HMG 3.0 FORUM TEST XVI
Re: HMG 3.0 FORUM TEST XVI
Hi
New Turkish language file attached.
Turkish.rar
Turkish Language File for HMG-IDE 3.00 Test XVI
(3.2 KiB) Downloaded 263 times
Vanguarda wrote:Hello friends,
Master i´ve update the file PtBR.LNG for HMG-IDE. Please so kind, replace it on official distribution.
The line 296 is translated now.
My best regards,
PS: Sorry my bad english.
THANKS!
esgici wrote:Hi
Turkish.rar
THANKS!
Roberto Lopez wrote:Deleted records can't be edited and are shown in light gray
FontColor.
Los registros marcados para eliminación no pueden ser editados y
se mostrarán en color gris claro.
I need to display these deleted records with another color. Is it possible ? I do not want gray color, I wish in red color.
Preciso que muestre los registros deletados con otro color. Es posible esto ? No quiero el color gris, quisiera el color rojo en cambio.
Leopoldo Blancas
Post by Leopoldo Blancas »
Gracias Roberto...
(Su link me manda a una pagina vacia y solo dice error 404)
Polo
Leopoldo Blancas wrote:Gracias Roberto...
Polo
Polo : no existe porque es la version 3.0 y estamos en la 3.1.1 si necesitas una de las viejas versiones solo tiene que ir a
http://hmgforum.com/site/index.php?opti ... s&Itemid=2
FontColor.
Probably I can get this by DYNAMICBACKCOLOR and DYNAMICFORECOLOR ? I saw something but I did not found it. Somebody could help me, please ?
Leopoldo Blancas
OK daniel... gracias.
Pablo César wrote:
FontColor.
I found it !!! :D
As I already said much before, some colors changing must be declared as CONSTANT for the good order. Then I made this:
In place of this (in Spanish: En lugar de esto)
Local fColor := { || if ( deleted() , RGB( 255, 0, 0 ) , RGB( 255, 255, 255 ) ) }
@ ... GRID ;
   DYNAMICFORECOLOR aFColor ;
I replaced for this: (in Spanish: Substituí por esto:)
#define MY_RED          {224,38,16}
Local fColor := { || if ( deleted() , MY_RED , BLACK ) }
@ ... GRID ;
So it has worked pretty well !!! :D All for HMG strength !!
--- Traducido para el español
Encontré la solucion !!
Como habia mencionando há tiempo atrás, algunos cambios de colores deben hacerse por medio de declaracion de CONSTANTEs para que tenga efecto. Es ratro ese comportamiento, pero funciona cuando se utiliza el # Define.
Paso a relatar como hice.
...//... codigo en evidencia ...
Y asi funciona perfectamente !!! Alguién ya pasó por esto ?
dhaine_adp
Post by dhaine_adp »
Hi Rathi,
I'm getting error code 404 in trying to download HMG 300 Test16.
TIA.
Danny
Manila, Philippines
