Page 2 of 3
Re: A Funny Thing Happened In The Way To The Browse :)
Posted: Sun Jan 03, 2010 10:11 pm
by Roberto Lopez
rathinagiri wrote:Unfortunately I can't compile the samples.
This is the error log.
hbmk2: Processing configuration: C:\hmg\harbour\bin\hbmk.cfg[/quote]
mmm... I've changed high level (.prg) code only.
Your linker error messages looks like you are using libraries compiled with different Harbour versions.
Since it worked for Ricci, I guess that the problem is in your system. Please, check it.
Posted: Mon Jan 04, 2010 2:39 am
Ok Roberto. I will check.
Posted: Mon Jan 04, 2010 2:35 pm
It's just fantastic. Thanks Roberto!
Posted: Mon Jan 04, 2010 3:24 pm
by sudip
Hello Master Roberto,
Excellent work
Thanks a lot
I don't know whether I made any mistake or not. I tried to add a record. Type "100001" in the first column. After pressing enter key, it took me to the 2nd column. Then I typed something instead of pressing enter again. And it took me to the top of the grid.
With best regards.
Posted: Mon Jan 04, 2010 3:25 pm
by Roberto Lopez
rathinagiri wrote:It's just fantastic. Thanks Roberto!
The better part is just coming
Posted: Mon Jan 04, 2010 3:26 pm
by Roberto Lopez
sudip wrote:Hello Master Roberto,
Excellent work
Thanks a lot
With best regards.
Please, indicate the exact steps you made and the results in each one.
Thanks.
Posted: Mon Jan 04, 2010 3:40 pm
by sudip
I ran the program and press Alt+A. Then typed 100001 in the first column and pressed enter (following image)
- 001.jpg (124.49 KiB) Viewed 4498 times
Then I typed some letters eg., "asdf" and the grid took me to the top! (following image)
- 002.jpg (108.81 KiB) Viewed 4498 times
I can't understand what I made mistake
With best regards.
Posted: Mon Jan 04, 2010 3:42 pm
by sudip
Roberto Lopez wrote:rathinagiri wrote:It's just fantastic. Thanks Roberto!
Great news
With best regards.
Posted: Mon Jan 04, 2010 4:02 pm
by Roberto Lopez
I ran the program and press Alt+A. Then typed 100001 in the first column and pressed enter (following image)...
This behavior is by design
The new added record behaves the same as any other record, so to edit a selected cell you must press <enter> first.
The other thing (pressing a key leaves you to the first record is a BIG BUG
Thanks for reporting!
Posted: Mon Jan 04, 2010 4:25 pm
Please publish a new "clean", (full setup) version, if possible.
I have some difficulties and can't succeed installing and using data grid
Best regards
