HMG 3.0.29 Patch 'a'
Hi all,
This patch fixes problem in windows handling introduced 3.0.29 and reported by Marek
I've fixed a little problem in IDE (introduced 3.0.29 too) and reinforced error checking to avoid unwanted operations involving panel windows.
Enjoy!
patch3029a.rar
(950.34 KiB) Downloaded 435 times
Re: HMG 3.0.29 Patch 'a'
Hi Roberto,
Tested, no problem encountered :)
WAIT WINDOW error gone away, \samples\panel.* and \samples\external.windows\panel also re-compiled and ran perfect.
Thanks a lot to all of advances :D
Best regards
esgici wrote:Hi Roberto,
Best regards
Thanks!
sudip
Post by sudip »
Hello Roberto,
Thank you very much :)
Regards.
claudiotedesco
Post by claudiotedesco »
Hola Roberto
Te comento que el ejemplo que adjunto me da error con este PATCH "a" en Windows 2000 SP4, no ocurre lo mismo si lo compilo con el HMG 3.0.29 solamente.
El error se produce cuando preciono el boton BASE DE DATOS BROWSE.
Adjunto el ejemplo
ej1.rar
(102.74 KiB) Downloaded 304 times
claudiotedesco wrote:Hola Roberto
Adjunto el ejemplo
Appears to be working fine here. Which is the problem?
Parece estar funcionando bien aquí. ¿Cuál es el problema?
Roberto Lopez wrote: Appears to be working fine here. Which is the problem?
Este es el test que hice / this is the test I've made (adjunto/attached).
capture.rar
(1.59 MiB) Downloaded 355 times
Czarny_Pijar
Post by Czarny_Pijar »
Norton Commander is really immortal :roll:
Czarny_Pijar wrote:Norton Commander is really immortal :roll:
I've used the utility you've suggested for this situations. It's fantastic.
By the way... it's not Norton Commander, it's Far Manager: http://www.farmanager.com/.
The Norton Commander 'soul' is immortal :)
