QUIT problem
fprijatelj
Re: QUIT problem
Post by fprijatelj »
Hi
This is possible solution:
Put this directive in myCommands.ch
#xtranslate QUIT => CLOSE ALL ; RELEASE WINDOW ALL
then include myCommand.ch in your prg files:
#include myCommand.ch
And you can safely use QUIT command.
Maybe this directive should be put in one of the system ch files (i_misc.ch) ?
BRGDS
Franček
Re: QUIT problem
Thanks Esgici
but in programming I am still a baby calf :lol:
Fprijatelj, very professional your code
greetings to all
Claudio
Re: QUIT problem
Nice solution, Franček :)
May be our Maestro will put it official headers file of HMG.
Claudio,
IMO, regarding your previous work, ( puzzle game ), you are a very robust bull in programing :)
(low level approach to high level needs; such as multi language feature changeable at run time etc)
Saludos and Regards
Re: QUIT problem
Esgici,
thanks for your words.
Best regards
Claudio
Re: QUIT problem
fprijatelj wrote:Hi
BRGDS
Franček
I'll add to hmg.ch.
Thanks.
Re: QUIT problem
fprijatelj wrote:Hi
BRGDS
Franček
I've already fixed. The fix will be available in 3.0.26.
It is based on your suggestion.
I've only omitted the CLOSE ALL command, since RELEASE WINDOW ALL command invokes the ReleaseAllWindows() function that includes a call to dbcloseall().
Steed
Re: QUIT problem
Post by Steed »
Hi, Roberto
Something is happend with command QUIT i think is overlaped the commad oExcel:Quit(), attached please find a little example. the error that these show is: Test.prg(52) Error E0030 Syntax error "syntax error at 'WINDOW'"
Ed
Hola Roberto,
Algo esta pasando con el comando QUIT , creo que esta traslapando el comando oExcel:Quit(), adjunto un pequeño ejemplo, el error que muestras es:
Saludos,
Ed
oExcel1.zip
(2.01 KiB) Downloaded 293 times
Re: QUIT problem
Hi Ed
Are you sure Quit() is a valid OLE (Excel Class) method ?
Does may be Close() ?
Regards, saludos
Re: QUIT problem
Steed wrote:Hi, Roberto
Ed
Hola Roberto,
Saludos,
Ed
I'll check it ASAP.
Thanks for reporting.
Steed
Re: QUIT problem
Post by Steed »
Hi, Esqici
Off course, the command is oExcel:Quit
BTW, Roberto i put a small update in the sample, in the same link of the first post.
Eduar
