DBF Viewer
Re: DBF Viewer
MigSoft wrote:
In the future we can all keep adding new features. :P
I'll wait eagerly; especially multiple RDD support, because DBA doesn't have and because many people need it :)
Re: DBF Viewer
MigSoft wrote:Hi Sudip,
Very interesting. How so :?: :roll:
MigSoft
Here is very humble code, which may be helpful for this viewtopic.php?f=15&t=284
JALMAG
DBs Used: DBF, MariaDB
Re: DBF Viewer
Post by JALMAG »
MigSoft wrote:Hello everyone,
"dbfview" is an application that is a mixture of code provided by our friends Rathinagiri, Grigory Filatov and an adaptation of sample "contactos" by Roberto Lopez.
I hope it serves as a starting point of a tool for viewing files DBF.
Miguel Angel Juárez A.
Compile with IDE :P
Hola Miguel Angel, lo veo bastante completo, ahora bien ¿Con qué IDE y versión se compila?, con el de HMG, el de Minigui...
Gracias anticipadas.
nguyenchiduc
Re: DBF Viewer
Post by nguyenchiduc »
Today, I run this program. Very good
Notice to read file on the intranet, multi-user. In line 92 of file dbfview.prg :
IF !Empty(aNewFile)
      Use (aNewFile[1]) New  /*Note */
      _DBULastPath := curdrive()+':\'+CurDir()+'\'
      If !Used(aNewFile[1])
         /* MsgInfo("Unable open file: "+aNewFile[1],PROGRAM) */
         Use (aNewFile[1]) New shared  /* Note */
         oWndBase.Title := PROGRAM+VERSION+COPYRIGHT+aNewfile[1]
         cBase := Alias()
         nCamp := Fcount()
         aEst  := DBstruct()
         aNomb := {'iif(deleted(),0,1)'} ; aJust := {0} ; aLong := {0}
         For i := 1 to nCamp
             aadd(aNomb,aEst[i,1])
             aadd(aJust,iif(aEst[i,2]=='N',1,0))
             aadd(aLong,Max(100,Min(160,aEst[i,3]*14)))
         Next
         CreaBrowse( cBase, aNomb, aLong, aJust, .F. )
      Else
         cBase := Alias()
         nCamp := Fcount()
         aEst  := DBstruct()
         For i := 1 to nCamp
         Next
      Endif
   Else
      cBase := ''
   Endif
This application is useful and convenient but there is a weakness of HMG3 system are:
For files with multiple records, use the command "SET FITLER TO..." displayed on the screen very slowly.
Because the workstations can be Win9x, RAM and CPU is less
Hopefully, the developers of HMG4, note to the application can work in general, many users not only in handling cases of personal computers.
Tristan
Re: DBF Viewer
Post by Tristan »
I need utility to make dbf file & cdx index, where i can find it?
Thanks,
Tristan
Re: DBF Viewer
Tristan wrote:Hi All,
Thanks,
Tristan
Hola Tristan:
puedes generar DBF´s desde el IDE de HMG.
Hello Tristan:
DBF can generate the IDE's from HMG.
Para los indices CDX, agrega a tu fuente :
For the CDX indices, add to your Code:
 REQUEST DBFCDX, DBFFPT
   RDDSETDEFAULT ("DBFCDX"
arma tus indices segun tu necesidad:
kick up your indexes according to your need:
 Cpathbases  :=cDisco+ "seguros\bases\"+"tipos"
 CPathindices:=cDisco+ "seguros\indices\"+"tipos"
 use &Cpathbases VIA "DBFCDX"
 INDEX ON STR(COD_TIPO,3) TAG COD_TIPO TO &CPathindices
 INDEX ON UPPER(DESC)     TAG DESC     TO &CPathindices
Mire en :
See : http://hmgforum.com/viewtopic.php?t=1577&p=12128
Tristan
Re: DBF Viewer
Post by Tristan »
Thanks Daniel :D
Is dbf/cdx file create from HMG compatible with Foxpro26 Dos version or VFP 9?
Is there utility like DBU for create dbf/cdx file?
Tristan
Re: DBF Viewer
Tristan wrote:Thanks Daniel :D
Tristan
Hello Tristan:
I use VFP, but never mix index for different languages.
see here
http://www.mail-archive.com/harbour@har ... 12873.html
http://lists.harbour-project.org/piperm ... 00173.html
