HMG 3.0.28
sudip
Re: HMG 3.0.28
Post by sudip »
Hello Roberto,
I am facing problem regarding refresh method of grid. I compiled and ran some code with ver 3.0.27 without any problem. But it gives error with 3.0.28. I created a small sample to show the error. Please compile following code and run. Please click on "Calculate" button more than 2 or 3 times to see the problem.
REQUEST SQLMIX
Function Main()
   local adbf := {}
   local cCtrl := {"TEXTBOX", "CHARACTER"}, iCtrl := {"TEXTBOX", "NUMERIC", "999"}, nCtrl :=  {"TEXTBOX", "NUMERIC", "99999999.99"}
   private aData := {}
   set deleted on
   for i := 1 to 10
      aadd(aData, {'Emp '+ltrim(str(i)), i*1000.00})
   next
   aadd(adbf,  {"empnm",   "c",  40,   0})
   aadd(adbf,  {"basic",   "n",  10,   2})
   DBCREATE("salreg", adbf, "SQLMIX", .T., "salreg")
   DEFINE WINDOW salreg ;
      WIDTH 700             ;
      HEIGHT 550             ;
      TITLE "Grid Test" ;
      main
      DEFINE BUTTON Calc
         ROW    40
         COL    560
         WIDTH  120
         CAPTION "&Calculate"
         ACTION SalRegCalc()
      END BUTTON
      define grid grid_1
         row 70
         col 10
			WIDTH 670
			HEIGHT 380
			HEADERS {'Employee','Basic'}
			WIDTHS {200,100}
			justify {0,1}
			COLUMNCONTROLS {cCtrl,nCtrl}
			ROWSOURCE "salreg"
			COLUMNFIELDS { 'empnm','basic'}
      end grid
	salreg.Center
	salreg.Activate
static function SalRegCalc()
   select salreg
   delete all
   for i := 1 to len(aData)
      append blank
      replace empnm with aData[i, 1]
      replace basic with aData[i, 2]
   next
   salreg.Grid_1.Refresh
   return nil
Problem is that, I tested the code with 3.0.27 and installed the app in my client's place, and today when I made a small change at client's place, I didn't check for the grid refresh method (it's my fault :( ) and after returning home, I noticed the error.
Most probably I made some mistakes in my code. :( But, when I compiled it with HMG 3.0.27 again, it worked fine :)
Thanks in advance :)
With best regards.
sudip
Re: HMG 3.0.28
Post by sudip »
Hello All,
Did anyone check the problem I mentioned in previous post?
You may also download from
GridTest001.zip
(1.3 KiB) Downloaded 281 times
With best regards.
Re: HMG 3.0.28
I too confirm the same Sudip.
I think Roberto would solve the problem in the next release.
sudip
Re: HMG 3.0.28
Post by sudip »
Thank you Friend :)
With best regards.
swapan
Re: HMG 3.0.28
Post by swapan »
Dear Sudip:
Its perfectly alright in HMG 3.0.24 (2010.03.07) version.
Not yet installed this latest 3.0.28 though!
I think it will be not a major issue (as it is ok in previous versions), and would be resolved
with the next release, if there's no workaround for it in .28 version.
Thanks & Regards,
Swapan Das
http://www.swapandas.com/
Re: HMG 3.0.28
sudip wrote:Hello All,
GridTest001.zip
With best regards.
I'll review it ASAP.
Re: HMG 3.0.28
sudip wrote: Problem is that, I tested the code with 3.0.27 and installed the app in my client's place, and today when I made a small change at client's place, I didn't check for the grid refresh method (it's my fault :( ) and after returning home, I noticed the error.
Please, consider that data-bound grid is fully new code and thus, it could has some undiscovered problems.
Moreover, every time you fix something, there is a possibility that a new problem arises.
I'm doing my best.
sudip
Re: HMG 3.0.28
Post by sudip »
Roberto Lopez wrote:...
I'm doing my best.
Yes Roberto :) Please continue the improvement of HMG in your time :)
For the time being I compiled my code into 3.0.27 and it is running fine :)
With best regards.
Re: HMG 3.0.28
Then you don't fix that something. ;)
Haa haa. Just joking.
It is a nice Murphy's law:
A solution to a problem will be the root of a new problem.
Re: HMG 3.0.28
Data-bound grid is specially tricky and difficult because it works on a 'callback' basis.
This means that the OS calls the specified procedure when it 'needs' to repaint a specific cell.
I've already fixed all bugs reported about grid for 3.0.28, but I'll tag the next release as 'Test', since its 'sensitive nature'.
