Post
by MigSoft » Mon Apr 05, 2010 12:14 am
Hello,
These are the results:
2010.04.04 19:51:26 Windows 7 6.1.7600
Harbour 2.1.0dev (Rev. 14264) MinGW GNU C 4.4.1 (32-bit) x86
THREADS: 0
N_LOOPS: 1000000
[ T000: empty loop overhead ]...................................0.05
[ T001: x := L_C ]..............................................0.05
[ T002: x := L_N ]..............................................0.05
[ T003: x := L_D ]..............................................0.05
[ T004: x := S_C ]..............................................0.05
[ T005: x := S_N ]..............................................0.06
[ T006: x := S_D ]..............................................0.06
[ T007: x := M->M_C ]...........................................0.05
[ T008: x := M->M_N ]...........................................0.06
[ T009: x := M->M_D ]...........................................0.06
[ T010: x := M->P_C ]...........................................0.06
[ T011: x := M->P_N ]...........................................0.05
[ T012: x := M->P_D ]...........................................0.06
[ T013: x := F_C ]..............................................0.14
[ T014: x := F_N ]..............................................0.20
[ T015: x := F_D ]..............................................0.11
[ T016: x := o:Args ]...........................................0.11
[ T017: x := o[2] ].............................................0.11
[ T018: round( i / 1000, 2 ) ]..................................0.25
[ T019: str( i / 1000 ) ].......................................0.87
[ T020: val( s ) ]..............................................0.22
[ T021: val( a [ i % 16 + 1 ] ) ]...............................0.39
[ T022: dtos( d - i % 10000 ) ].................................0.27
[ T023: eval( { || i % 16 } ) ].................................0.28
[ T024: eval( bc := { || i % 16 } ) ]...........................0.14
[ T025: eval( { |x| x % 16 }, i ) ].............................0.19
[ T026: eval( bc := { |x| x % 16 }, i ) ].......................0.20
[ T027: eval( { |x| f1( x ) }, i ) ]............................0.30
[ T028: eval( bc := { |x| f1( x ) }, i ) ]......................0.27
[ T029: eval( bc := &("{ |x| f1( x ) }"), i ) ].................0.27
[ T030: x := &( "f1(" + str(i) + ")" ) ]........................1.93
[ T031: bc := &( "{|x|f1(x)}" ), eval( bc, i ) ]................2.07
[ T032: x := valtype( x ) + valtype( i ) ].....................0.30
[ T033: x := strzero( i % 100, 2 ) $ a[ i % 16 + 1 ] ]..........0.84
[ T034: x := a[ i % 16 + 1 ] == s ].............................0.30
[ T035: x := a[ i % 16 + 1 ] = s ]..............................0.30
[ T036: x := a[ i % 16 + 1 ] >= s ].............................0.30
[ T037: x := a[ i % 16 + 1 ] <= s ].............................0.28
[ T038: x := a[ i % 16 + 1 ] < s ]..............................0.28
[ T039: x := a[ i % 16 + 1 ] > s ]..............................0.31
[ T040: ascan( a, i % 16 ) ]....................................0.22
[ T041: ascan( a, { |x| x == i % 16 } ) ].......................1.97
[ T042: iif( i%1000==0, a:={}, ) , aadd(a,{i,1,.T.,s,s2,a2 ]....0.66
[ T043: x := a ]................................................0.06
[ T044: x := {} ]...............................................0.08
[ T045: f0() ]..................................................0.08
[ T046: f1( i ) ]...............................................0.11
[ T047: f2( c[1...8] ) ]........................................0.09
[ T048: f2( c[1...40000] ) ]....................................0.11
[ T049: f2( @c[1...40000] ) ]...................................0.09
[ T050: f2( @c[1...40000] ), c2 := c ]..........................0.12
[ T051: f3( a, a2, s, i, s2, bc, i, n, x ) ]....................0.41
[ T052: f2( a ) ]...............................................0.11
[ T053: x := f4() ].............................................0.36
[ T054: x := f5() ].............................................0.17
[ T055: x := space(16) ]........................................0.14
[ T056: f_prv( c ) ]............................................0.28
[ total application time: ]....................................19.56
[ total real time: ]...........................................19.99
2010.04.04 19:25:10 Windows 7 6.1.7600
Harbour 2.1.0dev (Rev. 14234) MinGW GNU C 4.4.4 (64-bit) x86-64
THREADS: 0
N_LOOPS: 1000000
[ T000: empty loop overhead ]...................................0.06
[ T001: x := L_C ]..............................................0.00
[ T002: x := L_N ]..............................................0.00
[ T003: x := L_D ]..............................................0.00
[ T004: x := S_C ]..............................................0.00
[ T005: x := S_N ]..............................................0.02
[ T006: x := S_D ]..............................................0.00
[ T007: x := M->M_C ]...........................................0.02
[ T008: x := M->M_N ]...........................................0.00
[ T009: x := M->M_D ]...........................................0.00
[ T010: x := M->P_C ]...........................................0.00
[ T011: x := M->P_N ]...........................................0.02
[ T012: x := M->P_D ]...........................................0.00
[ T013: x := F_C ]..............................................0.11
[ T014: x := F_N ]..............................................0.11
[ T015: x := F_D ]..............................................0.05
[ T016: x := o:Args ]...........................................0.08
[ T017: x := o[2] ].............................................0.06
[ T018: round( i / 1000, 2 ) ]..................................0.11
[ T019: str( i / 1000 ) ].......................................0.27
[ T020: val( s ) ]..............................................0.12
[ T021: val( a [ i % 16 + 1 ] ) ]...............................0.25
[ T022: dtos( d - i % 10000 ) ].................................0.20
[ T023: eval( { || i % 16 } ) ].................................0.20
[ T026: eval( bc := { |x| x % 16 }, i ) ].......................0.12
[ T027: eval( { |x| f1( x ) }, i ) ]............................0.22
[ T028: eval( bc := { |x| f1( x ) }, i ) ]......................0.20
[ T029: eval( bc := &("{ |x| f1( x ) }"), i ) ].................0.20
[ T030: x := &( "f1(" + str(i) + ")" ) ]........................1.64
[ T031: bc := &( "{|x|f1(x)}" ), eval( bc, i ) ]................2.06
[ T032: x := valtype( x ) + valtype( i ) ].....................0.22
[ T033: x := strzero( i % 100, 2 ) $ a[ i % 16 + 1 ] ]..........0.44
[ T034: x := a[ i % 16 + 1 ] == s ].............................0.16
[ T035: x := a[ i % 16 + 1 ] = s ]..............................0.17
[ T036: x := a[ i % 16 + 1 ] >= s ].............................0.16
[ T037: x := a[ i % 16 + 1 ] <= s ].............................0.17
[ T038: x := a[ i % 16 + 1 ] < s ]..............................0.16
[ T039: x := a[ i % 16 + 1 ] > s ]..............................0.14
[ T040: ascan( a, i % 16 ) ]....................................0.16
[ T041: ascan( a, { |x| x == i % 16 } ) ].......................1.53
[ T042: iif( i%1000==0, a:={}, ) , aadd(a,{i,1,.T.,s,s2,a2 ]....0.48
[ T043: x := a ]................................................0.00
[ T044: x := {} ]...............................................0.06
[ T045: f0() ]..................................................0.03
[ T046: f1( i ) ]...............................................0.08
[ T047: f2( c[1...8] ) ]........................................0.08
[ T048: f2( c[1...40000] ) ]....................................0.06
[ T049: f2( @c[1...40000] ) ]...................................0.08
[ T050: f2( @c[1...40000] ), c2 := c ]..........................0.09
[ T051: f3( a, a2, s, i, s2, bc, i, n, x ) ]....................0.25
[ T052: f2( a ) ]...............................................0.06
[ T053: x := f4() ].............................................0.28
[ T054: x := f5() ].............................................0.14
[ T055: x := space(16) ]........................................0.09
[ T056: f_prv( c ) ]............................................0.20
[ total application time: ]....................................15.18
[ total real time: ]............................................15.53
"Exe files" for your tests
speedtst.zip
(987.18 KiB) Downloaded 1182 times
