IDE 3.0 TEST XIIg
Re: IDE 3.0 TEST XIIg
Hello Master Roberto,
I found that in debugging during compilation, TAB becomes single SPACE, which when corrected shows differently for indenting. For example
   if empty(mDeptid)
   	msgbox("Please specify department!", thiswindow.title); frmEmp.cboDeptid.setfocus(); return
becomes
   if empty(mDeptid)
It's a very minor different behavior (I don't even want to call it a "problem" at all :) )
I know. It was reported by Marek already.
I guess that the problem is in TextBox (used on grid edit). It could be hard to modify such default behavior.
Hello
Wonderful :o
Thanks a lot Maestro, this release is very impressive :)
My language file attached.
Best regards
Turkish.rar
Turkish Language file for Release 3.0 Test XIIg
(3.13 KiB) Downloaded 295 times
Sorry to bother again. Had this been taken care of?
http://hmgforum.com/viewtopic.php?p=7053#p7053
I'm using notepad++ as my source editor.
Notepad++ often reports changes in source code, even if I don't use built-in into IDE mechanism of editing sources..
Why?
Marek
mol wrote:I'm using notepad++ as my source editor.
Why?
Marek
There is nothing on IDE that 'touch' the sources excepting error tracking window editor.
Why?
Marek
Because Notepad++ and IDE are different applications. IDE opens a copy of the file in the disk and saves it outside the purview of Notepad++. It just can't tell Notepad++, "Hi, change this line content to this one". Therefore, Notepad++ reports the change in the source code outside. Even Crimson also says so. It is ok if we accept to the modified code, I think.
Mean while, ran this far, I expect the editor also in-built with IDE. :)
I'm using three applications while programming: IDE, Notepad++, Total Commander (sometimes command line). I think it's good combination to work comfortable.
I'm attaching polish language file
polish.zip
(3.46 KiB) Downloaded 275 times
I've reached error working with IDE 3.0 XII g
Date:12/18/09 Time: 10:37:44
Error BASE/1449 Syntax error: &
Called from _DEFINEMENUITEM(182)
Called from MAIN(9)
Date:2009.12.19 Time: 12:45:14
Error BASE/1003 Variable does not exist: RESULT
Called from EVENTEDIT(42741)
Called from (b)MAIN(902)
Called from _DOCONTROLEVENTPROCEDURE(4749)
Called from EVENTS(1735)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4437)
Called from DOMETHOD(7262)
Called from _OPEN(25021)
Called from EDITFILE(29007)
Called from (b)MAIN(753)
Called from EVENTS(1567)
Called from _ACTIVATEWINDOW(4391)
Called from MAIN(923)
PS. I've edited form manually and leaved duplicate buttons names...
Marek
