Useful UDF (User defined functions)
Re: Useful UDF (User defined functions)
Hi friends,
Thanks Rathi and Mol for this nice function. Great work.
My best regards,
My best regards,
Hello All,
Here is a very simple function for ComboBox.
You can use it like:
This function can be used with DBF tables also
Function Cbo2Code(mCboVal, aCode)
local i
if mCboVal = 0 .or. mCboVal > len(aCode)
return 0
return (aCode[mCboVal])Code: Select all
aCust := SQL(mDb, "select Custid, Custnm from Cust order by Custnm")
aeval(aCust, {|x| aadd(aCustId, x[1]), aadd(aCustNm, x[2])})
// aCustnm will be used with combobox, cboCustid
mCustId := Cbo2Code(frmSale.cboCustid.value, aCustId)
I'm searching good working function for archiving data (rg. whole folder with application and data files).
Maybe sb. has such a function created with hmg and want to share it?
If not, I'll try to write it.
Marek
Marek
Hello Marek,
I wrote a small app. But it used low level functions and also some extra library. I am sure original HMG functions also do the same thing.
Please check at viewtopic.php?f=15&t=440
I used one function called Dbf_menu(), for lookup data in my Clipper days, originally written by ex-boss Anando Banerjee. I changed it many times and later when I started using gtwvw, I completely re-wrote the function with tBrowse class, but the name of the function remained same. Today, I created the same function with MUCH LESS CODE using HMG. I tested it by using Array RDD. Result is very good. Many thanks to Master Roberto Lopez for the latest improvement of Grid control (I used some of your codes also from Grid.26 sample)
Using this function is very easy.
There are lots of TO DO-s for this function.
Please send your comments regarding this
Function dbf_menu(mAlias, aHeader, aWidth, aFieldnm, abDynamicDisplay)
local mOldRecno, lRecChanged := .f.
mOldRecno := if((mAlias)->(eof()), 0, (mAlias)->(recno()))
DEFINE WINDOW frmDbf_menu ;
WIDTH 640 ;
HEIGHT 460 ;
TITLE 'Find' ;
MODAL
@ 10,10 GRID Grid_1 ;
WIDTH 610 ;
HEIGHT 380 ;
HEADERS aHeader ;
WIDTHS aWidth;
ROWSOURCE mAlias ;
COLUMNFIELDS aFieldNm ;
DYNAMICDISPLAY abDynamicDisplay ;
value {(mAlias)->(recno()), 1}
@ 400, 150 button cmdOk caption "&Ok" action {|| lRecChanged := .t., frmDbf_menu.release()}
@ 400, 390 button cmdCancel caption "&Cancel" action frmDbf_menu.release()
on key ESCAPE of frmDbf_menu action frmDbf_menu.release()
CENTER WINDOW frmDbf_menu
ACTIVATE WINDOW frmDbf_menu
if !lRecChanged
if mOldRecno > 0
(mAlias)->(dbgoto(mOldRecno))
Return nil
Static Function FindSale()
dbf_menu("tempsale", {"Inv Dt", "Inv No", "Amount"}, {100, 100, 100}, {"invdt", "invno", "netamt"})
thiswindow.setfocus()
RefreshData()
return nil Please send your comments regarding this
Great Sudip. So nice. Thanks for sharing.
I want to post here function, which can be an alternative for InputWindow.
I don't know, if this function will work in future version of HMG, but works OK in 3.0.20
and a little sample, how to call it:
function OknoWprowadzaniaDanych
param cWindowTitle, aLabels, aInitialValues, aLengths, aInputMasks, aConvertToUpper, aJust, aResults
local nWysokosc, nSzerokosc, i
local xType , cNazwa , nMaxLength := NIL, lUpper, lLower
local lNumeric, lPassword := .f., uLostFocus := NIL, uGotFocus := NIL
local uChange := NIL, uEnter := NIL, lRight, HelpId := NIL
local lReadOnly := .f., lBold := .f., lItalic := .f., lUnderline := .f., lStrikeout := .f.
local field := NIL
local aBackColor := {255,255,255}
local aFontColor := {0,0,0}
local lInvisible := .f.
local lNotabstop := .f.
private nLiczbaPol
Private lOK := .f.
// aJust - contains values: 0 - for left align, 1 for right align
// function returns .T. when OK button is pressed, .F. when CANCEL
// return values are copied to aResults
nLiczbaPol := len(aLabels)
nSzerokosc := 300
for i:= 1 to nLiczbaPol
nSzerokosc := max(nSzerokosc, aLengths[i])
next i
nSzerokosc := min(800,nSzerokosc)
nWysokosc := 130 + 50*nLiczbaPol
nWysokosc := min(500,nWysokosc)
DEFINE WINDOW MOL_OknoWprowadzaniaDanych ;
ROW 0 ;
COL 0 ;
WIDTH min(800,nSzerokosc) ;
HEIGHT min(500,nWysokosc) ;
TITLE cWindowTitle ;
MODAL
for i:=1 to nLiczbaPol
cLbl := "Lbl_"+strzero(i,2);
@ 20+(i-1)*50 , 10 LABEL &cLbl ;
VALUE aLabels[i] ;
WIDTH 200 ;
HEIGHT 18 ;
FONT "Arial" SIZE 10 BOLD;
TRANSPARENT
xType := valtype(aInitialValues[i])
cNazwa :="T_"+strzero(i,2)
do case
case xType == "N"
nMaxLength := len(str(aInitialValues[i]))
case xType == "D"
nMaxLength := 8
otherwise
nMaxLength := len(hb_valtoExp(aInitialValues[i]))
endcase
lUpper := aConvertToUpper[i]
lLower := !lUpper
lNumeric := (xType = "N")
lPassword := .f.
uLostFocus := NIL
uGotFocus := NIL
uChange := NIL
uEnter := NIL
lright := aJust[i] == 1 // domyślnie numeryczne pola do prawej
HelpId := NIL
lReadOnly := .f.
lBold := .f.
lItalic := .f.
lUnderline := .f.
lStrikeout := .f.
field := NIL
lInvisible := .f.
lNotabstop := .f.
if len(aInputMasks[i]) > 0
if xType == "N"
_DefineMaskedTextBox ( cNazwa, "MOL_OknoWprowadzaniaDanych", 30, 38+(i-1)*50,aInputMasks[i],;
aLengths[i] , aInitialValues[i], "ARIAL CE", 12, "" ,;
uLostFocus, uGotFocus, uChange ,;
24 , uEnter , lRight ,;
helpid , "" ,lBold, lItalic, lUnderline, ;
lStrikeout , field , aBackColor , aFontColor ,;
lReadOnly, lInvisible , lNotabstop )
elseif xType == "C"
_DefineCharMaskTextBox ( cNazwa, "MOL_OknoWprowadzaniaDanych", 30, 38+(i-1)*50,aInputMasks[i],;
helpid , lBold, lItalic, lUnderline, ;
.f., lReadOnly, lInvisible , lNotabstop )
if xType == "D"
_DefineCharMaskTextBox ( cNazwa, "MOL_OknoWprowadzaniaDanych", 30, 38+(i-1)*50,"",;
.t., lReadOnly, lInvisible , lNotabstop )
_DefineTextBox( cNazwa, "MOL_OknoWprowadzaniaDanych", 30, 38+(i-1)*50, aLengths[i], 24, ;
aInitialValues[i], "ARIAL CE", 12, "", nMaxLength, ;
lUpper, lLower, lNumeric, lPassword, ;
uLostFocus, uGotFocus, uChange , uEnter , lRight , ;
HelpId , lReadonly , lBold, lItalic, lUnderline, ;
lStrikeout , field , aBackColor , aFontColor , ;
next i
// PRZYCISKI
@ nWysokosc - 80, nSzerokosc/2 - 120 BUTTON P_OK ;
CAPTION "OK" ;
ACTION (AEval(aResults, { | cValue, nIndex| aResults[nIndex] := GetProperty("Mol_OknoWprowadzaniaDanych","T_"+strzero(nIndex,2),"value") } ,1, nLiczbaPol),;
lOK := .t. , MOL_OknoWprowadzaniaDanych.Release );
WIDTH 100 HEIGHT 28
@ nWysokosc - 80, nSzerokosc/2 + 20 BUTTON P_CANCEL ;
CAPTION "Anuluj" ;
ACTION {|| lOK := .f., Mol_OknoWprowadzaniaDanych.Release} ;
WIDTH 100 HEIGHT 28
aResults := array(nLiczbaPol)
ON KEY ESCAPE OF MOL_OknoWprowadzaniaDanych ACTION (MOL_OknoWprowadzaniaDanych.Release , lOK := .f.)
center window MOL_OknoWprowadzaniaDanych
activate window MOL_OknoWprowadzaniaDanych
return lOK
aRes := {}
lRet := OknoWprowadzaniaDanych("A little sample of new InputWindow",{"Customer Name ","Customer Address","Customer ID","any other numeric ID","Date of test"} , ;
{"name of customer for editing",space(40),space(10), 123, date() },;
{200,200,80,100,100},;
{ "","","P-999","9999",""},;
{.t.,.f.,.t.,.f.,.f.},;
{0,0,0,1,1},;
@aRes)
Great Mol.
It will be useful for me since you have used date text box instead of standard date picker.
Standard date picker increases two key strokes extra.
Hello All,
Some days ago our friend Rathi created a sample to show how to add items in a list of a combo box of a grid. Today I changed a few codes so that it can be used for refreshing combobox list of a grid. Here "acList" is an array of character strings.
Thank you Rathi
function RefreshGridEditComboItem ( cGridName, cWindowName, nColIndex, acList )
local i := GetControlIndex ( cGridName, cWindowName )
local aEditcontrols := _HMG_SYSDATA [ 40 ] [ i ] [ 2 ]
aEditControls [nColIndex] [2] := {}
aeval(aclist, {|x| aadd(aEditControls [nColIndex] [2], x)})
_HMG_SYSDATA [ 40 ] [ i ] [ 2 ] := aEditControls
return nilWith best regards.
Great Sudip.
