someone use Codejoc Xtreme Suite Pro Activex controls
i'm begin to use it, and i can't find te way to use events
someone have a tip
tanks
sorry for my bad english
Help with Activex
Help with Activex
- Prueba.jpg (55.66 KiB) Viewed 27908 times
Re: Help with Activex
You can get an idea from c:\hmg\samples folder. Search for activex subfolder(s).
- Roberto Lopez
- HMG Founder
martingz wrote:someone use Codejoc Xtreme Suite Pro Activex controls
someone have a tip
tanks
Current Activex implementation do not handle events.
I'm researching in a simple/easy to use way to do it.
- apais
AFAIK Codejok is one of the most difficult active x components to implement.
It uses non standards callbacks and other quiirks I cant remember now.
Angel
Angel
Angel Pais
Thank you all for your answers
- luisvasquezcl
¿¿¿ Por qué preguntan y contestan en inglés si esta parte del foro es en español???
- Roberto Lopez
- HMG Founder
OOPS!!!luisvasquezcl wrote:¿¿¿ Por qué preguntan y contestan en inglés si esta parte del foro es en español???
Como la pregunta estaba en Ingles, respondí en Ingles
