IDE 3.0 TEST XIId
Re: IDE 3.0 TEST XIId
mol wrote:I found that correcting error in source file extends tabs into spaces.
I don't like it :(
Well... it could be difficult...
Source editor is an 'almost' standard grid with an experimental new event that allows to take an action on cell saving.
So, editing is done with a standard TEXTBOX and then saved with FCREATE/FWRITE/FCLOSE.
I should investigate in which part of the process, the conversion is done.
raumi75
Post by raumi75 »
Hello Meister Roberto,
this debug-feature is really great. I just tried it out.
Find attached the updated german language file
Jan
deutsch.zip
(3.17 KiB) Downloaded 335 times
raumi75
Post by raumi75 »
Dear Roberto,
thank you very much for the new release! It is very good.
I have two little suggestions for the debug-feature:
Could you add Line-Numbers to the source-code grid? That would be helpful.
When enlarging the Build log window, the source-code control should get bigger, too.
Raumi
Roberto Lopez wrote:
mol wrote:I've noticed that F5 F8 keys work in every IDE window. That's great!
Maybe one step beyond - working F5 F8 keys while editing form?
I know that I demand a lot... :D
many thanks, Roberto!
Yes yes yes... I'll do it :)
Super work.
I think, pressink F5 or F8 should automatically save form.
About polish.lng - I will update it tomorrow.
Best regards, Marek
raumi75 wrote:Hello Meister Roberto,
Jan
Thanks!
raumi75 wrote:Dear Roberto,
Raumi
It's a good idea. I'll work on it.
Thanks.
I'm attaching polish.lng
polish.zip
(3.34 KiB) Downloaded 364 times
mol wrote:I'm attaching polish.lng
Thanks.
After pressing F5 in build log window, I've got en error:
Date:2009.11.27 Time: 10:36:24
Error: HMG 3.0.0 Forum Test XII (2009.11.15)
Non top modal windows can't be released. Program terminated
Called from _RELEASEWINDOW(2962)
Called from DOMETHOD(7271)
Called from (b)SHOWLOG(41816)
Called from _DOCONTROLEVENTPROCEDURE(4749)
Called from EVENTS(553)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4413)
Called from DOMETHOD(7262)
Called from SHOWLOG(41966)
Called from NEWBUILD(38309)
Called from (b)HMGMAKE(38222)
Called from _PROCESSINITPROCEDURE(4588)
Called from _ACTIVATEWINDOW(4412)
Called from HMGMAKE(38236)
Called from BUILDPROJECTM(35601)
Called from RUNAPPLICATION(30347)
Called from (b)MAIN(501)
Called from EVENTS(1364)
Called from _ACTIVATEWINDOW(4437)
Called from _OPEN(25065)
Called from EDITFILE(29019)
Called from (b)MAIN(822)
Called from EVENTS(1567)
Called from _ACTIVATEWINDOW(4391)
Called from MAIN(977)
mol wrote:After pressing F5 in build log window, I've got en error:
Stange... this does not happen here...
I'll try to find the problem.
Thanks for reporting.
