HMG 3.0.20 Final Release
Re: HMG 3.0.20 Final Release
I think, something is wrong with GRID control when used to browse database.
Try to add and delete some records.
Empty rows appear in grid.
Strange effects when clicking in the grid...
- etykiety.zip
- (13.04 KiB) Downloaded 275 times
Maravilloso el trabajo que está realizando.
Muy agradecido
Rafael Pérez
Muy agradecido
Rafael Pérez
- HMG Founder
Ok.mol wrote:I think, something is wrong with GRID control when used to browse database.
I've not documented (I've forgot it) but, at the moment, data-bound grid DOES NOT SUPPORT the use of SET FILTER and SET DELETED commands.
Your sample uses SET DELETED, that is the problem.
Thank You Roberto, this it´s a great versión.Roberto Lopez wrote:Hi All,
Here we are... some months and 19 test releases later, the 3.0(.20) final release is here.
Saludos, Fernando Chirico.
Gracias Roberto. Es impagable tu trabajo.
Un abrazo
Un abrazo
ClaudioGalera
Thanks Master for this great release
Hi Roberto,
I had used virtual grid in one of my projects today. I am really astonished to see the results. It is amazing! The speed is just unimaginable.
However, I could not use gridprint.
I think I have to modify the gridprint code accordingly.
- HMG Founder
Ok.rathinagiri wrote:Hi Roberto,
However, I could not use gridprint.I think I have to modify the gridprint code accordingly.
I guess that the problem is how to get the data for a specific cell.
You have some different ways to do it.
The most straight way (if you refer to a grid bound to a table) is as follows:
GetDataGridCellData ( nControlIndex , lTrueData)Code: Select all
nControlIndex := GetControlIndex ( cControlName , cWindowName) If you want to retrieve the cell content for a non-data-bound grid, you must execute the same procedure as you execute for the OnQueryData procedure but tricking it to pass to it the required logical row and column.
Thanks Roberto. This will return the current cell content. I want to go through all the cells one by one in a loop.
