> ;
			[ TITLE <title> ] ;
			[ ICON <icon> ] ;
			[ <main:  MAIN> ] ;
	_DefineWindow ( , <title>, <col>, <row>, <wi>, <h>, <.nominimize.>, <.nomaximize.>, <.nosize.>, <.nosysmenu.>, <.nocaption.>,.F., '',<{InitProcedure}>, <{ReleaseProcedure}> , <{MouseDragProcedure}>, <{SizeProcedure}> , <{ClickProcedure}> , <{MouseMoveProcedure}>, [<backcolor>] , <{PaintProcedure}> , <.noshow.> , <.topmost.> , <.main.> , <icon> , <.child.> , <FontName> , <FontSize>, <NotifyIcon> , <NotifyIconTooltip> , <{NotifyLeftClick}>  , <{GotFocusProcedure}>, <{LostFocusProcedure}> , <vHeight> , <vWidth> , <{scrollleft}> , <{scrollright}> , <{scrollup}> , <{scrolldown}> , <{hScrollBox}> , <{vScrollBox}> , <.helpbutton.> , <{MaximizeProcedure}> , <{MinimizeProcedure}> , <cursor>  , <.noautorelease.>  , <{interactivecloseprocedure}> )
			AT <row>,<col> ;
			WIDTH <wi> ;
			HEIGHT <h> ;
			[ TITLE <title> ] ;
			[ ICON <icon> ] ;
			MODAL ;
	_DefineModalWindow ( , <title>, <col>, <row>, <wi>, <h>, "" , <.nosize.>, <.nosysmenu.>, <.nocaption.> ,.F., '',<{InitProcedure}>, <{ReleaseProcedure}> , <{MouseDragProcedure}> , <{SizeProcedure}> , <{ClickProcedure}> , <{MouseMoveProcedure}>, [<backcolor>]  , <{PaintProcedure}> , <icon> , <FontName> , <FontSize> , <{GotFocusProcedure}>, <{LostFocusProcedure}> , <vHeight>  , <vWidth>  , <{scrollleft}> , <{scrollright}> , <{scrollup}> , <{scrolldown}> , <{hScrollBox}> , <{vScrollBox}> , <.helpbutton.> , <cursor> , <.noshow.>  , <.noautorelease.>  , <{interactivecloseprocedure}> )
#xcommand  DEFINE WINDOW TEMPLATE ;
		WIDTH <wi> ;
		HEIGHT <h> ;
		[ TITLE <title> ] ;
		SPLITCHILD ;
	_DefineSplitChildWindow ( , <wi>, <h> , <.break.> , <grippertext> , <.nocaption.> , <title> , <FontName> , <FontSize> , <{GotFocusProcedure}>, <{LostFocusProcedure}> , <vHeight>  , <vWidth> , <.focused.>  , <{scrollleft}> , <{scrollright}> , <{scrollup}> , <{scrolldown}> , <{hScrollBox}> , <{vScrollBox}> , <cursor> ) ;;
#xcommand  SET TOOLTIPSTYLE BALLOON ;
	_HMG_SYSDATA \[55\] := .T.
#xcommand  SET TOOLTIPSTYLE STANDARD ;
	_HMG_SYSDATA \[55\] := .F.
#xcommand  SET TOOLTIPBACKCOLOR <aColor> ;
	_HMG_SYSDATA \[56\] := <aColor>
#xcommand  SET TOOLTIPFORECOLOR <aColor> ;
	_HMG_SYSDATA \[57\] := <aColor>
Re: HMG 2.6.6
Roberto,
Thanks a lot for prompt fix!
It seems that all is OK now :!:
I have one more suggestion for backward compatibility of containers row/col with old behaviour.
Please be so kind to replace the following two functions as below
Function _GetControlRow ( ControlName, ParentForm )
   Local mVar , i , nRet
   mVar := '_' + ParentForm + '_' + ControlName
   i := &mVar
   if i == 0 .Or. ( ValType ( _HMG_SYSDATA [ 18 ] [i] ) == 'U' .And. ValType ( _HMG_SYSDATA [ 19 ] [i] ) == 'U' )
      Return 0
   EndIf
   If _HMG_SYSDATA [ 23 ] [ i ] == - 1
      nRet := _HMG_SYSDATA [ 18 ] [ i ]
   Else
      nRet := _HMG_SYSDATA [ 18 ] [ i ] - _HMG_SYSDATA [ 23 ] [ i ]
   EndIf
Return nRet
Function _GetControlCol ( ControlName, ParentForm )
   i := &mVar
      Return 0
   EndIf
   If _HMG_SYSDATA [ 24 ] [ i ] == - 1
      nRet := _HMG_SYSDATA [ 19 ] [ i ]
   Else
      nRet := _HMG_SYSDATA [ 19 ] [ i ] - _HMG_SYSDATA [ 24 ] [ i ]
   EndIf
Return nRet
Re: HMG 2.6.6
Roberto,
   i := &mVar
      Return 0
   EndIf
   Else
   EndIf
Return nRet
   i := &mVar
      Return 0
   EndIf
   Else
   EndIf
Return nRet
Grigory,
At first thanks for the report and the sample.
Looking at your 'row/col' code I guess that there is problems returning
values for tab child controls when using new full container syntax.
I'll check it ASAP.
Any other (additional) info is welcome.
Thanks again.
Re: HMG 2.6.6
Roberto Lopez wrote:<...>
I'll check it ASAP.
Roberto,
Thanks for your kind words!
There are not a problems with values for tab child controls yet.
But an incompatibility exists for old codes which are used zero value of row/col for containers self.
:o
Re: HMG 2.6.6
gfilatov wrote: There are not a problems with values for tab child controls yet.
:o
Could you be so kind to post a little sample showing what exactly the problem is ? (I'm not sure of fully understand the situation).
Thanks in advance.
